土壤环境中发泡聚苯乙烯吸水率与栽培作物相关变化研究
2022-05-06     来源:本站     点击次数:1213
Dualex是一款源自于法国国家科学院 (CNRS)及巴黎第十一大学技术,由奥地利PESSL公司生产(原法国Force-A公司)开发的新型多功能叶片测量仪。它可同时准确测量叶片的叶绿素含量、叶片表层的类黄酮和花青素含量,适用于植物生理学和农学(如水稻叶绿素浓度,玉米氮素状况,葡萄藤等)相关研究。
其测量对象可以是单子叶植物,双子叶植物或多年生植物。这款设备简单易用,可进a行实时和非破坏性测量。由于不需要校准标定和事先的样品制备,测量工作可在实验室或现场完成。此外,该设备在各种温度的和环境光照条件下均可正常使用。系统采用专利设计,光学传感器可进行简单、快速、无损测量叶片中的叶绿素、多酚以及花青素。
Dualex便携式智能气象-叶绿素-花青素-黄酮醇测量仪
摘要
随着聚苯乙烯泡沫塑料(EPS)在土壤环境中的应用,有必要了解化学吸附和土壤系统之间的相互作用。我们在含有宏观尺寸EPS(8.3±0.5mm)的土壤系统中使用农作物进行了植物生物测定。当在无作物(对照)、绿豆、生菜和水稻栽培后收集EPS时,我们发现,与无作物栽培相比,绿豆和水稻栽培后EPS的吸水率显著增加(p<0.05)。我们预计这些依赖作物的差异将与金属吸附和解吸高度相关。然而,初始镉溶液中镉(Cd)的吸附百分比(%)计算为15-18%,不同作物栽培条件之间没有显著差异。解吸百分比也显示出与作物依赖性吸水率的低水平交互作用。这些结果为更好地理解塑料之间的相互作用及其在土壤系统中作为化学载体的作用提供了有用的数据。
关键词:生物测定;镉吸附;发泡聚苯乙烯;理化性质;吸水率。
Crop-dependent changes in water absorption of expanded polystyrene in soil environments
Abstract
As expanded polystyrene (EPS) has been utilized in soil environments, there is a need to understand interactions between chemical adsorption and the soil system. We conducted a plant bioassay using agricultural crops in a soil system containing a macro-sized EPS (8.3 ± 0.5 mm). When the EPS was collected after cultivation of no crop (control), mung bean, lettuce, and rice, we found that its water absorption rate significantly (p < 0.05) increased after mung bean and rice cultivation as compared to the no crop condition. We expected that these crop-dependent differences would be highly linked with metal adsorption and desorption. However, cadmium (Cd) adsorption percentages (%) from the initial Cd solution were calculated as 15-18% with no significant differences between the different crop cultivation conditions. The desorption percentages also showed low levels of interaction with the crop-dependent water absorption rate. These results provide useful data for better understanding the interaction between plastics and their roles as chemical vectors in the soil system.
Keywords: Bioassay; Cd adsorption; Expanded polystyrene; Physicochemical properties; Water absorption rate.
相关阅读
Dualex 便携式智能气象-叶绿素-花青素-黄酮醇测量仪
PESSL便携式便携式植物多酚-叶绿素仪原理
Dualex植物多酚-叶绿素仪:腐殖酸通过铁依赖和非铁依赖的协同机制缓解禾本科植物的铁失绿症
Dualex植物多酚-叶绿素仪:硝化抑制剂和/或间作效应下玉米(和小麦灌溉种植系统中的硝酸盐淋失
Dualex植物多酚-叶绿素仪:与保持绿色表达相关的叶片和冠层性状与对水分胁迫具有不同耐性的小麦基因型的产量构成密切相关
Dualex植物多酚-叶绿素仪:基于地面和智能传感器的冬小麦营养营养仪
Dualex植物多酚-叶绿素仪:增加角质层蜡沉积不会改变残余叶片蒸腾作用
Dualex植物多酚-叶绿素仪--氮平衡指数:不同生物刺激剂对水培生菜的效果比较
Dualex植物多酚-叶绿素仪:固体消化物和葡萄园冬季修剪堆肥替代苗圃中微繁殖高丛蓝莓生长基质中的泥炭研究
Dualex植物多酚-叶绿素仪:不同灌溉制度下根际细菌和藻类对金盏草生理生化指标的影响
Dualex植物多酚-叶绿素仪:Sentinel-2A与近端传感器数据协同提取水稻不同生育期生化参数
Dualex植物多酚-叶绿素仪:三种便携式光学传感器在冬小麦氮素状况无损诊断中的应用
Dualex植物多酚-叶绿素仪:基于微碳技术(MCT®)的肥料对土壤和辣椒生长室和田间培养的生物刺激效应
Dualex植物多酚-叶绿素仪:根际细菌在减轻大豆干旱胁迫中的作用
Dualex植物多酚-叶绿素仪:不同辐射组分下水分亏缺对苹果幼苗生长的影响
Dualex植物多酚-叶绿素仪:不同的非生物光谱途径揭示了不同物种的病原体应激信号
Dualex植物多酚-叶绿素仪:用于在田间估算葡萄叶片氮状况的反射指数和手持设备的性能
Dualex植物多酚-叶绿素仪:短期采前补充UV-B可提高罗勒叶片贮藏期间的多酚含量和抗氧化能力
Dualex植物多酚-叶绿素仪:基于图像处理技术的5种红树林叶片形态特征及叶绿素相对含量的估测
Dualex植物多酚-叶绿素仪:利用叶片荧光传感器估算玉米各生育期植株氮浓度
Dualex植物多酚-叶绿素仪:便携式叶绿素仪测量作物叶片叶绿素浓度的评估
Dualex植物多酚-叶绿素仪:从高光谱图像和SIF反演估算辐射传输Vcmax来评估雨养和灌溉植物表型试验中的光合性能
Dualex植物多酚-叶绿素仪:单金属和双金属植物纳米颗粒对Mezquit生理状态的影响
Dualex植物多酚-叶绿素仪:LED照明剂量对tatsoi光合指标的影响
Dualex植物多酚-叶绿素仪:利用Dualex非破坏性测量确定不同甜樱桃园的覆盖下光有效性™
Dualex植物多酚-叶绿素仪:硅在渗透胁迫下介导两种不同番茄基因型差异耐逆反应中的调节作用
Dualex植物多酚-叶绿素仪:用非破坏性荧光传感器监测两个苹果品种对供水条件的生理生化反应
Dualex植物多酚-叶绿素仪:从Sentinel-2光谱带反演冠层叶绿素含量以估算冬小麦集约种植系统的氮素吸收
Dualex植物多酚-叶绿素仪:胚胎大小作为种子捕食耐受性性状:胚胎受损种子对植株再生的贡献
Dualex植物多酚-叶绿素仪:干旱和高温对4个冬小麦基因型光合特性的联合效应
