biorad imark酶标仪
The iMark™ microplate absorbance reader, with a wavelength range of 400–750 nm, is an economical, high-performance solution for a wide range of applications, including immunoassays with colorimetric substrates, such as ELISA, and protein assays such as Bradford and Lowry. The instrument can be used as a stand-alone reader or be controlled by a PC or Mac with Microplate Manager® 6 software
Features and Benefits of the iMark Reader
Features and Benefits of the iMark Reader Onboard Software
The iMark reader comes with six standard absorbance filters: 415, 450, 490, 595, 655, and 750 nm. Bio-Rad also supplies custom filters at 5 nm intervals from 400 to 750 nm on request.
The iMark microplate absorbance reader is registered with the FDA as a medical device for clinical chemistry applications.
Wavelength range | 400–750 nm |
Photometric range | 0.0–3.5 OD |
Linearity | ≤1.0% from 0.0–2.0 OD; ≤2.0% from 0.0–3.0 OD |
Accuracy | ≤1.0% or 0.010 from 0.000–3.000 OD at 490 nm |
Precision | 1.0% or 0.005 OD from 0.0–2.0 OD; 1.5% from 2.0–3.0 OD |
Resolution | 0.001 OD |
Filter wheel capacity | 8 |
Plate shaking (3 speeds) | Low, mid, high |
Duration, sec | 0–999 |
Read time | 6 sec at single wavelength, 10 sec at dual wavelengths |
Data output | Onboard graphical thermal printer and USB2 interface with PC or Mac data stations |
Data storage | Calender/clock funtions; 64 assay protocols |
Multilanguage support | 4 languages, LCD indication supported; printout report supported |
Dimensions (W x D x H), cm (in) | 34.6 x 37.7 x 16.4 (13.6 x 14.8 x 6.5) |
Weight, kg (lb) | 5.5 (12) |
一家经营进口实验室分析仪器及配件的专业公司。于2003年注册成立,在公司发展壮大的10多年里,我们始终为客户提供好的产品和技术支持、健全的售后服务。
