干燥箱
上海精宏电热鼓风干燥箱DHG-9023A
上海精宏
DHG-9023A DHG-9053A
【销售电话】:13911142721
上海精宏电热鼓风干燥箱  DHG-9023A DHG-9053A DHG-9123A
DHG-9141A GZP-250 GZP-350 GZP-450
一、用途概述
   供工矿企业、化验室外、科研单位等作干燥、烘焙、熔腊、灭菌之用。
二、产品特点
1 、工作室采用优质钢板或不锈钢板。
2 、微电脑智慧控温仪,具有设定,测定温度双数字显、定时、功率抑制和自整定功能,控温精确可靠。
3 、热风循环系统由低噪声风机和风道组成,工作室内温度均匀。
I.Applications:
It is applicable to such test as drying,cure melt,sterilize in industrial and mining enterprises as well as in laboratory and scientific research institute.
II.Features:
1 、 The working chamber is made of high quality sheet steel or corrosion-restistant stainless steel,safe and easy to use.
2 、 Intelligent temperature controller is based microprocessor with PID parameters controlling function.Digital display of set and actual temperatures. High temperature controlling accuracy and reliability.
3 、 Hot air circulation system is consist of low-noisy fan and optimal air duct, reaching a uniform temperature inside the working chamber
注: ① DHG 型产品均有定时功能,定时范围: 0~9999min ,控温精度 0.1 ℃ , 温度波动 ± 1 ℃ , “ RT” 表示室温 .
② 除 9623A 、 9425A 、 9626A 电源电压为 380V , 50H 外其余均为 220V , 50Hz 。
③ ( A )表示包括带 A 和不带 A 两种型号产品,带 A 为不锈钢工作室带观察窗,不带 A 为镀锌或一般钢板不带观察窗。
Notes: ① DHG Series has timing function. And the range of timing is 0 to 999min. The temperature control precision is 0.1 ℃ . and the temperature fluctuation is ± 1 ℃ ,”RT” stands of room temperature,
② Except main voltage of model 9623A 、 9426A and 9626A are 380V,59Hz, the others are 220v,50Hz.
③ (A)have “A”andnothave“A”. and “A” means stainless steel working chamber, has the window in the door. The not have means zinc or ordinary steel working chamber, has not window.
电热鼓风干燥箱
北京市海淀区圆明园西路2号中国农业大学院内畜牧所西平房2-3
