真空过滤装置主要应用于高效液相色谱流动相过滤、粒子物质分析和微生物污染检测。它们是化学实验室常备器材。选用优质硼酸盐玻璃或316L卫生级不锈钢为材质,可在分析中过滤各种水溶液、有机物和腐蚀性液体,并可进行121℃热压消毒处理。
Vacuum filter holders are used for filtration of mobile phase of HPLC, particulate and microbiological contamination. They are the basic instruments in the chemistry lab. Borosilicate glass or type 316L stainless steel parts are endurable many kinds of aqueous, organic or corrosive liquids for analysis. Also can be autoclavable at 121℃(250℉) for sterilization.
特点:Features
溶剂过滤器:经典设计,使用便捷。
All glass vacuum filter holders: Classical design,they are used conveniently.
胶塞式过滤器:较之于溶剂过滤器,此产品采用胶塞连接,插拔方便,上面的换膜部分还可与多联过滤支架配套使用,组合方式更加多样。
Filtration assembiles: compare with filter holders, these products which join with silicone stopper are easily insert or pull out. Upper portions can connect with vacuume manifold, the combination is more flexible and diversified.
玻璃换膜过滤器:与多联过滤支架配合使用,经济实用。
Glass filter holders: These products can connect with vacuume manifold, economical and practical.
不锈钢换膜过滤器:与多联过滤支架配合使用,较之于玻璃换膜过滤器,此产品经久耐用,无耗损。
Glass filter holders: These products can connect with vacuume manifold. Compare with glass filter holders, they are durable and no damage.
