生化试剂
电镀原理 金属离子标液 表面张力测试液
电镀原理 金属离子标液 表面张力测试液
进口
zzstandard
100ML
 主要利用辉光放电(glow discharge)将氩气(Ar)离子撞击靶材(target)表面,
      靶材的原子被弹出而堆积在基板表面形成薄膜。溅镀薄膜的性质、均匀度都比蒸镀薄膜来的好,但是镀膜速度却比蒸镀慢很多。新型的溅镀设备几乎都使用强力磁铁将电子成螺旋状运动以加速靶材周围的氩气离子化,
      造成靶与氩气离子间的撞击机率增加,
      提高溅镀速率。一般金属镀膜大都采用直流溅镀,而不导电的陶磁材料则使用RF交流溅镀,基本的原理是在真空中利用辉光放电。
(部分有毒金属需要确认能否进口!)
日本WAKO原装金属离子标准溶液,ICP-MS/ICP单元素标准溶液
1000ppm等于1g/L
100ppm等于 100mg/L
标准级别:JCSS (Japan Calibration Service System)
WAKO has been qualified as an institution for calibration of standard pH solutions, standard metal solutions and
standard ion solutions (licensed trader) by the Minister of International Trade and Industry and offers the
standard solutions traceable to the National Metrology Standard. This product is provided with a calibration
certificate marked with JCSS to certify that it is traceable to the National Metrology Standard and, at the same
time, attests to the supply of accurate and highly reliable reagent.
UN 2031
英文名       中文名    缩写    浓度    包装
ALUMINIUM    Standard Solution 铝Al 1000ppm    100ML
ALUMINIUM    Standard Solution 铝Al 100ppm       100ML
ANTIMONY     Standard Solution 锑Sb 1000ppm    100ML
ANTIMONY     Standard Solution 锑Sb 100ppm      100ML
BARIUM       Standard Solution 钡Ba 1000ppm    100ML
BERYLLIUM    Standard Solution 铍Be 100ppm      100ML
BISMUTH      Standard Solution 铋Bi 1000ppm     100ML
BORON        Standard Solution 硼B  1000ppm     100ML
CADMIUM      Standard Solution 镉Cd 1000ppm    100ML
CADMIUM      Standard Solution 镉Cd 100ppm      100ML
CALCIUM      Standard Solution 钙Ca 1000ppm    100ML
CERIUM       Standard Solution 铈Ce 1000ppm    100ML
CESIUM       Standard Solution 铯Cs 1000ppm    100ML
CHROMIUM     Standard Solution 铬Cr 1000ppm    100ML
CHROMIUM     Standard Solution 铬Cr 100ppm      100ML
COBALT       Standard Solution 钴Co 1000ppm    100ML
COBALT       Standard Solution 钴Co 100ppm      100ML
COPPER       Standard Solution 铜Cu 1000ppm    100ML
COPPER       Standard Solution 铜Cu 100ppm      100ML
DYSPROSIUM   Standard Solution 镝Dy 1000ppm    100ML
ERBIUM       Standard Solution 铒Er 1000ppm     100ML
EUROPIUM     Standard Solution 铕Eu 1000ppm    100ML
GADOLINIUM   Standard Solution 钆Gd 1000ppm    100ML
GALLIUM      Standard Solution 镓Ga 1000ppm    100ML
GERMANIUM    Standard Solution 锗Ge 1000ppm    100ML
GOLD         Standard Solution 金Au 1000ppm    100ML
HOLMIUM      Standard Solution 钬Ho 1000ppm    100ML
INDIUM       Standard Solution 铟In 1000ppm     100ML
IRON         Standard Solution 铁Fe 1000ppm    100ML
IRON         Standard Solution 铁Fe 100ppm      100ML
LANTHANUM    Standard Solution 镧La 1000ppm    100ML
LEAD         Standard Solution 铅Pb 1000ppm    100ML
LEAD         Standard Solution 铅Pb 100ppm      100ML
LITHIUM      Standard Solution 锂Li 1000ppm    100ML
LUTETIUM     Standard Solution 镥Lu 1000ppm    100ML
MAGNESIUM    Standard Solution 镁Mg 1000ppm    100ML
MAGNESIUM    Standard Solution 镁Mg 100ppm      100ML
MANGANESE    Standard Solution 锰Mn 1000ppm    100ML
MANGANESE    Standard Solution 锰Mn 100ppm      100ML
MOLYBDENUM   Standard Solution 钼Mo 1000ppm    100ML
NEODYMIUM    Standard Solution 钕Nd 1000ppm    100ML
NICKEL       Standard Solution 镍Ni 1000ppm     100ML
NICKEL       Standard Solution 镍Ni 100ppm       100ML
NIOBIUM      Standard Solution 铌Nb 1000ppm    100ML
PALLADIUM    Standard Solution 钯Pd 1000ppm    100ML
PLATINUM     Standard Solution 铂Pt 1000ppm    100ML
POTASSIUM    Standard Solution 钾K  1000ppm     100ML
POTASSIUM    Standard Solution 钾K  100ppm      100ML
PRASEODYMIUM Standard Solution 镨Pr1000ppm    100ML
RHODIUM      Standard Solution 铑Rh 1000ppm    100ML
RUBIDIUM     Standard Solution 铷Rb 1000ppm    100ML
SAMARIUM     Standard Solution 钐Sm 1000ppm    100ML
SCANDIUM     Standard Solution 钪Sc 100ppm      100ML
SELENIUM     Standard Solution 硒Se 1000ppm    100ML
SILICON      Standard Solution 硅Si 1000ppm     100ML
SILVER       Standard Solution 银Ag 1000ppm    100ML
SODIUM       Standard Solution 钠Na 1000ppm    100ML
SODIUM       Standard Solution 钠Na 100ppm      100ML
STRONTIUM    Standard Solution 锶Sr 1000ppm     100ML
TANTALUM     Standard Solution 钽Ta 1000ppm    100ML
TELLURIUM    Standard Solution 碲Te 1000ppm    100ML
TERBIUM      Standard Solution 铽Tb 1000ppm    100ML
THULIUM      Standard Solution 铥Tm 1000ppm    100ML
TIN          Standard Solution 锡Sn 1000ppm    100ML
TITANIUM     Standard Solution 钛Ti 1000ppm    100ML
TUNGSTEN     Standard Solution 钨W  1000ppm    100ML
VANADIUM     Standard Solution 钒V  1000ppm     100ML
YTTERBIUM    Standard Solution 镱Yb 1000ppm    100ML
YTTRIUM      Standard Solution 钇Y 1000ppm    100ML
ZINC         Standard Solution 锌Zn 1000ppm    100ML
ZINC         Standard Solution 锌Zn 100ppm      100ML
ZIRCONIUM    Standard Solution 锆Zr 1000ppm     100ML
      discharge)将氩气(Ar)离子撞击靶材(target)表面,电浆中的阳离子会加速冲向作为被溅镀材的负电极表面,这个冲击将使靶材的物质飞出而沉积在基板上形成薄膜。一般来说,利用溅镀制程进行薄膜披覆有几项特点:(1)金属、合金或绝缘物均可做成薄膜材料。(2)再适当的设定条件下可将多元复杂的靶材制作出同一组成的薄膜。(3)利用放电气氛中加入氧或其它的活性气体,可以制作靶材物质与气体分子的混合物或化合物。(4)靶材输入电流及溅射时间可以控制,容易得到高精度的膜厚。(5)较其它制程利于生产大面积的均一薄膜。(6)溅射粒子几不受重力影响,靶材与基板位置可自由安排。(7)基板与膜的附着强度是一般蒸镀膜的10倍以上,且由于溅射粒子带有高能量,在成膜面会继续表面扩散而得到硬且致密的薄膜,同时此高能量使基板只要较低的温度即可得到结晶膜。(8)薄膜形成初期成核密度高,可生产10nm以下的极薄连续膜。(9)靶材的寿命长,可长时间自动化连续生产。(10)靶材可制作成各种形状,配合机台的特殊设计做更好的控制及最有效率的生产。
真空电镀】的做法现在是一种比较流行的做法,做出来的产品金属感强,亮度高.而相对其他的镀膜法来说,成本较低,对环境的污染小,现在为各行业广泛采用.s9H7D8W.d5Ph上海甄准生物科技有限公司
www.zzstandard.com
电话:021-58979353
传真:021-58979353
客服:15800340161 QQ:648862165
客服:13512172575 QQ:1745420292
客服:13795317828 QQ:2453006496
  一般【真空电镀】的做法是在素材上先喷一层底漆,再做电镀,然后再上面.由于素材是塑料件,在注塑时会残留空气泡,有机气体,而在放置时会吸入空气中的水分.另外,由于塑料表面不够平整,直接电镀的工件表面不光滑,光泽低,金属感差,并且会出现气泡,水泡等不良状况.喷上一层底漆以后,会形成一个光滑平整的表面,并且杜绝了塑料本身存在的气泡水泡的产生,使得电镀的效果得以展现.
  【真空电镀】是将工件装入电镀室内,然后将室内空气抽走,达到一定的真空度后,将室内的钨丝通电加热.当达到一定的温度后,钨丝上所放置的金属丝融化,进而气化,然后随着室内工件的转动均匀的沉积在工件表面,形成金属膜. 一般常见的电镀用金属有铝.镍.铜等等,但由于熔点.工艺控制等方面的原因,镀铝成为最流行的做法.
  【镀膜】完成后,由于金属膜比较容易氧化而导致光泽降低易划伤等问题的产生,所以在镀膜层上面再喷上一层面漆来完成对镀膜的保护.并且在面漆中可添加染料来达到装饰性的效果.涂料,配方, 华润,立邦,BYK,BASF,助剂,油墨, 粉末, 分散剂,流变,辐射固化,色料,颜色,树脂,汽车涂料,工业涂料,丙烯酸涂料,防火涂料;^Jd%b3| Z上海甄准生物科技有限公司
www.zzstandard.com
电话:021-58979353
传真:021-58979353
表面湿润张力测试液(Wetting Tension Test Mixture)
表面湿润张力试验用混合液,用于“塑料薄膜及薄板表面湿润张力试验法”的试剂。塑料薄膜的涂装、涂层、粘附时,要求保留薄膜上的油墨、涂层剂、粘合剂。所显示的这种保留能力将作为表面湿润张力的一种尺度。
表面湿润张力的定义
顺次在塑料薄膜上涂上一系列表面湿润张力不同的混合液,使其恰好湿润薄膜,由此判定混合液表面湿润张力(μN/cm){dyn/cm2}的数值。
单位mN/m表示这种表面湿润张力的数值,相当于品名的NO.。例如NO.31的表面湿润张力是31mN/m (310μN/cm)* dyn/cm=1mN/m (=10μN/cm) (SI单位的统一)
简便的试验方法
用含有试剂的棉棒在试验材料(薄膜)上横向涂抹一次,必需注意涂上的混合液的量会极大影响试验的正确度。涂上试剂后2秒,判定液膜中央部分的状态。当液膜没有产生破裂时,判定为“可润湿”;产生破裂时,判定为“不可润湿”。
货号 品名 包装
235-01791 WETTING TENSION TEST MIXTURE NO.22.6 50ML
238-01801 WETTING TENSION TEST MIXTURE NO.25.4 50ML
235-01811 WETTING TENSION TEST MIXTURE NO.27.3 50ML
232-01821 WETTING TENSION TEST MIXTURE NO.30.0 50ML
239-01831 WETTING TENSION TEST MIXTURE NO.31.0 50ML
236-01841 WETTING TENSION TEST MIXTURE NO.32.0 50ML
233-01851 WETTING TENSION TEST MIXTURE NO.33.0 50ML
230-01861 WETTING TENSION TEST MIXTURE NO.34.0 50ML
237-01871 WETTING TENSION TEST MIXTURE NO.35.0 50ML
234-01881 WETTING TENSION TEST MIXTURE NO.36.0 50ML
231-01891 WETTING TENSION TEST MIXTURE NO.37.0 50ML
234-01901 WETTING TENSION TEST MIXTURE NO.38.0 50ML
231-01911 WETTING TENSION TEST MIXTURE NO.39.0 50ML
238-01921 WETTING TENSION TEST MIXTURE NO.40.0 50ML
235-01931 WETTING TENSION TEST MIXTURE NO.41.0 50ML
232-01941 WETTING TENSION TEST MIXTURE NO.42.0 50ML
239-01951 WETTING TENSION TEST MIXTURE NO.43.0 50ML
236-01961 WETTING TENSION TEST MIXTURE NO.44.0 50ML
233-01971 WETTING TENSION TEST MIXTURE NO.45.0 50ML
230-01981 WETTING TENSION TEST MIXTURE NO.46.0 50ML
237-01991 WETTING TENSION TEST MIXTURE NO.48.0 50ML
234-02001 WETTING TENSION TEST MIXTURE NO.50.0 50ML
231-02011 WETTING TENSION TEST MIXTURE NO.52.0 50ML
238-02021 WETTING TENSION TEST MIXTURE NO.54.0 50ML
235-02031 WETTING TENSION TEST MIXTURE NO.56.0 50ML
232-02041 WETTING TENSION TEST MIXTURE NO.58.0 50ML
239-02051 WETTING TENSION TEST MIXTURE NO.59.0 50ML
236-02061 WETTING TENSION TEST MIXTURE NO.60.0 50ML
233-02071 WETTING TENSION TEST MIXTURE NO.61.0 50ML
230-02081 WETTING TENSION TEST MIXTURE NO.62.0 50ML
237-02091 WETTING TENSION TEST MIXTURE NO.63.0 50ML
230-02101 WETTING TENSION TEST MIXTURE NO.64.0 50ML
237-02111 WETTING TENSION TEST MIXTURE NO.65.0 50ML
234-02121 WETTING TENSION TEST MIXTURE NO.67.0 50ML
231-02131 WETTING TENSION TEST MIXTURE NO.70.0 50ML
238-02141 WETTING TENSION TEST MIXTURE NO.73.0 50ML
  早期的【真空电镀底漆】以热塑性的涂料为主,但一般需要长达2~3个小时的烘烤而使得产能大大的降低.所以在UV涂料开发出来后,这种涂料被迅速的淘汰.现在只有在一些小工厂为了考虑成本的前提下,还有少量的使用.而现在【真空电镀】的主流是UV涂料,具有施工方便,生产效率高,能耗低,污染小等各种优势.
简单来说,电镀指借助外界直流电的作用,在溶液中进行电解反应,使导电体例如金属的表面沉积一金属或合金层。
我们以硫酸铜镀浴作例子:
硫酸铜镀液主要有硫酸铜、硫酸和水,甚至也有其它添加剂。硫酸铜是铜离子(Cu2+)的来源,当溶解于水中会离解出铜离子,铜离子会在阴极(工件)还原(得到电子)沈积成金属铜。这个沉积过程会受镀浴的状况如铜离子浓度、酸碱度(pH)、温度、搅拌、电流、添加剂等影响。
阴极主要反应 : Cu2+(aq) + 2e- → Cu (s)
电镀过程浴中的铜离子浓度因消耗而下降,影响沉积过程。面对这个问题,可以两个方法解决:1.在浴中添加硫酸铜;2.用铜作阳极。添加硫酸铜方法比较麻烦,又要分析又要计算。用铜作阳极比较简单。阳极的作用主要是导体,将电路回路接通。但铜作阳极还有另一功能,是氧化(失去电子)溶解成铜离子,补充铜离子的消耗。
阳极主要反应 : Cu (s) → Cu2+(aq) + 2e-
由于整个镀液主要有水,也会发生水电解产生氢气(在阴极)和氧气(在阳极)的副反应
阴极副反应 : 2H3O+(aq) + 2e- → H2(g) + 2H2O(l)
阳极副反应 : 6H2O(l) → O2(g) + 4H3O+(aq) + 4e-
结果,工件的表面上覆盖了一层金属铜。这是一个典型镀浴的机理,但实际的情况是十分复杂。自催化镀及浸渍镀
更多相关产品,欢迎咨询:
上海甄准生物科技有限公司
甄准,甄心倾听您每一个标准!
杨树彦 手机/QQ:13795317828
杨露   手机/QQ:13917991872
周万庚 手机/QQ:15800340161
电话:021-6840 4353
传真:021-5897 9353
邮箱:yangshuyan@zzstandard.com
地址:上海市浦东新区中科路2635弄61号401室
邮编:201210
网址:http://www.zzstandard.com
上海甄准生物科技有限公司(简称甄准®)专业提供科研试剂产品,主要包括高端化学试剂、生物学试剂、分析标准品、对照品、标准物质等,应用覆盖药物分析领域、食品安全领域、聚合物研究领域、环境监测领域,客户广泛分布于食品、制药、政府机构、第三方检测、环境测试机构、化工、科研院校、生物工程等行业。
上海甄准生物拥有充满活力的团队,持续创新,致力于为客户提供高质量产品和优质的服务。
*企业文化: 用心甄选,追求精准。
*服务理念:真心倾听您每一个标准。
*产品定位:甄准®科研试剂供应商。
*品牌形象:甄准®(代理、经销国外进口原装产品线)、zzstandard®(中药植物提取物产品线)、GlycoSci®(糖/碳水化合物产品线)、IsoReag®(稳定性同位素标记物产品线)。
甄准生物将一如既往,关注您的研发生产项目,为您提供最高性价比产品和服务。
Striving for high quality products and immediate service, we, SHANGHAI ZZBIO CO., LTD, shall do our best to ensure that your experiments and projects will be successful.
Our core business is to supply quality reference standard materials, high purity bio-chem reagents and technical consultancy to laboratories, universities, research institutions, hospitals, pharmaceutical companies, and drug manufacturers. These products can be supplied in quantities from a few milligrams to grams, and even to kilograms.
If you have special requirements, please contact us freely. We have considerable experience in custom-made products and will be very glad to discuss your needs.
上海甄准生物科技有限公司
客服01:13917991872 QQ:3001034031
客服02:13816009161 QQ:3001086693
客服04:15800340161 QQ:3001010259
客服05:19921389057 QQ:3004995018
客服06:18901678489 QQ:3004909899
客服07:13795317828 QQ:3001080377
客服08:13918293035 QQ:3001005926
客服09:13916577892 QQ:3001007248
客服10:13651665725 QQ:3001028570
客服11:19921087069 QQ:3004931168
客服12:18918753302 QQ:3001080321
客服13:18217024652 QQ:3001084617
客服14:15102117276 QQ:3001090745
客服15:19921389125 QQ:3004937757
客服16:15316187026 QQ:3004961006
客服17:18018502489 QQ:3001074579
客服18:13391016096 QQ:3004957527
电话:021-58979353
电话:021-68920155
电话:021-68404353
邮箱:info@zzsrm.com
邮箱:tech@zzbioco.com
地址:上海市闵行区浦江镇三鲁公路3398号国茸1号楼B-506室   邮编:201112
021-68920155-2011
