人 布舍瑞林Buserelin
Human BuserelinCertificate of Analysis and Data Sheet |
| Background : | |
| Buserelin(Receptal) belongs to the group of gonadotrophin releasing hormone (gonadorelin) analogues (LHRH agonist). It acts on the pituitary gland which controls the amount of many different types of hormones (chemical messengers). Buserelin alters the amount of hormones, particularly the oestrogens androgens, this alteration of hormone levels can be exploited to treat cancers of the prostate gland, which are stimulated to grow by testosterone. | |
| Physical Appearance: | |
| Sterile Filtered White lyophilized (freeze-dried) powder. | |
| Formulation: | |
| Lyophilized from a concentrated (1 mg/ml) solution in water containing no additives. | |
| Solubility: | |
| It is recommended to reconstitute the lyophilized Buserelin in sterile 18MΩ-cm H2O not less than 100µg/ml, which can then be further diluted to other aqueous solutions. | |
| Stability: | |
| Lyophilized Buserelin although stable at room temperature for 3 weeks, should be stored desiccated below -18 C. Upon reconstitution Buserelin should be stored at 4 C between 2-7 days and for future use below -18 C. For long term storage it is recommended to add a carrier protein (0.1% HSA or BSA). Please avoid freeze-thaw cycles. | |
| Purity: | |
| Greater than 98.0% as determined by: (a) Analysis by RP-HPLC. (b) Anion-exchange FPLC. (c) Analysis by reducing and non-reducing SDS-PAGE Silver Stained gel. | |
| Amino acid sequence: | |
| Glu-His-Trp-Ser-Tyr-D-Ser(tBu)-Leu-Arg-Pro-NHEt | |
| Endotoxin: | |
| Less than 0.1 ng/µg (IEU/µg) of Buserelin. | |
| Usage: | |
| Prospec's products are furnished for LABORATORY RESEARCH USE ONLY. The product may not be used as drugs, agricultural or pesticidal products, food additives or household chemicals. |
| 单位名称: |
北京市海淀区澄湾街19号院大北农凤凰国际创新园5号楼
| 联系电话: |
| Email: |
