French Pressure Cell超高压细胞破碎仪应用
2020-12-25     来源:本站     点击次数:6096
一、细胞破碎应用
Cell Rupture, Disruption, Lysis are methods for disrupting cell walls and cell membranes to release biological molecules, whilst maintaining intracellular contents integrity.
细胞破裂、破碎、溶解是细胞壁和细胞膜破碎以释放生物分子,同时保留细胞内含物完整的方法。
Cell Disruption / Lysis细胞破碎/裂解
The apparatus used for cell disruption is often referred to as a 'French pressure cell press', or 'French Press'. Our 'Stansted' range of 'Benchtop' Cell Disruptors provide an
industry-leading, powerful and extremely user friendly replacement for the French ® pressure cell system with capabilities for batch and continuous operation.
用于细胞破碎的仪器常会被联想到'French pressure cell press'或者 'French Press'。我们的“'Stansted' 系列 'Benchtop'细胞破碎仪提供业界领先、强大和极为用户友好的French ®类型高压细胞系统,具有单批次和连续运行的功能。
Our very high pressure performance up to 58,000 psi (4,000 bar) ensure our systems can handle the toughest cells while a versatile range of flexible lysing valves ensure finely controlled operation even when working the softest.
我们非常高压力性能达58,000 psi (4000bar)保证我们的系统可以处理最坚硬的细胞,同时多功能范围的灵活的溶解阀保证非常好的控制处理最柔软的样品。
Common Applications include共同的应用包括:
 E.coli大肠杆菌
 Yeasts (s cerivises, Pichia)酵母菌
 Algae藻类
 Mamalllian cells马马利亚血细胞
 Bacillus 杆菌
 Staph a.葡萄杆菌
 CBD / Cannabinoids大麻素类
... and many others
Enzyme preparation, Cell extract preparation Bacterial and plant tissue disintegration Recovery of intercellular proteins and nucleic acid. Preparation of viral antigens, membrane
preparation for phizobia and pseudomonads ...... etc.)
生物细胞破壁: (大肠杆菌、酵母菌、霉菌......等等) 酶的分离和隔离,细菌和植物组织断裂,细胞内蛋白质和核酸的回收,制备EIA测试包的病毒性抗原,phizobia和假单体的膜制备,胚芽和毒素的回收,蛋白质纯化,细胞提取制备等 范围包括:微生物(大肠杆菌、酵母菌、酶菌)、藻类、动物细胞和组织、植物细胞和组织、昆虫、病毒、环境样品等。
Our scalable technology offer practical processing from 1ml, through bench top, pilot and production systems with flow rate in excess of 1000 l/hr.
我们的可扩展技术提供实际处理从1ml,实验桌面型,中试和生产系统流量超过1000升每小时。
二、生物技术:细胞破碎应用例子
生物细胞破壁:
1、大肠杆菌破碎前后镜检图。
1)未破碎
2)100MPa破碎一遍
3)100MPa破碎二遍
4)100MPa破碎三遍
5)100MPa破碎四遍
2、Lysis of Pseudomonas aeruginosa
Non-lysed Sample
 Lysed Sample
10ml of cells run once through machine at ~100 MPa
3、酵母菌破碎效果镜检图
三、各类细胞、细菌建议使用的压力
动物细胞(淋巴细胞)  1 to 15 MPa
细胞器与线粒体  1 to 15 MPa
寄生物(锥体虫) 1 to 15 MPa
Sperm   1 to 35 MPa
线虫类  1 to 35 MPa
大肠杆菌  30 to 140 MPa
动物组织  70 to 150 MPa
植物组织与藻类(蓝细菌)35 to 150 MPa
酵母菌  100 to 250 MPa
角质层  140 to 200 MPa
DNA  100 to 250 MPa
硬细菌(葡萄球菌、链球菌) 150 to 320 MPa
霉菌  150 to 320 MPa
