酸度计/PH计
在线溶氧电极、溶解氧电极、DO电极
在线溶氧电极、溶解氧电极、DO电极
DO电极、Do传感器
进口
瑞士汉密尔顿Hamilton
OXYFERM XL溶氧(DO)电极
OXYFERM Dissolved Oxygen Sensors
  • Suitable for steam sterilization, autoclavation and CIP
  • Shaft and membrane have their own serial and melt numbers
  • Sanitary feature: the silicone membrane seals without a gap to steel membrane body (no additional o-ring)
  • Little drift, fast response, short polarization time
  • Thanks to longer service cycles, reduced operating costs
  • Comes with a material and performance test certificate
  • Oxyferm FDA is shipped with a replacement FDA membrane body and electrolyte
  • Replacing the inner glass body is child's play
  • Unique feature: Upside-down insertion is possible when using OXYLYTE USD electrolyte. This is very useful for measurements in near empty tanks or containers. Comes with a material and performance test certificate
  • 12 mm or 25 mm (XL-version) shaft diameter
  • With XL option, the o-ring position “OP” can be optimally matched to the weld-in socket from 22 to 55 mm. Please state the OP you want when ordering. Example: Order number 237175-50 for OP = 50 mm (Sartor ius B. Braun safety sockets) or 237175-25 for standard sockets 237202
  • A selection of membrane materials (Standard, CIP, and FDA membranes) and a selection of differentbody shapes, with a protective edge or rounded (preferred in the case of insertion through the lid from above, so as to prevent gas bubbles collecting) are all available.
OXYFERM Sensors Photo
Simple Cathode Replacement - remove the old cathode assembly with a pull and insert the new assembly.
12 mm OXYFERM FDA 120 with T82/D4 connector
12 mm OXYFERM 120 VP
25mm OXYFERM XL 100 sensor
Ordering Information
Part # Description Shaft Length Shaft Diameter Measuring Range Temp. Range Pressure Range
237450
OXYFERM FDA 120
120 mm
12 mm
10 ppb to saturation or 0.1%...200% air
0...130°C
Up to 4 bar
237400
OXYFERM VP 120
120 mm
12 mm
0...130°C
Up to 4 bar
237455
OXYFERM FDA 160
170 mm
12 mm
0...130°C
Up to 4 bar
237452
OXYFERM FDA 225
210 mm
12 mm
0...130°C
Up to 4 bar
237401
OXYFERM VP 225
210 mm
12 mm
0...130°C
Up to 4 bar
237453
OXYFERM FDA 325
325 mm
12 mm
0...130°C
Up to 4 bar
237402 OXYFERM VP 325 325 mm 12 mm 10 ppb to saturation or 0.1%...200% air 0...130°C Up to 4 bar
237175-OP OXYFERM XL 100* 100 mm 25 mm 10 ppb to saturation or 0.1%...200% air 0...130°C Up to 4 bar
*OP indicates the o-ring position must be specified during ordering.
MEMBRANE KITS, ELECTROLYTE , REPLACEMENT CATHODE & POLARIZATION MODULES
237123 OXYFERM MEMBRANE KIT
3 Membranes, Oxylyte, pipette, O-rings, polishing strip
237126 MEMBRANE KIT CIP
As above but with a special membrane for intensive CIP
237140 MEMBRANE KIT for OXYFERM FDA
As above but with FDA certified membrane material, without membrane protection collar
237306 Replacement Oxyferm Cathode/Anode assembly
237118 OXYLYTE electrolyte for OXYFERM sensors (50 mL)
237136 OXYLYTE USD electrolyte for OXYFERM sensors mounted upside down (50 mL)
237350 Polarization Module (for OXYFERM VP sensors only)
237370 Polarization Module (for OXYFERM with T82/D4 connector)
237137 Autoclaving Cap
北京恩耐德科技有限公司是一家从事建筑材料、机械、化工、科学仪器、电 子产品为一体的高科技公司。公司集科研、销售、技术咨询与服务于一体,在石 油化工、石油天然气、水利、电力、工业与民用建筑、水及污水处理、实验室、化工与冶金等诸多行业中,我们都可提供高品质的产品及周到、细致的服务。公司主营业务有:建筑材料,装饰材料,自动加药系统和配套产品,水质分析仪器仪表,气体分析仪器仪表,其中包括一体化自动加药装置、简易自动加药系统、自动监测仪器和自动控制仪器、加药泵、计量泵、加药搅拌机、加药桶及底阀、注射阀、背压阀、安全阀、Y型过滤器、脉冲阻尼器、液位开关、流量计等管道配件,PH/ORP在线控制仪,电导(EC)率控制器,余氯在线监测仪表,溶氧(DO)在线监测,酸度计,以及实验室用水质监测系统,汉密尔顿电极,电磁气泵等。
主要代理品牌:
瑞士汉密尔顿电极:生物发酵电极,PH传感器,ORP电极,Do传感器,啤酒溶氧电极,光学溶氧电极。
美国爱默森仪表:罗斯蒙特PH/ORP控制器,罗斯蒙特电导率/电阻率仪表,罗斯蒙特溶氧控制器。
意大利赛高SEKO:电磁计量泵、机械隔膜计量泵、柱塞式计量泵、一体化加药装置、加药桶及底阀、注射阀、背压阀、安全阀、Y型过滤器、脉冲阻尼器、液位开关、触点流量计等管道配件。
德国普罗名特prominent:电磁气泵,电磁式计量泵、精密计量泵、防爆计量泵、微型计量泵、气动计量泵、机械隔膜式计量泵、液压隔膜式计量泵、柱塞计量泵、加药桶及底阀、注射阀、背压阀、安全阀、Y型过滤器、脉冲阻尼器、液位开关、触点流量计等管道配件、PH控制器、电导控制器、溶氧控制器、余氯控制器、一体化加药装置、加药系统。
美国帕斯菲达:电磁隔膜计量泵、机械隔膜计量泵。
美国米顿罗Milton Roy计量泵:A、H、P系列电磁驱动隔膜计量泵、B、C系列电磁驱动隔膜计量泵、G系列系列电机驱动机械隔膜计量泵。
日本易威奇IKAKI:磁力泵、计量泵、化工泵。
台湾上泰SUNTEX:PH计、酸度计、电导率仪、EC测试仪、溶氧仪、DO测定仪、余氯测试仪。
台湾三亚SANYA:可搬型搅拌机、液体搅拌机、低速搅拌机、齿轮搅拌机、行星搅拌机、高速搅拌机、立式搅拌机
美国FTI插桶泵:高性能无泄露桶泵、中等粘度溶剂桶泵、中低粘度桶泵、中低粘度漂白领域桶泵、高粘度桶泵、高粘度螺杆型桶泵。
美国固瑞克(Garco)气动隔膜泵: HUSKY205塑料泵系列、HUSKY307塑料泵系列、HUSKY515塑料泵系列、HUSKY716金属泵系列、HUSKY1040金属泵系列、HUSKY1040塑料泵系列、HUSKY1590金属泵系列、HUSKY1590塑料泵系列、HUSKY2150金属泵系列、HUSKY2150塑料泵系、HUSKY2150金属泵系列。
德国弗尔德VERDER:VA系列气动隔膜泵、VF系列软管蠕动泵。
崇文区左安门内大街左安漪园5-3-704
