发明直流无级温控超精度;
刷新细茵生命周期率;
开创直流培养箱新纪元。
上海市高新技术成果转化项目并有多项发明专利的康曼技CMD产品已经上海市机电产品质量检测中心检验通过,编号:HWT03050,CAL(沪)质监认字(088)号,CMA(2001)量认(沪)字(A0296)号。国家一级查新ISTIS国科证字(008)号,结论为国际先进水平,上海市预防医学研究院检验报告,沪预研(2004)检字第9316号,结果为生长周期比普通培养箱快约4小时,是拥有自主知识产权的企业。
本公司坚守“智能爆炸,理念创新,开拓进取,勇创先河”之宗旨,多年来致力于发明专利产品的研发和孵化,全直流系统成功应用于培养箱系列。康曼技CMD系列CO2、生化、光照培养箱、干燥箱等制冷不用压缩机及氟利昂,制热不用电热丝的全直流无级电子恒温箱,由微电脑自动控制,属于物理类高精度的恒温箱领域。温度波动度±0.1℃,湿度波动度<1%RH,为广泛运用于生物、化学、医学、微电子产品的科学研究,病毒繁殖、细菌培养、微生物、林业、环境科学、畜牧、水产等研究部门提供最理想的精湛卓越的试验设备。
Invent electric stepless temperature control supper accuracy, refresh world biochemistry life circuit rate and develop electric biochemistry foster box new age.
Inventor: Mr. Lichang Cen. Invent name: Electric stepless temperature control box which was formally authorized by National intellectual Property Bureau. Patent number: ZL02110529.4
The Commander products have been tested by Shanghai Electrical Product Quality Test center. Number: HWT03050, CAL (SH) Quality Control (088), CMA (2001) Quality (SH) No (A02696). National 1st Level ISTIS National Science No (008), advance international level, Shanghai Precaution Chemical Research test report, SH precaution research (2004) No 9316. The conclusion is the life circle is 4 hours faster than normal foster box.
With the theme of "intelligent, creative and innovative", our company develops inventing the patent products and successfully used for the foster box series. Commander CMD series foster box, biochemistry, CO2, light to freeze without compressor or freon. The whole electric stepless temperature control box is controlled automatically by computer and within the physical high accuracy stable temperature region. The temperature fluctuate is within +/- 0.1oC and the humidity fluctuate is <1%RH. It is widely used in biochemistry, chemistry, medicine, micro-electrical products, forest, environment scientist, animal, marine lives research institutes to provide the most ideal test equipments.
