试管和离心管
Beckman贝克曼 离心管250ml 356011
进口
美国Beckman贝克曼
产品特点:
品牌:贝克曼库尔特
所属分类:高速离心管
类型:宽口离心瓶
包装规格:6个
容量:250ml
尺寸(直径X高 mm):62 x 120
适用转头:JLA-16.250, JA-14, JLA-10.500, JA-10, JLA-9.1000, JLA-8.1000,JS-7.5, JS-5.2, JS-4.3, JS-4.2, JS-4.2A, JS-4.0, JS-3.0
材质:聚丙烯
透明度:半透明
贝克曼 beckman 毛细管试剂耗材
序号 货号(P/N) 产品描述
1 144390 36 Position Buffer Tray
2 144430 UV Filter 200 nm
3 144431 UV Filter 210 nm
4 144432 UV Filter 220 nm
5 144433 UV Filter 230 nm
5 608105 Fragment Analysis Test Sample
6 144434 UV Filter 260 nm
7 144435 UV Filter 300 nm
8 144436 UV Filter 340 nm
9 144437 UV Filter 214 nm
10 144438 UV Filter 254 nm
11 144439 UV Filter 280 nm
12 144543 48 Position Sample Tray 2 ml Vial
13 144544 48 Position Sample Tray 0.5 ml Vial
14 144645 Cartridge Rebuild Kit
15 144647 Coolant Fill Tool
16 144648 Vial Caps 2 ml - 100 Pack
17 144649 Vial Caps 0.5 ml - 50 Pack
18 144656 PCR Vial Caps 2 ml - 50 Pack
19 144657 Vial Holder - 50 Pack
20 144672 Electrode Replacement Kit
21 144689 Cartridge Tubing Kit
22 144709 PCR Microvials - 100 Pack
23 144711 Aperture 100 x 800 um - 3 Pack
24 144712 Aperture 100 x 200 um - 3 Pack
25 144717 Cartridge Tubing Kit 100 cm
26 144738 Standard Capillary Cartridge Assembly
27 144824 BUFFER RESERVOIR ACCESS KIT
29 144829 External Detector Adaptor (EDA) Cartridge Assembly Kit
30 144834 External Detector Adaptor (EDA) Tubing Kit
32 144865 O-Ring Buffer Reservoir Replacement - 4 Pack
33 144866 Replacement Cartridge Clip with Double Seal - 4 Pack
34 144873 Replacement Cartridge Clip with Single Seal - 4 Pack
35 144940 Filter Emission Band Pass 520 nm
36 144941 Filter Notch LIF 488 nm
37 144942 Filter Emission Band Pass 655 nm
38 144980 Glass Vial 2 ml
39 149044 Capillary Cartridge CE-MS (White)
40 149053 Traditional CE-MS Interface Capillary - 3 Pack
41 149068 Filter Emission Band Pass 560 nm
42 285441 GEXP (ONE RAIL) SEQ START-UP-PAC
43 285489 GEXP (ONE RAIL) FA START-UP-PAC
44 338424 Capillary Regenerator Solution A
45 338426 Capillary Run Buffer A
46 338437 Capillary Performance Test Kit
47 338451 Pre-cut Bare Fused Silica Capillary 50 um x 67 cm - 3 Pack
48 338454 Pre-cut Bare Fused Silica Capillary 75 um x 50 cm - 3 Pack
49 338472 Untreated Bare Fused Silica Capillary 50 um x 5 m
50 338473 Untreated Bare Fused Silica Capillary 75 um x 5 m
51 338474 Untreated Bare Fused Silica Capillary 100 um x 5 m
52 338475 Untreated Bare Fused Silica Capillary 20 um x 27 cm - 3 Pack
53 358821 Spring Micro Vial - 10 Pack
54 359976 Capillary Cartridge Coolant 450 ml
55 360800 Traditional CE-MS Interface Capillary 75 um x 111 cm - 3 Pack
56 360801 Traditional CE-MS Interface Capillary 50 um x 111 cm - 3 Pack
57 360804 Extended-Length Capillary (eCAP) 20 um x 5 m
58 390904 CEQ-8800 BUFFER EVAPORATION COVER
59 390953 SDS-MW Analysis Kit
60 391438 Separation Gel 20 ml
61 391734 IgG Control Standard - 3 Pack
62 477409 eCAP EnhanCE Dye 0.5 mL
63 477410 dsDNA 1000 KIT
64 477422 eCAP Phosphate Buffer 50.0 mM pH 2.5 100 ml
65 477427 eCAP Tris Buffer 50.0 mM pH 8.0 100 ml
66 477431 eCAP Amine Coated Capillary
67 477441 Neutral Coated Capillary 50 um x 67 cm
68 477445 Protein Methods Development Kit
69 477477 eCAP DNA Capillary 100 um ID 65 cm
70 477480 eCAP ssDNA 100-R Kit
71 477497 cIEF Gel Polymer Solution 100 ml
72 477600 Carbohydrate Labeling & Analysis Kit
73 477601 N-CHO Coated Capillary 50 um x 65 cm
74 477623 N-Linked Carbohydrate Separation Buffer
75 501309 Labeling Dye (APTS) 2 x 5 mg
76 501310 P/ACE MDQ Plus Method Development Kit
77 501333 P/ACE MDQ Performance Test Mix B
78 607445 Wetting Tray - Retainer Version
79 607533 Evaporation Control Mat
80 608010 Separation Gel 10 ml
81 608012 GenomeLab Separation Buffer - 4 Pack
82 608070 SEQUENCING TEST SAMPLE
83 608074 Sequencing Reaction Buffer
84 608082 Sample Loading Solution
85 608087 DNA SEP CAP ARRAY 33-75B
86 608095 DNA Size Standard Kit 600 bp
87 608098 DNA Size Standard Kit 400 bp
89 608120 DTCS QUICK START KIT
90 608145 D4-PA KIT, 0.1G
91 608146 D3- PA KIT 0.1G
92 608147 D2- PA KIT 0.1G
93 608395 DNA Size Standard 80 BP
94 609801 Sample Microtiter Plate - 25 Pack
95 609844 Buffer Microplates, 96-Well Nonsterile - 100 Pack
96 713333 Capillary Conditioning Solution
97 713350 Highly Sulfated Gamma Cyclodextrin Kit 5 ml
98 721125 LIF Cartridge Aperture Plug Assembly
99 725898 APTS-M Extra Purified for Monosaccharide Analysis 20 mg
100 969114 GEXP FRAGMENT ANALYSIS START-UP PAC
101 969115 GEXP SNP START-UP PAC
102 969118 GEXP (ONE RAIL) SNP START-UP-PAC
103 969133 GEXP (SEQ & FA) START-UP PAC
104 969134 GEXP (ONE RAIL) SEQ & FA START-UP-PAC
105 970297 O-Ring for Aperature
106 970668 Vial 0.5 ml - 50 Pack
107 974705 Plastic Waste Bottle 250 ml - 12 Pack
108 5043467 NanoVials - 100 Pack
109 A10308 IGG PURITY/HET ASSAY PART 1 OF 2
110 A10663 IgG Purity/Heterogeniety Assay Kit
111 A20100 HUMAN STR PRIMER SET KIT
112 A22196 Molecular Weight Sizing Standard - 3 Pack
113 A23201 GENOMELAB SNPSTART PRIMER EXTENSION KIT
114 A26487 10kDa Internal Standard
115 A30341 SDS-MW Gel Buffer
116 A36465 GEXP GENE EXPRESSION START-UP-PAC
117 A36466 GENOMELAB GEXP (ONE RAIL) INSTALLATION AND TRAINING PACKAGE
118 A37326 Open Bore Vial Cap, White
119 A47775 Electrode Assembly
120 A47922 Cartridge Plug & Clip Kit, Plugged
121 A50924 Highly Sulfated Gamma Cyclodextrin Kit 30 ml
122 A52078 GENOMELABTM GEXP HUMAN REFERENCE PLEX KIT SALES GROUP
123 A53537 Anion Analysis Kit
124 A53540 Cation Analysis Kit
125 A58481 cIEF Peptide Marker Kit
126 A59494 Packaged Laser Module Upgrade (Single Color) Kit 488 nm
127 A59525 Electrode Tool Assembly
128 A61216 External Detector Adapter Kit
129 A62250 Universal Vial Caps - 100 Pack
130 A62251 Universal Vials - 100 Pack
131 A71837 GENOMELAB? GEXP SEQUENCING START-UP-PAC SALES GROUP
132 A80976 Advanced cIEF Starter Kit
133 A85017 GENOMELAB GEXP START KIT, LUO
134 A85022 THERMO-START TAQ DNA POLYMERASE KIT, LUO
135 A94461 Sample Vial Tray 6 x 8
136 A94462 Buffer Vial Tray 6 x 6
137 B07363 OptiMS Adapter for SCIEX Nanospray III Source
138 B07366 OptiMS Adapter for Thermo Nanospray II MS Source
139 B07367 Silica Surface OptiMS Cartridge
140 B07368 Neutral OptiMS Surface Cartridge
141 B11648 CESI Vial - 100 Pack
142 B24699 CESI Vial Cap - 100 Pack
143 B68372 PhotoDiode Array Detector Upgrade Kit
144 A79661 PA 800 & P/ACE MDQ Molded Vial - 100 Pack
145 477490 ECAP CIEF 3-10 KIT
146 477621 Gel Kit ssDNA 100-R
147 A55625 Pre-Assembled Capillary Cartridge
148 B83386 OptiMS Adapter for Thermo Nanospray Flex / NG Ion Source
149 391809 IGG PURITY/HET ASSAY PART 2 OF 2
150 969136 IEF UPGRADE MODULE FOR THE PA 800 AND PA 800 PLUS SERIES
151 477628 eCAP dsDNA 1000 Gel Kit - 3 Pack
152 B94499PTO Fast Glycan Labeling and Analysis Kit
153 A11147 CAPILLARY, CARTRIDGE PA800-30CM
154 477414 eCAP dsDNA 1000 Test Mix
155 726022 LIF Performance Test Mix
183 608114 Mineral Oil
江苏科器成立于一九六三年,隶属于江苏省科技厅,是一个有着超过五十年经营国内外科研器材﹑精密仪器的专业公司,公司具有自营和代理各类商品和技术的进出口权。2005年公司根据省政府有关文件,在省科技厅的直接领导下,整体改制成为股份制公司.
这五十多年来,公司本着诚实守信﹑团结协作﹑开拓创新﹑勇于争先的精神和宗旨,为科研院所﹑大专院校﹑大中型企业﹑医院等单位,提供各种进口﹑国产的科研器材﹑教学仪器等专业设备和技术服务,为促进我省的科学技术发展作出了应有的贡献,受到广大用户的一致好评,得到了省政府的嘉奖,并荣获江苏省精神文明称号.
目前公司主要经营的品种有:分析仪器、光学仪器、电化学仪器、计量仪器、物性测试、环境监测、生命科学、实验室仪器、药物检测仪器。主要国外品牌有日本岛津Shimadzu﹑日本岛津技迩Shimadzu-gl﹑美国贝克曼Beckman﹑美国爱博才思SCIEX、瑞士梅特勒Mettler Toledo﹑德国艾卡IKA﹑美国密理博Millipore﹑德国美墨尔特Memmert﹑德国艾本德Eppendorf、奥地利安东帕Anton Paar、美国热电Thermo、美国戴安Dionex、瑞士步琪Buchi等品牌,用户遍及省内外各大科研院所﹑大专院校﹑电力﹑电子﹑石油﹑化工﹑环保﹑轻工等许多相关领域。
公司经营这五十多年来,始终坚持为用户提供优质商品﹑优惠价格和优良服务,所售产品主要来源于国内外一流品牌的仪器仪表生产企业上。多年来公司注重人才的培养,现拥有一支富有经验﹑懂技术的高素质专业队伍。在科学技术迅猛发展的今天,公司将一如既往,再接再励,携全体员工共同开创美好的明天。
江苏省南京市栖霞区纬地路9号江苏生命科技创新园B3幢
1483923011/2603776813
