其他实验耗材
Hausser细菌计数板 精子计数板
Hausser细菌计数板 精子计数板
Petroff-Hausser Counting Chamber
进口
hausser
¥7548.00
精子计数板(Petroff-Hausser Counting Chamber):或者称细菌计数板Bacteria Counter,具有单一计数区,盖玻片表面被激光蚀刻有计数网格,改良牛鲍氏型,深度:0.02mm,这个优化的深度形成的单层精子细胞。用于细菌或者用于未稀释标本的精子计数,计数精子时一般要杀死精子或者固定精子后进行。
货号 品名 规格
3990(7548元) Petroff Hausser Chamber 1个
3920(9250元) Petroff-Hausser Chamber w/ Case 1个
3900sp(7474元) Petroff-Hausser Chamber no grid, w/ case 1个
3901(9916元) Petroff-Hausser Chamber 10 microns w/ Grid 1个
3902(9916元) Petroff-Hausser Chamber 20 microns w/ Grid 1个
3951(9916元) Petroff-Hausser Chamber 20 microns w/ Grid 1个
3952(9916元) Petroff-Hausser Chamber 20 microns w/o Grid 1个
Directions for Use:
Usage Sperm Analysis and Counting Bacteria Counting
Cell Depth 0.02mm (1/50 mm)
Ruling Pattern
Improved Neubauer , 1/400 square mm
In order to count the number of sperm per milliliter, dilution is not necessary. To immobilize sperm, there are two recommendations:
  1. Add a drop of Formaldehyde
    OR
  2. Run semen under hot water, which will kill or immobilize.
Rulings cover 9 square millimeters. Boundary lines of the Neubauer ruling are the center lines of the groups of three. (These are indicated in the illustration below.) The central square millimeter is ruled into 25 groups of 16 small squares, each group separated by triple lines, the middle one of which is the boundary. The ruled surface is 0.02 mm below the cover glass, so that the volume over a square millimeter is 0.02 cubic mm. Count all cells within this center square millimeter (1mm x 1mm area).
Neubauer Ruling
Neubauer Ruling
The number of sperm per milliliter (ml) = Number of cells counted X dilution (if used) X 50,000*
*50,000 = 50 (cell depth is 1/50) X 1000 (1000 cubic mm = 1 milliliter)
Cleaning:
After completing the count, remove the cover glass and clean the counting chamber with water or a mild cleaning solution (10% solution of bleach). Dry the counting chamber with a soft cloth or wipe, or rinse with acetone.
上海康稳生物科技有限公司是一家专注于生命科学和生物技术领域的企业,主要从事分子生物学、细胞生物学、免疫学、蛋白组学等实验研究的相关生化试剂、耗材,抗体及仪器的销售,致力于在各个领域内向用户提供世界领先水平和质量稳定的产品,同时也为客户提供相关的实验服务。
上海市徐汇区石龙路818弄11号201室
