木聚糖酶检测试剂盒 K-XYLS
品牌:
产品货号:K-XYLS 品牌:Megazyme 产品品名:木聚糖酶检测试剂盒 英文品名:Xylanase (Xylazyme AX) Assay Kit 规格型号:200 assays per kit For the measurement of endo-1,4-?-D-xylanase in enzyme preparations,bread improver mixtures and animal feeds. Contains Xylazyme AX Tabletsand xylanase enzyme controls (A. niger and Trichoderma longibrachiatum). INTRODUCTION: Arabinoxylan is the major endosperm cell-wall polysaccharide of wheat and rye and is found in significant proportions in most cereal solutions and slurries of high viscosity, and in animal nutrition it reduces the rate of nutrient absorption from the gut. endo-β-D-Xylanase (xylanase) is added to feeds to catalyse depolymerisation of this polysaccharide. It can be demonstrated that endo-cleavage by xylanase of just one bond per thousand in the arabinoxylan backbone can significantly remove viscosity properties. Of the carbohydrase enzymes used as feed supplements, one of the most difficult to measure has been xylanase. These problems are attributed to several factors, including the low levels of enzyme added to the feed, inactivation of enzyme during pelleting, binding of the enzyme to feed components and the presence of specific xylanase inhibitors. The only biochemical methods which are sufficiently sensitive, specific and robust to measure xylanase in feeds are viscometric assays and those employing dyed xylan or arabinoxylan polysaccharides. Viscometric assays are tedious, whereas assays employing dyed xylan substrates are rapid, reproducible and simple to perform. We recommend the use of either Xylazyme AX tablets or Azo- Wheat Arabinoxylan (Azo-WAX). Xylazyme AX based assays are about 5-fold more sensitive than assays employing Azo-WAX. However, this latter substrate does have sufficient sensitivity in most applications, and results are slightly more reproducible than with Xylazyme AX. It is generally accepted that xylanase enzymes which are best suited to feed applications have optimal activity at pH 6.0. Consequently, these enzymes are generally assayed at this pH in 100 mM sodium phosphate buffer. In recovery experiments, however, we found that sodium phosphate buffer extracts only a small proportion (< 20%) of the amount of enzyme added to the feed. Thus a wide range of alternative extractants and extraction conditions have been evaluated. For feeds containing Trichoderma sp. xylanases, the best and most consistent results have been obtained using 100 mM acetic acid or 100 mM sodium acetate buffer (pH 4.7) at room temperature. Optimal extraction of Humicola sp. xylanases was achieved with a buffer containing 100 mM MES buffer (pH 6.0) and 1 % w/v sodium dodecyl sulphate (SDS). KITS: Kits containing the required reagents to measure xylanase in animal feeds are available from Megazyme. These kits contain: 1. Xylazyme AX test tablets (200 tablets). 2. A. niger control xylanase (~ 295 mU/mL at 40°C and pH 4.7) in 50 % (v/v) glycerol (activity stated on vial). 3. T. longibrachiatum control xylanase (~ 386 mU/mL at 40°C and pH 6.0) in 50% (v/v) glycerol (activity stated on vial). 爱尔兰Megazyme公司是全球知名的酶及酶法分析试剂盒的生产厂家, 其中大多数产品都被AOAC(Association of Official Analytical Chemists)、 AACC(American Association of Cereal Chemists)、ICC(InternationalAssociation for Cereal Science and Technology)、 EBC(European Brewing Convention)、RACI(Royal Australian Chemical Institute)等国际组织采用。 其中欧洲检测果汁及葡萄酒等发酵产品基本都采用该公司产 品。 其中全线产品及相关检测信息见: 该公司产品分以下系列: 1. 生物及食品酶法分析试剂盒 (Diagnostic Kits) 2. 试剂混合物(Reagent Mixtures) 3. 协同因子(Cofactors) 4. 糖酶片剂试验(Carbohydrase Tablet Tests) 5. 蛋白酶片剂试验(Protease Test Tablets) 6. 可溶性呈色底物(Soluble Chromogenic Substrates) 7. 不可溶性(交联的)呈色底物(Insoluble (Crosslinked) Chromogenic Substrates) 8. 酶(Enzymes) 9. 植物凝血素(Lectins) 10. 多聚糖(Polysaccharides) 11. 低聚糖(Oligosaccharides) 12. 相关产品 (General) 其中产品被国际机构采用,建立国际检测方法如下: 总淀粉检测盒(Total Starch Assay Kit) AOAC Method 996.11 AACC Method 76-13 ICC Standard Method no. 168 RACI Standard Method 总膳食纤维检测盒(Total Dietary Fibre Assay Kit) AOAC Method 985.29 AOAC Method 991.42 AOAC Method 993.19 AOAC Method 991.43 AACC Method 32.07 AACC Method 32.21 AACC Method 32.05 淀粉损失检测盒(Starch Damage Assay Kit) AACC Method 76-31 ICC Standard No. 164 RACI Standard Method α-淀粉酶检测盒Ceralpha (α-Amylase) Assay Kit AOAC Method 2002.01 ICC Standard No. 303 RACI Standard Method CCFRA Flour Testing Working Group Method 0018 AACC - under evaluation. Alpha淀粉酶检测盒Amylazyme (α-Amylase Assay) AACC Method 22.05 RACI Standard Method 果聚糖检测盒Fructan Assay Kit AOAC Method 999.03 AACC Method 32-32 木聚糖酶AX片剂(Xylazyme AX Tablets) Xylazyme AX Tablets have been widely adopted in the fermentation andfeeds industries for the measurement of Xylanase. β-葡聚糖检测盒β-Glucan (Mixed Linkage) Assay Kit AACC Method 32-23 EBC Methods 3.11.1, 4.16.1 and 8.11.1 AOAC Method 995.16 ICC Standard No. 166 RACI Standard Method 极限糊精酶和支链淀粉酶检测片剂(Limit-Dextrizyme) RACI Standard Method β-葡聚糖酶检测盒(β-Glucanase (Malt and Microbial) Assay Kit) RACI Standard Method β-淀粉酶检测盒(Betamyl (β-Amylase Assay Kit)) RACI Standard Method. 木聚糖酶检测底物(Azo-Wheat Arabinoxylan ) Azo-Wheat Arabinoxylan, Azo-CM-Cellulose and Ceralpha methods for theassay of Xylanase, cellulase and ?-Amylase, respectively, have beenadopted by the UK silage industry. 抗性淀粉检测盒(Resistant Starch Assay Kit) AOAC Method 2002.02 温馨提示:需要详细的产品使用说明书,请联系甄准生物客服人员,我们将竭诚为您服务。 甄准,甄心倾听您每一个标准! |
上海甄准生物科技有限公司(简称甄准®)专业提供科研试剂产品,主要包括高端化学试剂、生物学试剂、分析标准品、对照品、标准物质等,应用覆盖药物分析领域、食品安全领域、聚合物研究领域、环境监测领域,客户广泛分布于食品、制药、政府机构、第三方检测、环境测试机构、化工、科研院校、生物工程等行业。
上海甄准生物拥有充满活力的团队,持续创新,致力于为客户提供高质量产品和优质的服务。
*企业文化: 用心甄选,追求精准。
*服务理念:真心倾听您每一个标准。
*产品定位:甄准®科研试剂供应商。
*品牌形象:甄准®(代理、经销国外进口原装产品线)、zzstandard®(中药植物提取物产品线)、GlycoSci®(糖/碳水化合物产品线)、IsoReag®(稳定性同位素标记物产品线)。
甄准生物将一如既往,关注您的研发生产项目,为您提供最高性价比产品和服务。
Striving for high quality products and immediate service, we, SHANGHAI ZZBIO CO., LTD, shall do our best to ensure that your experiments and projects will be successful.
Our core business is to supply quality reference standard materials, high purity bio-chem reagents and technical consultancy to laboratories, universities, research institutions, hospitals, pharmaceutical companies, and drug manufacturers. These products can be supplied in quantities from a few milligrams to grams, and even to kilograms.
If you have special requirements, please contact us freely. We have considerable experience in custom-made products and will be very glad to discuss your needs.
上海甄准生物科技有限公司
客服01:13917991872 QQ:3001034031
客服02:13816009161 QQ:3001086693
客服04:15800340161 QQ:3001010259
客服05:19921389057 QQ:3004995018
客服06:18901678489 QQ:3004909899
客服07:13795317828 QQ:3001080377
客服08:13918293035 QQ:3001005926
客服09:13916577892 QQ:3001007248
客服10:13651665725 QQ:3001028570
客服11:19921087069 QQ:3004931168
客服12:18918753302 QQ:3001080321
客服13:18217024652 QQ:3001084617
客服14:15102117276 QQ:3001090745
客服15:19921389125 QQ:3004937757
客服16:15316187026 QQ:3004961006
客服17:18018502489 QQ:3001074579
客服18:13391016096 QQ:3004957527
电话:021-58979353
电话:021-68920155
电话:021-68404353
邮箱:info@zzsrm.com
邮箱:tech@zzbioco.com
地址:上海市闵行区浦江镇三鲁公路3398号国茸1号楼B-506室 邮编:201112
单位名称: |
联系电话: |
Email: |
