估算茄子对根结线虫生理反应的近端遥感装置的比较
2022-05-06     来源:本站     点击次数:909
Dualex是一款源自于法国国家科学院 (CNRS)及巴黎第十一大学技术,由奥地利PESSL公司生产(原法国Force-A公司)开发的新型多功能叶片测量仪。它可同时准确测量叶片的叶绿素含量、叶片表层的类黄酮和花青素含量,适用于植物生理学和农学(如水稻叶绿素浓度,玉米氮素状况,葡萄藤等)相关研究。
其测量对象可以是单子叶植物,双子叶植物或多年生植物。这款设备简单易用,可进行实时和非破坏性测量。由于不需要校准标定和事先的样品制备,测量工作可在实验室或现场完成。此外,该设备在各种温度的和环境光照条件下均可正常使用。系统采用专利设计,光学传感器可进行简单、快速、无损测量叶片中的叶绿素、多酚以及花青素。
Dualex便携式智能气象-叶绿素-花青素-黄酮醇测量仪
摘要
近距离遥感设备正在被广泛应用于田间植物研究,以估计生物化学(例如色素或氮)或农学(例如叶面积、生物量或产量)参数作为胁迫指标。与传统方法相比,植物反应的非侵入性特征可以更快地筛选更多的种群,除了需要更多的时间外,还可能意味着材料被破坏或筛选是主观的(例如,视觉排序)。这项研究探索了单叶和整个冠层水平上的遥感设备的比较,基于此来评估茄子及其产量如何响应嫁接以耐受根结线虫方面的表现。结果表明,整个冠层的测量结果,例如从红-绿-蓝(RGB)图像(r=0.706,p值=0.001**)得到的绿面积(GA)或冠层温度(r=−0.619和p值=0.005**),优于单叶测量,例如通过Dualex(r=0.422和p值=0.059)评估产量的叶片叶绿素含量。此外,在讨论中还考虑了其他参数,如测量每个样本所需的时间或传感器的成本。总之,从RGB图像得出的指数显示了它们在评估作物状况方面的强大潜力,可作为其他更昂贵和耗时设备的低成本替代品。
关键词:近距离遥感;茄子;根结线虫;单叶测量;冠层测量;RGB图像;叶绿素含量;叶温
Comparison of Proximal Remote Sensing Devices for Estimating Physiological Responses of Eggplants to Root-Knot Nematodes
Abstract
Proximal remote sensing devices are becoming widely applied in field plant research to estimate biochemical (e.g., pigments or nitrogen) or agronomical (e.g., leaf area, biomass, or yield) parameters as indicators of stress. Non-invasive characterization of plant responses allows for the screening of larger populations faster than conventional procedures which, in addition to requiring more time, either imply the destruction of material or are subjective (e.g., visual ranking). This study explores the comparison of a set of remote sensing devices at single-leaf and whole-canopy levels based on their performance in assessing how the eggplant and its yield responds to grafting as a way to tolerate root-knot nematodes. The results showed that whole-canopy measurements, such as the Green Area (GA) derived from the Red-Green-Blue (RGB) images (r = 0.706 and p-value = 0.001**) or the canopy temperature (r = −0.619 and p-value = 0.005**), outperformed single-leaf measurements, such as the leaf chlorophyll content measured by the Dualex (r = 0.422 and p-value = 0.059) assessing yield. Moreover, other parameters, such as the time required to measure each sample or the cost of the sensors, were taken into account in the discussion. In sum, indices derived from the RGB images demonstrated their robust potential for the assessment of crop status as a low-cost alternative to other more expensive and time-consuming devices.
Keywords: proximal remote sensing; eggplants; toot-knot nematodes; single-leaf measurements; canopy measurements; RGB images; Chlorophyll content; leaf temperature
相关阅读
Dualex 便携式智能气象-叶绿素-花青素-黄酮醇测量仪
PESSL便携式便携式植物多酚-叶绿素仪原理
Dualex植物多酚-叶绿素仪:腐殖酸通过铁依赖和非铁依赖的协同机制缓解禾本科植物的铁失绿症
Dualex植物多酚-叶绿素仪:硝化抑制剂和/或间作效应下玉米(和小麦灌溉种植系统中的硝酸盐淋失
Dualex植物多酚-叶绿素仪:与保持绿色表达相关的叶片和冠层性状与对水分胁迫具有不同耐性的小麦基因型的产量构成密切相关
Dualex植物多酚-叶绿素仪:基于地面和智能传感器的冬小麦营养营养仪
Dualex植物多酚-叶绿素仪:增加角质层蜡沉积不会改变残余叶片蒸腾作用
Dualex植物多酚-叶绿素仪--氮平衡指数:不同生物刺激剂对水培生菜的效果比较
Dualex植物多酚-叶绿素仪:固体消化物和葡萄园冬季修剪堆肥替代苗圃中微繁殖高丛蓝莓生长基质中的泥炭研究
Dualex植物多酚-叶绿素仪:不同灌溉制度下根际细菌和藻类对金盏草生理生化指标的影响
Dualex植物多酚-叶绿素仪:Sentinel-2A与近端传感器数据协同提取水稻不同生育期生化参数
Dualex植物多酚-叶绿素仪:三种便携式光学传感器在冬小麦氮素状况无损诊断中的应用
Dualex植物多酚-叶绿素仪:基于微碳技术(MCT®)的肥料对土壤和辣椒生长室和田间培养的生物刺激效应
Dualex植物多酚-叶绿素仪:根际细菌在减轻大豆干旱胁迫中的作用
Dualex植物多酚-叶绿素仪:不同辐射组分下水分亏缺对苹果幼苗生长的影响
Dualex植物多酚-叶绿素仪:不同的非生物光谱途径揭示了不同物种的病原体应激信号
Dualex植物多酚-叶绿素仪:用于在田间估算葡萄叶片氮状况的反射指数和手持设备的性能
Dualex植物多酚-叶绿素仪:短期采前补充UV-B可提高罗勒叶片贮藏期间的多酚含量和抗氧化能力
Dualex植物多酚-叶绿素仪:基于图像处理技术的5种红树林叶片形态特征及叶绿素相对含量的估测
Dualex植物多酚-叶绿素仪:利用叶片荧光传感器估算玉米各生育期植株氮浓度
Dualex植物多酚-叶绿素仪:便携式叶绿素仪测量作物叶片叶绿素浓度的评估
