免疫学/诊断检测试剂
CHARM β-内酰胺牛奶试纸20枚/盒 RSBLMTK20
ROSA SL Beta-Lactam Milk Tests
进口
美国Equl
系列
优惠
ROSA SL Beta-Lactam Milk Tests   β-内酰胺牛奶试纸   RSBLMTK20
20枚/盒
产品特色
8分钟内得到结果
检测五种等于或低于美国安全水平的β-内酰胺药物
用于牛,山羊,绵羊和水牛乳
大多数乳品加工厂使用相同的测试
业界领先的快速一步测定残留物诊断测试可快速,准确地检测抗生素,兽药等。测试单个母牛和大量筛选的理想选择。
每个测试都遵循相同的简单步骤-只需将牛奶添加到测试条中,进行孵育即可获得结果。这很容易! ROSA试纸条的测试结果可能以非官方的方式在视觉上进行解释,使其非常适合农场使用。
专门设计用于通过过度敏感的筛选测试来限制对非违规牛奶的排斥。对6种最广泛使用的β-内酰胺药物中的5种提供与美国安全水平(SL)最接近的检测:阿莫西林(5.6 ppb),氨苄青霉素(8.5 ppb),头孢氨苄(13.7 ppb),头孢噻呋(77 ppb)和青霉素G(3.6 ppb)。为您节省宝贵的牛奶,以帮助您检查牛奶并减少“热”负荷的风险。包括移液器。
必须与DO ROSA 8分钟双重培养箱一起使用(另售)。
Product Features
Results in 8 minutes
Detects five beta-lactam drugs at or below U.S. Safe Levels
Use for bovine, goat, sheep, and buffalo milk
The same test most dairy processing plants use
Industry-leading Rapid One Step Assay residue diagnostic tests deliver fast, accurate detection of antibiotics, veterinary drugs and more. Ideal for testing individual cows and for bulk screening.
Each test follows the same simple procedure – just add milk to test strip, incubate and get results. It’s easy! Test results from ROSA strips may be interpreted visually in an unofficial capacity, making it ideal for farm use.
Specifically designed to limit rejection of non-violative milk by overly sensitive screening tests. Provides detection at the closest match to U.S. safe levels (SL) for 5 of the 6 most widely used beta-lactam drugs: amoxicillin (5.6 ppb), ampicillin (8.5 ppb), cephapirin (13.7 ppb), ceftiofur (77 ppb) and penicillin G (3.6 ppb). Saves you valuable milk to help boost your milk check and helps reduce risk of "hot" load. Includes pipettes.
Must use with ROSA 8 min Dual Incubator (sold separately).
Have questions? Ask us, we can help!
Charm Sciences representatives are available to work with you and your farm to make sure you get the support you need to correctly and accurately use Charm tests.
我们提供世界著名品牌的百万种优质产品:
部分仪器>
三维细胞组织培养系统
微囊发生器
微量注射器、助吸器
转定子式均质器、碾槌式匀质器、混涡混合器、旋转器、细胞破碎器、振荡器、搅拌器
加热套
吸入暴露系统/气溶胶发生器
所售仪器类商品,保修一年,终身维修。
上海市徐汇区云锦路500号绿地汇中心A座809,在中国主要城市有销售支持,见www.equl.cn
2380088352, 390113670
上海:021-64280805
22817530
