B Cell Receptor 信号通路图
2012-07-13     来源:SciMall科学在线     点击次数:4445
B cells produce immunoglobulins (Ig, antibodies) that specifically bind antigen molecules. B cells first produce a membrane-bound form of immunoglobulin, the B cell receptor, as part of B cell differentiation. Each B cell expresses one immunoglobulin but the population of B cells in each individual display a wide variety of antigen specificity, with each cell expressing Ig on its surface as part of the B cell receptor complex. When the B cell receptor binds to antigen, it initiates a signal through other proteins non-covalently associated with it in the B cell receptor complex, the Ig-alpha (CD79a) and Ig-beta (CD79b) chains. The signal initiated by binding of antigen to the B cell receptor complex causes growth and proliferation of the B cell and the creation of an amplified clone of effector cells that secrete the antigen-specific immunoglobulin. Activation of the B cell receptor by antigen also results in the production of memory cells that persist in circulation to produce a more rapid immune response after future challenges by the same antigen.
本信号转导涉及的信号分子主要包括:
BCR,mlg,CD19,Ag,CRALChannel,Orai1,Lyn,Ezrin,Syk,SHP-1,SHP-2,SHIP,PTEN,Gab,BACP,Shc,Dok-3,PI3K,PIR-B,Csk,clathrin,Cbp/PAG,Cbl,p38,p70,p85,p110,CD19,CD22,CD40,CD45,Btk,Bam32,PLCγ2,LAB,BLNK,GRB2,SOS,RhoA,Akt,cdc42,Vav,HS1,Pyk2,Rsc,RapL,Riam,Rap,SOS,Rss,c-Raf,MEK1,MEK2,Erk1,Erk2,GRP,Dok-1,IP3R,STIM1,PKC,TAK1,CARMA1,Bcl10,MALT1,IKK,p38,IκB,NF-κB,CaM,GSK-3,mTOR,S6K,Calclneurln,NFAT,MEKK8,MKK3,MKK4,MKK6,MKK7,JNK1,JNK2,CaMK,MEF2C,CREB,ATF-2,Jun,Bcl-6,Egr-1,Elk-1,Bcl-xL,Bfl-1,Oct-2,Ets1,FoxO等。
点击图中信号分子,查看详细通路图及产品(抑制剂,抗体,磷酸化抗体,检测试剂盒,重组蛋白等):
