用植物多酚叶绿素仪夹持传感器预测玉米氮素状况
2022-04-27     来源:本站     点击次数:1787
Dualex是一款源自于法国国家科学院 (CNRS)及巴黎第十一大学技术,由奥地利PESSL公司生产(原法国Force-A公司)开发的新型多功能叶片测量仪。它可同时准确测量叶片的叶绿素含量、叶片表层的类黄酮和花青素含量,适用于植物生理学和农学(如水稻叶绿素浓度,玉米氮素状况,葡萄藤等)相关研究。
其测量对象可以是单子叶植物,双子叶植物或多年生植物。这款设备简单易用,可进a行实时和非破坏性测量。由于不需要校准标定和事先的样品制备,测量工作可在实验室或现场完成。此外,该设备在各种温度的和环境光照条件下均可正常使用。系统采用专利设计,光学传感器可进行简单、快速、无损测量叶片中的叶绿素、多酚以及花青素。
Dualex便携式智能气象-叶绿素-花青素-黄酮醇测量仪
摘要
农业系统中的氮(N)损失增加了空气和水污染,这些损失和过度施肥高度相关。因此,调整施氮量是提高氮肥效率的关键因素,而叶夹传感器有助于提高氮肥效率。本研究(结合西班牙中部的五个不同田间试验)试图确定clip传感器在玉米氮素状况识别和产量预测中的能力,比较两种不同的设备(SPAD-502®和Dualex®),并确定玉米叶片取样的最佳方案。因此,该研究表明,不同的叶夹叶绿素传感器呈现出相似的结果,尽管在较高的氮浓度下出现了一些差异。补充多酚信息(如黄酮)可以改善玉米缺氮预测。此外,本研究还为正确的采样方案提供了有价值的信息。这证明了采样位置(在叶片和植株中)和采样时间对于更好地估计玉米氮素状况至关重要。根据clip叶绿素传感器测量结果,可以获得适当的施肥建议。
关键词:叶绿素;多酚;营养缺乏;受精;精准农业
Predicting N Status in Maize with Clip Sensors: Choosing Sensor, Leaf Sampling Point, and Timing
Abstract
Nitrogen (N) losses from agricultural systems increase air and water pollution, and these losses are highly correlated with the excessive fertilization. An adjusted N fertilization is then a key factor in increasing the N fertilizer efficiency, and leaf clip sensors can help to improve it. This study (combining five different field experiments in Central Spain) tried to identify the ability of the clip sensors in maize N status identification and yield prediction, comparing two different devices (SPAD-502® and Dualex®) and identifying the best protocol for maize leaf sampling. As a result, the study demonstrated that different leaf clip chlorophyll sensors presented similar results, although some differences appeared at larger N concentrations. Complementary polyphenol information (as flavonol) can improve the maize N deficiency prediction. Moreover, valuable information for a proper sampling protocol was obtained with this study. It proved that the sampling position (in the leaf and in the plant) and sampling time were crucial for a better estimation of the maize N status. Proper fertilization recommendations could be achieved based on clip chlorophyll sensor measurements.
Keywords: chlorophyll; polyphenol; nutrient deficiency; fertilization; precision agriculture
相关阅读
Dualex 便携式智能气象-叶绿素-花青素-黄酮醇测量仪
PESSL便携式便携式植物多酚-叶绿素仪原理
Dualex植物多酚-叶绿素仪:腐殖酸通过铁依赖和非铁依赖的协同机制缓解禾本科植物的铁失绿症
Dualex植物多酚-叶绿素仪:硝化抑制剂和/或间作效应下玉米(和小麦灌溉种植系统中的硝酸盐淋失
Dualex植物多酚-叶绿素仪:与保持绿色表达相关的叶片和冠层性状与对水分胁迫具有不同耐性的小麦基因型的产量构成密切相关
Dualex植物多酚-叶绿素仪:基于地面和智能传感器的冬小麦营养营养仪
Dualex植物多酚-叶绿素仪:增加角质层蜡沉积不会改变残余叶片蒸腾作用
Dualex植物多酚-叶绿素仪--氮平衡指数:不同生物刺激剂对水培生菜的效果比较
Dualex植物多酚-叶绿素仪:固体消化物和葡萄园冬季修剪堆肥替代苗圃中微繁殖高丛蓝莓生长基质中的泥炭研究
Dualex植物多酚-叶绿素仪:不同灌溉制度下根际细菌和藻类对金盏草生理生化指标的影响
Dualex植物多酚-叶绿素仪:Sentinel-2A与近端传感器数据协同提取水稻不同生育期生化参数
Dualex植物多酚-叶绿素仪:三种便携式光学传感器在冬小麦氮素状况无损诊断中的应用
Dualex植物多酚-叶绿素仪:基于微碳技术(MCT®)的肥料对土壤和辣椒生长室和田间培养的生物刺激效应
Dualex植物多酚-叶绿素仪:根际细菌在减轻大豆干旱胁迫中的作用
Dualex植物多酚-叶绿素仪:不同辐射组分下水分亏缺对苹果幼苗生长的影响
Dualex植物多酚-叶绿素仪:不同的非生物光谱途径揭示了不同物种的病原体应激信号
Dualex植物多酚-叶绿素仪:用于在田间估算葡萄叶片氮状况的反射指数和手持设备的性能
Dualex植物多酚-叶绿素仪:短期采前补充UV-B可提高罗勒叶片贮藏期间的多酚含量和抗氧化能力
Dualex植物多酚-叶绿素仪:基于图像处理技术的5种红树林叶片形态特征及叶绿素相对含量的估测
Dualex植物多酚-叶绿素仪:利用叶片荧光传感器估算玉米各生育期植株氮浓度
Dualex植物多酚-叶绿素仪:便携式叶绿素仪测量作物叶片叶绿素浓度的评估
