动物实验仪器
实验动物心脏起搏器
实验动物心脏起搏器
Animal Pacer
进口
USA
EP 6877
The ‘Animal Pacer’ model EP 6877 is small and lightweight in design for animal use only. Pulse amplitude width and rate are adjustable, which provides high rate pacing up to 460 pulses per min. In the last 10 years, this pacer had successfully been used in pacing-Induced heart failure in the conscious dog and rabbit in USA. The device comes complete with extension cable and myocardial pacing lead.
Operational Specifications for EP6877.pdf EP 6877 Question & Answer.pdf
EP 6877问题的答复:
1.起博器的型号?
EP 6877.
2.起博器是否是外置的?
是外置起博器. 动物先穿一内衣, 起博器用胶带固定在动物肩胛部的内衣外面. 然后再给动物穿一件外衣. 起博器就可以固定得很好了.
3.起博系统是否由导线,起博器,导联线和控制面板4部分组成?临时起博器放置在体外,体内与导线相连,体外与导联线连接.导联线再与控制面板连接?
经手术在动物左心室连一导线(有效极), 地线可连在左心室或胸壁肌肉上. 将此两导线经胸腔皮下引至肩胛部穿出皮肤. 将皮肤外的导线部分缠绕成一团,胶带固定在局部. 待手术伤口愈合后(术后7-10),动物可开始接受心脏起博.
4.能否大致介绍一下起博器的安装流程?
先在上述(3)两根起博线线头上锡焊两个接头(类似于插座与插头),然后将起博器固定好,再将起博线的插头与起博器的插座联好后,即开始起博. 起博器上有三个旋钮,可按需要设定起博的强度,波宽,频率. 起博频率的设定可用PowerLab或任何一种能测量电脉冲频率的仪器完成. 也可用动物的动脉脉搏波来即使监控.起博器上的控制面板没有刻度.
5. 用户情况:
此起博器已在美国成功地用于兔及狗 10 余年, 2007 年开始进入中国市埸。
上海泽生科技开发有限公司引进10 余套 EP 6877 起博器后,成功地应用此起博器建立狗的心衰模型,开展新药研究。
徐州市心血管研究所已签定购买合同, 将应用此起博器建立狗的心衰模型,开展心衰发生发展机理的研究。
Operational Specifications:
Battery requirement: one standard size 9 volt alkaline battery.
Output signal specifications –
Pulse amplitude width and rate are adjustable between the following values:
Signal Amplitude: Max = 8.0 vdc ; Min = 0.8 vdc
Pulse wide: Max =4.msec; Min = 0.2msec
Pulse Rate: Max=460 pulses per min(interval=130msec)
Min=120 pulses per min (interval= 500msec)
Battery life: In excess of 72 days when tested under continuous operation with a 100 ohm load, 1.0 msec pulse width and 300 pulses per min and a fresh battery to an endpoint of 2.8 volts. Output amplitude on day 1 was 8.0 volts DC and 2.8 volts on day 72. Battery life in actual use will vary depending on a variety of conditions, hut should be in excess of 60 days in most cases. The output pulse width and rate did not change over the 72 day test period. Always start a new experiment with a fresh battery. Output voltage will fall during prolonged use, slowly at first, and more rapidly as the battery drains. This causes need for regular monitoring of the animal and perhaps slight adjustments of the output amplitude to ensure the cardiac rhythm remains entrained.
Physical Specifications
Dimensions of polyethylene Case:
Height=6.0 cm; Width=5.3 cm; Depth=2.1 cm
Total Weight (without battery) 26.0 gm
(with battery-Duracell) 70.5gm
Surgical Procedure and Instrumentation
Male dogs weighing 25 to 27 kg were sedated with acepromazine maleate (1 mg/kg IM), anesthetized with sodium pentobarbital (25 mg/kg IV), and ventilated with room air.
A thoracotomy was performed in the left fifth intercostal space. Catheters (Tygon) were placed in the descending thoracic aorta and left atrial appendage for pressure measurements. A third catheter was inserted in the coronary sinus (CS) with the tip leading away from the right atrium.
During the surgery, a blood sample was taken from the CS catheter and immediately measured on a pH/blood gas analyzer. If the PO2 was >25 mm Hg, the catheter was repositioned and tied into place.
A screw-type, unipolar myocardial pacing lead was placed on the left ventricle (LV).
Wires and catheters were run subcutaneously to the intrascapular region, the chest was closed in layers, and the pneumothorax was reduced.
Antibiotics were given after surgery, and the dogs were allowed to fully recover.
After 10 days, dogs were trained to lie quietly on the laboratory table.
Heart Electrodes for rabbits
1. Each Electrode set consists of 1 Black and 1 Red electrode. The black electrode attaches to the heart on the left ventricle with 5-0 or 6-0 cardiovascular suture. Use at least 2 stitches through the mersilene mesh to attach the electrode to the heart muscle points down into the muscle (3 or 4 at opposing corners is best). The red electrode is the indifferent electrode and can be placed on another portion of the left ventricle as far as possible from the black electrode or on a muscle in the chest. Stitch through the loop at 2 separate points to attach the electrode as desired. Stabilize the wires by stitching down the wires to muscle in the chest prior to exiting the wires.
2. The mersilene mesh can be trimmed to fit the rabbit heart. You need to leave enough to stitch to the heart. This size is a surgeon preference.
3. The black electrode will connect to the black wire on the pacer and the red electrode will attach to the red wire on the pacer.
4. After implantation and exit of the electrode wires on the scapular region of the rabbit, solder the male pin to the tip of the black wire and the female socket to the tip of the red wire. Use small shrink tube to cover the solder points and to strengthen the area of pin attachment.
5. Keep excess wire coiled and taped up on the scapular area until ready to attach to the pacer. Keep covered by some manner of jacket otherwise the rabbit WILL chew the wires off.
6. These electrodes are for single use only.
7. Electrodes must be gas sterilized. They will be damaged and unusable if autoclaved or chemically sterilized.
美国健康医疗仪器国际公司AHMSIC于新世纪之初创建于美国纽约,借新世纪之春风快速成长。 AHMSIC是一家专门从事医学科研和临床仪器应用的高科技企业, 志力于心血管,呼吸及神经生理和药理科研仪器的应用:
•心血管-血压,血流,心脏功能及小血管研究: 压力及线性肌动图(Myograph,USA); 光谱成像血流分析仪; 超声血流计,激光血流计, ECGenieTM是唯一的真实地非侵入性地记录神志清楚的小鼠、大鼠和荷兰猪的心电图; 无创小鼠心脏功能及血流动力学动态连续研究系统(Indus Instruments, USA); 无创小动物脉搏血氧仪MouseOx; 精确的尾套法测定血压(USA); 实验动物心脏起搏器; 动物血管封堵器OC Vascular Occluders. 美国肌细胞收缩测定与分析系统Integrated System for Myocyte and SMC Contractility Measurements;
• 神经科学: 行為分析、疼痛研究、脑切片机: 动物行为轨跡-LABORAS &及超音波分析仪-SONOTRACK系統; 新一代振动脑切片机 Compresstome (USA); 动物行为波谱测定仪Behavioral Spectrometer. VCU动物颅脑损伤仪-颅脑创伤模型制作; NYU脊髓冲击损伤仪-脊髓冲击损伤模型制作
• 呼吸研究:CWE生理及呼吸研究仪器; 小动物呼吸机&麻醉系统, CO2 及 O2分析仪, 呼吸及代谢分析系统.
•生理药理和临床教學設備: 美国IWORX产品包括生理学教学设备、网络工具、数据记录主机、信号调节器、各种(ECG、EMG、EEG、PH值及张力、位移、血压、温度等)换能器及附件。在教学方面可以提供全面的人体生理学、动物生理学及心理生理学实验用工具包。在研究方面可以应用于血液动力学、神经系统科学、离体器官和组织试验、药理学等领域。和BIOPAC、POWERLAB并称三大生理研究和教学仪器公司。
•细胞生理:激光扫描,萤光离子,机械牵拉, 電生理:膜片钳放大器, 微量测定一氧化氮NO, 多巴胺, PO2和Dissolved Oxygen , pH, ion, redox, 细胞机械牵拉仪器 STREX - Mechanical Cell Strain Instruments ; 四通道or八通道可编程超微射灌系统; 超微细胞注射泵, 可编程微针拉针器; 显微锻针磨针器
•给药/采样: Alzet 植入式胶囊渗透压泵-- 胶囊大小的滲透压泵植入实验动物皮下或腹腔内, 直接或通过导管以 µl/小时 的速度持续准确地送出測試药剂入作用部位,最長可达6个星期; PE导管(PE10, PE50 & PE60 From USA); 精确可编程序的注射器微量注射泵(USA);
•无创无线遥测: 活动量、体温、心率; VitalView-無線遙測实验动物生理及行为Telemetric Physiological & Behavioral data acquisition system; 無線遙測实验动物Temp., Activity, & Heart Rate; 无创无线遥测心电图 (ECGenie TM, USA);
•低氧研究--Hypoxic Chambers气体O2/CO2/N2自动调控系统; 细胞低氧研究的新工具-镜下温控低氧小室; 高原低氧训练MAG-10.
•运动医学,行为及肥胖研究的最新武器--精确心率,运动量及热卡消耗监测仪.(USA)
•显微外科手术設備: 眼科手术剪(USA). 微型手术镊 (USA), .
• 动物小肠动力学研究-Gastrointestinal Motility Monitor & 膀胱动力学研究--膀胱内压监测系统Mouse Cystometry.
•样品均质:  冷冻细胞粉碎机Frozen Cell Crusher:CRYO-P.
•肥胖,内分泌和代谢研究- EchoMRI 清醒小動物體脂肪水份分析仪.
成都市金牛区一环路北一段88号新熙门2幢624室
028-86653817
400-6762467
