心输出量测定仪:Cardiotherm 400R
哥伦布仪器公司专门为实验动物设计制造了基于热稀释的心输出量测定仪。它的独特性在于能支持哥伦布仪器公司的微探针系列传感器。这些传感器可以用于测量实验室小型啮齿动物的心输出量。
Cardiotherm-400R是哥伦布仪器公司用于测试小动物心输出量最基础的仪器,它利用热稀释方法进行测量。在测量过程中,室温或冷却的生理盐水或葡萄糖溶液注射到小动物的右心脏,在此与测试动物的血液混合。所造成的温度变化能被肺部动脉或大动脉(对于小动物)感知。混合血液/指示剂流经温度测量位置,可以创建出一条反映温度变化的稀释曲线。曲线下面积与通过检测点的血液体积成反比,Cardiotherm-400R利用这些信息来计算心脏输出,以L/min或者ml/min为单位。
微探针可根据实验动物的大小来使用,可从小鼠到兔。微探针只能用于传感,它们没有额外的端口可用于注射或温度探测。在实际应用中,微探针的尖端经由颈动脉穿刺植于主动脉弓。另一个穿刺位置,通常选择颈静脉,用于将生理盐水注射到右心脏。微探针还可以用于急、慢性研究。可植入的微探针有一定大小,这样它们能植入大动脉和颈后切除的对应末端,接入一个小的连接器就可以进行心输出量测试。其它用于心输出量测试的哥伦布仪器包括一多微探针选择器,可连续监测多至6个目标。更详细的信息请咨询哥伦布仪器公司。
特点/技术规格
可以进行小鼠,大鼠和兔子的心输出量测试
可适用于大多数的电热调节导管
内建“自检”确认仪器的运行
监测血液温度
记录的模拟输出
遥控开始/终止控制与其他设备的图标记录或同步
心输出量范围:10mL/min到100L/min
血液温度范围:30°C到40°C
注射液温度范围:0-25°C
输出:模拟电压,与稀释曲线成比例
图标记录开始/终止封闭连接
Cardiac Output Computer: Cardiotherm 400R
Columbus Instruments manufactures a specialized line of thermodilution based cardiac output computers for use in laboratory animals. Unique to our cardiac output computers is their support for the Columbus Instruments'' Microprobe series of sensors employed in the measurement of cardiac output in small laboratory rodents.
Cardiotherm-400R is Columbus Instruments most basic instrument for cardiac output measurements in small animals by the thermodilution process. During the procedure, room temperature or iced saline or glucose is injected into the right heart where it mixes with subject blood. The resulting change in temperature is sensed in either the pulmonary artery or in the aorta (in small animals). The passage of the mixed blood/indicator by the measurement site creates a dilution curve representing the change in temperature. The area bound by the curve is inversely proportional to the volume of blood passing the detection site. Cardiotherm-400R uses this information to calculate cardiac output formatted in either liters or milliliters per minute.
Microprobes are available in sizes that range from use in mice to rabbits. Microprobes are strictly for sensing. They do not contain additional ports for either injection or temperature sensing. In practice, the tip of the probe is placed in the aortic arch via canulation of the carotid artery. A second canulation site, usually the jugular vein, is employed as an entry point for injection of saline into the right side of the heart. Microprobes are available for acute and chronic studies. Implantable Microprobes are sized such that they can be place in the aorta and the opposite end excised behind the neck where a small connector is accessed in preparation for making cardiac output measurements.
Additional items for the Columbus Instruments line of cardiac output instruments include a multiple Microprobe selector for sequential monitoring of up to six subjects. Consult Columbus Instruments for complete details on our line of cardiac output instrumentation.
Features / Specifications
Cardiac Output measurements in Mice, Rats and Rabbits
Adaptable to most thermistor catheters
Built-in ''Self-Test'' confirms instrument operation
Monitors Blood Temperature
Analog outputs for recording
Remote Start/Stop control for chart recording or synchronization with other devices
Cardiac Output Range: 10mL/min. to 100L/min.
Blood Temperature Range: 30o to 40o centigrade
Injectate Temperature Range: 0o to 25o centigrade
Outputs: Analog voltage proportional to dilution curve
Contact closure for chart recorder start / stop
