实验室装修规划设计与设备的统一
2015-09-22     来源:本站     点击次数:3360
实验室装修规划设计与设备的统一
实验室规划设计中涉及到的内容很多,如实验室内的设备仪器、储存、储藏家具、卫生要求、建筑和人员安全、防火要求、电路布线、给排水等等。Related to the contents of the laboratory, laboratory planning and design of a lot of decoration, such as laboratory equipment, storage, storage furniture, health requirements, construction and personnel safety, fire safety requirements, wiring, plumbing etc..
实验室装修在进行设计之前,首先要对目标实验室的以下内容进行了解,并进行初步规划。
装修设计现代化的实验室,首先要制定的提出实验室的总体规划,确定实验室的性质、目的、任务、依据和规模,确定各类实验室功能和工艺条件以及规模大小。
Laboratory renovation in the design, first of all to the following content to target Laboratory of understanding, and a preliminary planning.
Decoration design and modern laboratory, first of all to develop forward planning laboratory, determine the nature, purpose, mission laboratory, basis and scale, determine the types of function of laboratory and process conditions and size.
室内空间的总体概念,如房间形状,尺寸等。
天花的类型和高度等。
地面,要针对不同实验室采用不同地面,不能在实验室内使用大理石地面。现在人们最常用的是PVC地面和还氧树脂地面两种,也有的用瓷砖。地面除了要注意类型外,还要注意上下水管道的位置等。
The ground, be aimed at different laboratories using different ground, cannot use the marble ground in the laboratory. Now it is the most commonly used PVC ground and epoxy resin ground two, some with tile. The ground in addition to the attention of types, but also pay attention to the water pipes on the position.
实验室装修墙面,包括柱体的位置、窗台高、踢脚板的宽度等都要确定清楚,这是很重要的一个方面,因为这些都是在具体施工中经常出现问题的环节。
相关文章:实验室装修设计施工原则与技巧
