内切纤维素酶检测试剂盒
产品货号:K-CELLG3
品牌:Megazyme
产品品名:内切纤维素酶检测试剂盒
英文品名:endo-Cellulase Assay Kit
规格型号:180/360
A soluble substrate for the specific measurement of cellulase(endo-1,4-β-glucanase) in enzyme preparations and fermentation products.
INTRODUCTION:
Cellulase (endo-1,4-β-glucanase) plays a key role in the hydrolysis
of cellulosic biomass to fermentable sugars. This enzyme also finds
widespread industrial applications in the modification of cellulosic
materials and in the degradation of mixed linkage 1,3;1,4-β-glucans.
Numerous methods are available for the measurement of cellulase,
including those based on increase in reducing sugar levels on
hydrolysis of CM-cellulose or 1,3:1,4-β-glucan1. endo-Cellulase
can be specifically assayed using viscometric methods with soluble
CM-cellulose 7M as substrate, or by employing soluble or insoluble
(crosslinked) dyed cellulose or mixed-linkage β-glucan. In general,
assays based on the use of dyed polysaccharides are standardised
against a reducing sugar method that employs either CM-cellulose or
β-glucan as substrate. The problem here is that these polysaccharide
substrates are not completely defined and thus lead to some variation
in the values obtained.
The Megazyme CellG3, cellulase test reagent, employs high purity
β-glucosidase and benzylidene blocked, 2-chloro-4-nitrophenyl-β-Dcellotrioside
(BClPNPβ-G3). The level of β-glucosidase used ensures
maximum sensitivity of the assay. On hydrolysis of BClPNPβ-G3 to
benzylidene blocked cellobiose and 2-Cl-4-nitrophenyl-β-D-glucose
by cellulase, the 2-Cl-4-nitrophenyl-β-D-glucose is immediately
cleaved to D-glucose and free 2-Cl-4-nitrophenol (ClPNP) by the
β-glucosidase present in the substrate mixture (Scheme 1). Thus, the
rate of release of ClPNP relates directly to the rate of hydrolysis of
BClPNPβ-G3 by cellulase. The reaction is stopped, and the phenolate
colour is developed, on addition of Trizma base solution (pH 9).
Standard curves relating enzyme activity to increase in absorbance
at 400 nm on hydrolysis of BClPNPβ-G3 by Trichoderma and A. niger
cellulases are shown in Figures 1 and 2. A standard curve relating
enzyme activity on CM-cellulose 4M (Nelson/Somogyi reducing
sugar assay2) to absorbance increase at 400 nm on incubation
of Trichoderma cellulase with BClPNPβ-G3 is shown in Figure 3.
Cellulase enzymes from different sources vary in their ability to
hydrolyse BClPNPβ-G3, so it is necessary to establish a specific
standard curve for each cellulase to allow accurate quantitation. The
assay can be used at temperatures up to 80°C and in the pH range of
4.5 to 8.0. With cellulase enzymes with activity at high pH values, it
is necessary to terminate the reaction with tri-sodium phosphate
(pH 11.0).
Of the cellulases evaluated in the current study, that with the lowest
rate of hydrolysis of BClPNPβ-G3 was the cellulase from A. niger
(E-CELAN, Megazyme). BClPNPβ-G3 substrate solution as supplied
in dimethyl sulphoxide (DMSO) is very stable when stored at 4°C or
1
-20°C. The substrate, CellG3 is stable for at least 7 days at 4°C and
for > 2 years at -20°C.
KITS:
Kits suitable for performing 180 / 360 assays are available from
Megazyme. The kits contain the full assay method plus:
Bottle 1: (x2) Benzylidene blocked, 2-chloro-4-nitrophenyl-β-Dcellotrioside
(BClPNPβ-G3; 3 mL) in DMSO.
Stable for > 2 years at -20°C.
Bottle 2: KCl solution (15 mL, 100 mM) plus
sodium azide (0.02% w/v).
Stable for approx. 4 years at 4°C.
Bottle 3: Thermostable β-glucosidase (0.40 mL, 400 U/mL) in
50% w/v ammonium sulphate solution plus sodium
azide (0.02% w/v).
Bottle 4: Trichoderma cellulase standard solution (5 mL,
~ 1.6 U/mL; actual value stated on the vial label) in
50% aqueous glycerol plus sodium azide (0.02% w/v).
Stable for approx. 4 years at -20°C.
温馨提示:需要详细的产品使用说明书,请联系甄准生物客服人员,我们将竭诚为您服务。
甄准,甄心倾听您每一个标准!
上海甄准生物科技有限公司(简称甄准®)专业提供科研试剂产品,主要包括高端化学试剂、生物学试剂、分析标准品、对照品、标准物质等,应用覆盖药物分析领域、食品安全领域、聚合物研究领域、环境监测领域,客户广泛分布于食品、制药、政府机构、第三方检测、环境测试机构、化工、科研院校、生物工程等行业。
上海甄准生物拥有充满活力的团队,持续创新,致力于为客户提供高质量产品和优质的服务。
*企业文化: 用心甄选,追求精准。
*服务理念:真心倾听您每一个标准。
*产品定位:甄准®科研试剂供应商。
*品牌形象:甄准®(代理、经销国外进口原装产品线)、zzstandard®(中药植物提取物产品线)、GlycoSci®(糖/碳水化合物产品线)、IsoReag®(稳定性同位素标记物产品线)。
甄准生物将一如既往,关注您的研发生产项目,为您提供最高性价比产品和服务。
Striving for high quality products and immediate service, we, SHANGHAI ZZBIO CO., LTD, shall do our best to ensure that your experiments and projects will be successful.
Our core business is to supply quality reference standard materials, high purity bio-chem reagents and technical consultancy to laboratories, universities, research institutions, hospitals, pharmaceutical companies, and drug manufacturers. These products can be supplied in quantities from a few milligrams to grams, and even to kilograms.
If you have special requirements, please contact us freely. We have considerable experience in custom-made products and will be very glad to discuss your needs.
上海甄准生物科技有限公司
客服01:13917991872 QQ:3001034031
客服02:13816009161 QQ:3001086693
客服04:15800340161 QQ:3001010259
客服05:19921389057 QQ:3004995018
客服06:18901678489 QQ:3004909899
客服07:13795317828 QQ:3001080377
客服08:13918293035 QQ:3001005926
客服09:13916577892 QQ:3001007248
客服10:13651665725 QQ:3001028570
客服11:19921087069 QQ:3004931168
客服12:18918753302 QQ:3001080321
客服13:18217024652 QQ:3001084617
客服14:15102117276 QQ:3001090745
客服15:19921389125 QQ:3004937757
客服16:15316187026 QQ:3004961006
客服17:18018502489 QQ:3001074579
客服18:13391016096 QQ:3004957527
电话:021-58979353
电话:021-68920155
电话:021-68404353
邮箱:info@zzsrm.com
邮箱:tech@zzbioco.com
地址:上海市闵行区浦江镇三鲁公路3398号国茸1号楼B-506室 邮编:201112
单位名称: |
联系电话: |
Email: |
