利用Dualex传感器监测两个苹果品种对供水条件的生理生化反应
2022-05-07     来源:本站     点击次数:1140
热点
Chl荧光技术评估植物生理反应的适用性。
叶绿素浓度不是一个合适的水分胁迫指标。
品种‘Pinova 10’对叶绿素荧光表现出较高的水亏缺敏感性。
叶片水势特别受提前浇水制度的影响。
摘要
在世界范围内,水资源短缺导致的干旱胁迫加剧了保持农业和园艺作物的高产的危险性。众所周知,不同的作物不仅需要不同的水分,而且不同的品种也需要不同的水分。最常见的是,植物对干旱胁迫的反应是在生理水平上监测的,例如通过植物水分状况(叶水势、相对含水量)或气孔行为、光合作用和渗透调节。然而,对这些参数的分析既耗时又具有破坏性。相比之下,荧光传感器等新方法似乎很有前途,因为它们易于在现场进行,无破坏性且分析迅速。因此,本研究的目的是调查两个苹果品种“Pinova 10”和“Gala Galaxy”对水分胁迫是否表现出不同的生理反应,例如叶片水势、相对含水量以及叶绿素和脯氨酸浓度。此外,叶绿素荧光参数被认为是一种很有前途的应激症状检测技术。“Gala Galaxy”比“Pinova 10”表现出更高的耐水性,尤其是在整个实验过程中的某些测量日,叶绿素荧光指数增加。与叶绿素含量(Chl_指数和SFR_R)和氮平衡(NBI和NBI_R)相关的荧光指数显示出相似的曲线。然而,用湿化学方法进行的叶片叶绿素分析并不是苹果树水分胁迫的可靠指标。在完全停水期间,DAT 38的叶水势受到影响,品种间没有显著差异。综上所述,与叶绿素含量和氮平衡相关的荧光指数有望成为一种有用的非破坏性工具,用于评估受水分限制的幼树的生理状态。
Monitoring physiological and biochemical responses of two apple cultivars to water supply regimes with non-destructive fluorescence sensors
Highlights
Suitability of Chl-fluorescence technique to assess plant physiological responses.
Chlorophyll concentration was not an appropriate water stress indicator.
Cultivar ‘Pinova 10’ showed higher sensibility to water deficit on Chl-fluorescence.
Leaf water potential is specially affected advanced watering withholding regime.
Abstract
Worldwide, increased drought stress induced by water shortages will be especially hazardous for maintaining high yields in agricultural and horticultural crops. It is known that not only do different crops have different water requirements, but that these can also vary between cultivars. Most commonly, plant responses to drought stress are monitored on the physiological level, for example via plant water status (leaf water potential, relative water content) or stomatal behavior, photosynthesis and osmotic adjustment. However, analyses of these parameters are time-consuming and destructive. In contrast, novel approaches such as fluorescence sensors seem promising as they are easy to embark in the field, non-destructive and quick to analyze. Therefore, the aim of this study was to investigate whether two apple (Malus domestica) cultivars, ‘Pinova 10’ and ‘Gala Galaxy’, show different physiological reactions, for example in leaf water potential, relative water content as well as chlorophyll and proline concentration, in response to water stress. In addition, chlorophyll fluorescence parameters were analyzed as a promising stress symptom detection technique. ‘Gala Galaxy’ showed higher tolerance to water deprivation conditions than ‘Pinova 10’, indicated especially by increased chlorophyll fluorescence indices on certain measurement days throughout the experimental course. Fluorescence indices related to chlorophyll content (Chl_Index and SFR_R) and nitrogen balance (NBI and NBI_R) showed similar curves. However, leaf chlorophyll analysis performed wet-chemically was not a reliable indicator of water stress in apple trees. Leaf water potential was affected on DAT 38, during complete watering withholding, without significant differences between the cultivars. In summary, fluorescence-based indices, related to chlorophyll content and nitrogen balance, promise to be a useful non-destructive tool to estimate physiological status of young apple trees submitted to water restriction regimes.
Dualex是一款源自于法国国家科学院 (CNRS)及巴黎第十一大学技术,由奥地利PESSL公司生产(原法国Force-A公司)开发的新型多功能叶片测量仪。它可同时准确测量叶片的叶绿素含量、叶片表层的类黄酮和花青素含量,适用于植物生理学和农学(如水稻叶绿素浓度,玉米氮素状况,葡萄藤等)相关研究。其测量对象可以是单子叶植物,双子叶植物或多年生植物。这款设备简单易用,可进a行实时和非破坏性测量。由于不需要校准标定和事先的样品制备,测量工作可在实验室或现场完成。此外,该设备在各种温度的和环境光照条件下均可正常使用。系统采用专利设计,光学传感器可进行简单、快速、无损测量叶片中的叶绿素、多酚以及花青素。
相关阅读
Dualex 便携式智能气象-叶绿素-花青素-黄酮醇测量仪
PESSL便携式便携式植物多酚-叶绿素仪原理
Dualex植物多酚-叶绿素仪:腐殖酸通过铁依赖和非铁依赖的协同机制缓解禾本科植物的铁失绿症
Dualex植物多酚-叶绿素仪:硝化抑制剂和/或间作效应下玉米(和小麦灌溉种植系统中的硝酸盐淋失
Dualex植物多酚-叶绿素仪:与保持绿色表达相关的叶片和冠层性状与对水分胁迫具有不同耐性的小麦基因型的产量构成密切相关
Dualex植物多酚-叶绿素仪:基于地面和智能传感器的冬小麦营养营养仪
Dualex植物多酚-叶绿素仪:增加角质层蜡沉积不会改变残余叶片蒸腾作用
Dualex植物多酚-叶绿素仪--氮平衡指数:不同生物刺激剂对水培生菜的效果比较
Dualex植物多酚-叶绿素仪:固体消化物和葡萄园冬季修剪堆肥替代苗圃中微繁殖高丛蓝莓生长基质中的泥炭研究
Dualex植物多酚-叶绿素仪:不同灌溉制度下根际细菌和藻类对金盏草生理生化指标的影响
Dualex植物多酚-叶绿素仪:Sentinel-2A与近端传感器数据协同提取水稻不同生育期生化参数
Dualex植物多酚-叶绿素仪:三种便携式光学传感器在冬小麦氮素状况无损诊断中的应用
Dualex植物多酚-叶绿素仪:基于微碳技术(MCT®)的肥料对土壤和辣椒生长室和田间培养的生物刺激效应
Dualex植物多酚-叶绿素仪:根际细菌在减轻大豆干旱胁迫中的作用
Dualex植物多酚-叶绿素仪:不同辐射组分下水分亏缺对苹果幼苗生长的影响
Dualex植物多酚-叶绿素仪:不同的非生物光谱途径揭示了不同物种的病原体应激信号
Dualex植物多酚-叶绿素仪:用于在田间估算葡萄叶片氮状况的反射指数和手持设备的性能
Dualex植物多酚-叶绿素仪:短期采前补充UV-B可提高罗勒叶片贮藏期间的多酚含量和抗氧化能力
Dualex植物多酚-叶绿素仪:基于图像处理技术的5种红树林叶片形态特征及叶绿素相对含量的估测
Dualex植物多酚-叶绿素仪:利用叶片荧光传感器估算玉米各生育期植株氮浓度Dualex植物多酚-叶绿素仪:便携式叶绿素仪测量作物叶片叶绿素浓度的评估Dualex植物多酚-叶绿素仪:从高光谱图像和SIF反演估算辐射传输Vcmax来评估雨养和灌溉植物表型试验中的光合性能
Dualex植物多酚-叶绿素仪:单金属和双金属植物纳米颗粒对Mezquit生理状态的影响
Dualex植物多酚-叶绿素仪:LED照明剂量对tatsoi光合指标的影响
Dualex植物多酚-叶绿素仪:利用Dualex非破坏性测量确定不同甜樱桃园的覆盖下光有效性™
