利用植物多酚-叶绿素仪估算葡萄叶片氮状况的反射指数
2022-04-18     来源:本站     点击次数:1756
Dualex是一款源自于法国国家科学院 (CNRS)及巴黎第十一大学技术,由奥地利PESSL公司生产(原法国Force-A公司)开发的新型多功能叶片测量仪。它可同时准确测量叶片的叶绿素含量、叶片表层的类黄酮和花青素含量,适用于植物生理学和农学(如水稻叶绿素浓度,玉米氮素状况,葡萄藤等)相关研究。
其测量对象可以是单子叶植物,双子叶植物或多年生植物。这款设备简单易用,可进行实时和非破坏性测量。由于不需要校准标定和事先的样品制备,测量工作可在实验室或现场完成。此外,该设备在各种温度的和环境光照条件下均可正常使用。系统采用专利设计,光学传感器可进行简单、快速、无损测量叶片中的叶绿素、多酚以及花青素。
Dualex便携式智能气象-叶绿素-花青素-黄酮醇测量仪
背景和目标
光学叶片感应植物氮(N)状态可以根据植物需求施肥。本研究的目的是评估叶片反射率指数和手持设备在葡萄N和叶绿素(Chl)估算中的适用性。
方法和结果
对长期施肥试验中的雷司令叶进行了氮和色素分析,并连续两个季节记录了其在可见光/近红外范围内的光谱反射率。在第二个季节,还使用基于Chl荧光的便携式设备(Dualex)对叶片进行了测量。已发表的反射指数和荧光指数与色素和氮的浓度进行回归。Chl/N比率的时间变化使通过Chl间接评估氮变得复杂。红边拐点和几个三到四个波段指数可以很好地预测叶片N。荧光指数可以可靠地估计N和Chl。
结论
虽然叶色素可以通过简单的双波段指数进行分析,但准确的N估计需要更复杂的指数,如三波段指数或根据导数光谱计算的指数。
研究的意义
这项研究的数据将有助于种植者无破坏性地监测葡萄氮素状况的时空变化,从而改善施肥。
Performance of reflectance indices and of a handheld device for estimating in-field the nitrogen status of grapevine leaves
Background and Aims
Optical leaf sensing of plant nitrogen (N) status enables fertilisation based on plant demand. The aim of this study was to assess the suitability of leaf reflectance indices and of a handheld device for the estimation of N and chlorophyll (Chl) in Vitis vinifera L. cv. Riesling.
Methods and Results
Riesling leaves from a long-term fertilisation trial were analysed for nitrogen and pigments and their spectral reflectance in the Vis/near-infrared range was recorded for two consecutive seasons. In the second season the leaves were also measured with a Chl fluorescence based portable device (Dualex). Published reflectance indices and fluorescence indices were regressed against the concentration of pigment and N. Temporal changes in the Chl/N ratio complicated the indirect assessment of N via Chl. Red edge inflection points and several three- to four-waveband indices allowed for a good prediction of leaf N. Fluorescence indices allowed for reliable estimation of N and Chl.
Conclusions
While leaf pigments can be analysed by simple two-band indices, accurate N estimation requires more complex indices such as three-band indices or indices calculated from derivative spectra.
Significance of the Study
Data from this study will assist growers to monitor non-destructively the spatial and temporal variability of grapevine N status and thereby, improve fertilisation.
相关阅读
Dualex 便携式智能气象-叶绿素-花青素-黄酮醇测量仪
PESSL便携式便携式植物多酚-叶绿素仪原理
Dualex植物多酚-叶绿素仪:腐殖酸通过铁依赖和非铁依赖的协同机制缓解禾本科植物的铁失绿症
Dualex植物多酚-叶绿素仪:硝化抑制剂和/或间作效应下玉米(和小麦灌溉种植系统中的硝酸盐淋失
Dualex植物多酚-叶绿素仪:与保持绿色表达相关的叶片和冠层性状与对水分胁迫具有不同耐性的小麦基因型的产量构成密切相关
Dualex植物多酚-叶绿素仪:基于地面和智能传感器的冬小麦营养营养仪
Dualex植物多酚-叶绿素仪:增加角质层蜡沉积不会改变残余叶片蒸腾作用
Dualex植物多酚-叶绿素仪--氮平衡指数:不同生物刺激剂对水培生菜的效果比较
Dualex植物多酚-叶绿素仪:固体消化物和葡萄园冬季修剪堆肥替代苗圃中微繁殖高丛蓝莓生长基质中的泥炭研究
Dualex植物多酚-叶绿素仪:不同灌溉制度下根际细菌和藻类对金盏草生理生化指标的影响
Dualex植物多酚-叶绿素仪:Sentinel-2A与近端传感器数据协同提取水稻不同生育期生化参数
Dualex植物多酚-叶绿素仪:三种便携式光学传感器在冬小麦氮素状况无损诊断中的应用
Dualex植物多酚-叶绿素仪:基于微碳技术(MCT®)的肥料对土壤和辣椒生长室和田间培养的生物刺激效应
Dualex植物多酚-叶绿素仪:根际细菌在减轻大豆干旱胁迫中的作用
Dualex植物多酚-叶绿素仪:不同辐射组分下水分亏缺对苹果幼苗生长的影响
Dualex植物多酚-叶绿素仪:不同的非生物光谱途径揭示了不同物种的病原体应激信号
