其他温度设备/程序降
顶部镂空的纤维材料的加热套(加热烧杯用)
Fabric heating top:
进口
美国/GLASCOL
100A MO1033 现货
100A MO1033
Fabric heating top:
Outside Diameter (in): 4.77
Product Weight (lbs): 0.6
side opening for up to 3 neck 250ml spherical flask for aluminum housed mantle, 140W, 230V Flask Diameter: 83 mm
Preventing Vapor Condensation In the Upper Half Of a Flask During Distillation Of High Boiling Materials. Supplied With a 4 Foot 2-Wire Twist-Lock Cord. Tops Are Designed To Work With Series M, TM, O, and STM Mantles. They Also Can accommodate Up to a 3-Neck Flask.
This mantle helps prevent vapor condensation in the upper half of a flask during distillation of high-boiling materials.
They protect the flask, the solutions, and the laboratory in these ways:
1) from drafts, which would disturb the reflux ratio during fractionation;
2) from flying glass of flask implosions in high-vacuum distillations;
3) from falling objects;
and, 4) from thermal strain between top and lower half of flask during hightemperature operations. With a glass-fabric construction and laced-side opening, the
elliptical hole accommodates 1-, 2-, and 3-neck flasks.
Specifications
Electrical: Separable 4-ft., 2-wire cord and locking connector.
外径(英寸):4.77
产品重量(磅):0.6
侧面开口,最多可容纳3个颈部250ml球形烧瓶,用于铝制外壳,140W,230V烧瓶直径:83 mm
防止高沸点物质蒸馏过程中烧瓶上半部分的蒸汽凝结。随附4英尺2线扭锁线。上衣经过设计可与M,TM,O和STM系列衬套配合使用。它们还可以容纳3颈烧瓶。
该罩有助于防止高沸点物料蒸馏过程中烧瓶上半部的蒸汽凝结。
它们通过以下方式保护烧瓶,溶液和实验室:
1)从气流中分馏,这会影响分馏过程中的回流比;
2)在高真空蒸馏中从烧瓶内壁飞出的玻璃中取出;
3)掉落的物体;
4)由于在高温操作期间烧瓶的上半部和下半部之间的热应变。具有玻璃纤维结构和侧边开口,
椭圆孔可容纳1颈,2颈和3颈烧瓶。
规格
电气:可分离的4英尺2线软线和锁定连接器。
我们提供世界著名品牌的百万种优质产品:
部分仪器>
三维细胞组织培养系统
微囊发生器
微量注射器、助吸器
转定子式均质器、碾槌式匀质器、混涡混合器、旋转器、细胞破碎器、振荡器、搅拌器
加热套
吸入暴露系统/气溶胶发生器
所售仪器类商品,保修一年,终身维修。
上海市徐汇区云锦路500号绿地汇中心A座809,在中国主要城市有销售支持,见www.equl.cn
2380088352, 390113670
上海:021-64280805
22817530
