分析技术之缩写缩略语
2009-02-10     来源:本站     点击次数:9364
AAA - Amino acid analysis – 氨基酸分析
AAS - Atomic absorption spectrometry – 原子吸收光谱
AED - Atomic emission detection – 原子发射检测
AES - Atomic emission spectrometry – 原子发射光谱
AFD - Alkali flame detection – 碱火焰检测
API - Atmospheric-pressure ionization – 常压电离
AX/HPLC - Anion-exchange HPLC – 离子交换HPLC
CC - Open (low pressure) column chromatography – 开口(低压)柱色谱法
CD - Conductivity detection – 电导检测
CEC - Capillary Electrochromatography – 毛细管电色谱法
CF-FAB - Continuous flow FAB – 持流FAB
CGC - Capillary column gas chromatography – 毛细管柱气相色谱法
CI/MS - Chemical ionization MS – 化学电离MS
CIA - Capillary ion analysis – 毛细管离子分析
CLD - Chemiluminescence detection – 化学发光检测
CLSE - Column liquid-solid extraction – 液固柱萃取
13C-NMR - Carbon-13 NMR – 碳13NMR
CSFC - Capillary supercritical-fluid chromatography – 毛细管超临界流体色谱法
CV - Cyclic voltammetry – 循环伏安法
CX/HPLC - Cation-exchange HPLC – 阳离子交换HPLC
CZE - Capillary zone electrophoresis – 毛细管区域电泳
EC - Electron capture detection – 电子捕获检测
ECD - Electrochemical detection – 电化学检测
EI/MS - Electron-impact MS – 电子碰撞MS
EIA - Enzyme immunoassay – 酶免疫测定
ELISA - Enzyme-linked immunosorbent assay – 酶联免疫吸附测定
EMIT - Enzyme-multiplied immunoassay technique – 酶多联免疫测定技术
EPR - Electron paramagnetic resonance – 电子顺磁共振
FAB/MS - Fast-atom-bombardment MS – 快速原子轰击MS
FD - Fluorescence detection – 荧光检测
FIA - Flow injection analysis – 流动注射分析
FID - Flame ionization detection – 火焰离子化检测
FPD - Flame photometric detection – 火焰光度检测
FPIA - Fluorescence polarization immunoassay – 荧光偏振免疫测定
FTD - Flame thermionic detection (alkali flame ionization ) – 火焰热离子检测(碱火焰离子化)
GC - Gas chromatography – 气相色谱法
GC/MS - GC/mass spectrometry – GC/MS
GFC - Gel filtration chromatography – 凝胶过滤色谱法
GPC - Gel permeation chromatography – 凝胶渗透色谱法
HallECD - Hall electrolytic conductivity detection – 霍尔电解质电导率检测
HPLC - High performance liquid chromatography – 高效液相色谱法
µHPLC - Microcolumn HPLC – 微径柱HPLC
HPTLC - High performance TLC – 高效TLC
HRGC - High resolution GC – 高分辨GC
IE/HPLC - Ion-exchange HPLC – 离子交换HPLC
IEC - Ion-exchange (low pressure) chromatography – 离子交换(低压)色谱法
IEF - Isoelectric focusing – 等电点聚焦
ILC - Ion liquid chromatography – 离子液相色谱法
IMS - Ion mobility spectrometer – 离子淌度光谱仪
IR - Infrared spectrometry – 红外光谱法
LC - Liquid chromatography – 液相色谱法
µLC - Microcolumn LC – 微径柱LC
LC/MS - Coupled HPLC- mass spectrometry – LC/MS联用
LIFD - Laser-induced fluorescence detection – 激光诱导荧光检测
LLE - Liquid-liquid extraction – 液液萃取
LSC - Liquid scintillation counting – 液滴闪烁计数
LSE - Liquid-solid extraction – 液固萃取
MD - Mass detection – 质量检测
MECC - Micellar electrokinetic capillary chromatography – 胶束电动毛细管色谱法
MSD - Mass selective detection – 质量选择检测
NICI/MS - Negative-ion CI/MS – 负离子CI/MS
NMR - Nuclear magnetic resonance – 核磁共振
NP/HPLC - Normal-phase HPLC – 正相HPLC
NPD - Nitrogen phosphorous detection – 氮磷检测
PAD - Pulsed-amperometric detection – 脉冲电流检测
PAGE - Polyacrylamide gel electrophoresis – 聚丙烯酰胺凝胶电泳
PCR - Post-column reaction (on-line) – 后柱反应(在线)
PDA - Photodiode array – 二极管阵列
PI/HPLC - Paired-ion HPLC – 离子对上HPLC
PICI/MS - Positive-ion CI/MS – 正离子CI/MS
1H-NMR - Proton NMR – 质子NMR
PSFID - Phosphorus sulfur flame ionization detection – 磷硫火焰离子化检测
PTLC - Preparative TLC – 制备TLC
RD - Radioactivity detection – 放射性检测
RI - Refractive index detection – 示差折光检测
RIA – Radioimmunoassay – 放射免疫测定
RP/HPLC - Reversed-phase HPLC – 反相HPLC
RRA - Radioreceptor assay – 放射受体测定
SAX - Strong anion exchange – 强阴离子交换
SCX - Strong cation exchange – 强阳离子交换
SDS-PAGE - Sodium dodecyl sulfate PAGE – 十二烷基磺酸钠PAGE
SEC - Size exclusion chromatography – 尺寸排阻色谱法
SFC - Supercritical-fluid chromatography – 超临界流体色谱法
SID - Surface ionization detection – 表面离子化检测
SIM - Selective ion monitoring – 选择性离子监测
SPE - Solid phase extraction – 固相萃取
TCA - Total carbon analysis – 总碳分析
TCD - Thermal conductivity detection – 热导检测
2-D TLC - Two-dimensional TLC – 二维TLC
TEA - Thermal energy analyzer – 热能分析仪
TLC - Thin layer chromatography – 薄层色谱法
TSMS - Mass spectrometric detection with thermospray interface – 带热喷雾接口的质谱检测
UV/VIS - Ultraviolet/visible detection – 紫外/可见光检测
WAX - Weak anion exchange – 弱阴离子交换
WCX - Weak cation exchange – 弱阳离子交换
