产品说明:
XSP系列显微镜集设计精美、制造精细、操作简便及价格低廉等优点于一身,其放大倍率按需可配置成20X-1600X之间,可供一般农业科研单位及中等学校生物切片观察及实验之用,是中国教委中学生物试验课教材指定的实验工具,是普及生物教学的理想机型。
特点:
1、机械筒长160mm。
2、结构件绝大部分是金属件,经久耐用。
3、三孔转换器可根据观察需要任意切换物镜,定位准确,保证齐焦。
4、采用全国统一设计的185mm消色差物镜,其中40XS、60XS、100XS均为弹簧物镜。
5、装有调焦限位机构,可防止损坏盖(载)玻片和物镜;调焦手轮有松紧调节装置,防止调节中下滑。
6、粗微调焦机构分离;镜臂可45°倾斜,可任意调整观察角度,使观察更加舒适。
7、配有密封性较强,使用便利的工程塑料包装箱。
8、有多种附件可供选择,使其用途更加强大。
Description:
The designs of XSP Series biological microscope is fine, operate simply, Magnification can equip between 20X and 1600X for different demand. It can be used for biological slice observation and experiment of agricultural institutions or middle schools.
Features:
1) Mechanical tube length 160mm.
2) Metal construction body ensures many years use for students.
3) Triple nosepiece can change objectives to view at random.
4) All models adopt three achromatic objectives 4X,10X,40XS.
5) Rack and pinion focusing adjustment with slip clutch mechanism, avoid breaking slides and objectives by careless or overpowered turning.
6) coarse and fine focus mechanism; Arm of these biological microscope can incline up to 45°adjust angle at random to observe comfortably.
7) It equip hermetic and convenient Engineering plastics packing box.
8) There are many accessories , you can choose it by yourself.
