Beckman 扩增纯化试剂A63880 A63881 A63882
产品特征: 200bp以上的核酸回收率高达90%以上,核酸长度*小要求100bp |
beckman磁珠A63880/A63881/A63882现货 Agencourt AMPure XP -核酸纯化试剂盒 该试剂盒应用于: PCR体系纯化、酶切和连接反应体系纯化 产物适合于下游应用:PCR、Genotyping(SNP detection)、sequencing(Sanger and Next Generation Sequencing)、Cloning、Primer Walking纯化产物得率高 Agencourt AMPure XP可以结合大于100bp的核酸片段,对于片段长度为10KB的长片段,也能获得比传统过柱法高得多的得率。 ![]() 图1:经过3种纯化试剂纯化后的产物得率对比:分别是200bp、800bp和10KB,纯化所用的试剂分别为Agencourt AMPure XP、QIAquick 和QuickStep 过柱法纯化试剂盒。 |
操作过程:
1. 加入AMPure XP 磁珠试剂
2. 磁珠与核酸结合
3. 结合有核酸的磁珠与杂质分离
4. 乙醇洗涤
5. 加入洗脱液
6. 转移洗脱产物
订购信息:
| 产品 | 试剂盒组成 | 货号 |
| Agencourt AMPure XP 5 mL Kit | Agencourt AMPure XP Reagent | A63880 |
| Agencourt AMPure XP 60 mL Kit | Agencourt AMPure XP Reagent | A63881 |
| Agencourt AMPure XP 450 mL Kit | Agencourt AMPure XP Reagent | A63882 |
贝克曼 beckman 毛细管试剂耗材
| 序号 | 货号(P/N) | 产品描述 |
| 1 | 144390 | 36 Position Buffer Tray |
| 2 | 144430 | UV Filter 200 nm |
| 3 | 144431 | UV Filter 210 nm |
| 4 | 144432 | UV Filter 220 nm |
| 5 | 144433 | UV Filter 230 nm |
| 5 | 608105 | Fragment Analysis Test Sample |
| 6 | 144434 | UV Filter 260 nm |
| 7 | 144435 | UV Filter 300 nm |
| 8 | 144436 | UV Filter 340 nm |
| 9 | 144437 | UV Filter 214 nm |
| 10 | 144438 | UV Filter 254 nm |
| 11 | 144439 | UV Filter 280 nm |
| 12 | 144543 | 48 Position Sample Tray 2 ml Vial |
| 13 | 144544 | 48 Position Sample Tray 0.5 ml Vial |
| 14 | 144645 | Cartridge Rebuild Kit |
| 15 | 144647 | Coolant Fill Tool |
| 16 | 144648 | Vial Caps 2 ml - 100 Pack |
| 17 | 144649 | Vial Caps 0.5 ml - 50 Pack |
| 18 | 144656 | PCR Vial Caps 2 ml - 50 Pack |
| 19 | 144657 | Vial Holder - 50 Pack |
| 20 | 144672 | Electrode Replacement Kit |
| 21 | 144689 | Cartridge Tubing Kit |
| 22 | 144709 | PCR Microvials - 100 Pack |
| 23 | 144711 | Aperture 100 x 800 um - 3 Pack |
| 24 | 144712 | Aperture 100 x 200 um - 3 Pack |
| 25 | 144717 | Cartridge Tubing Kit 100 cm |
| 26 | 144738 | Standard Capillary Cartridge Assembly |
| 27 | 144824 | BUFFER RESERVOIR ACCESS KIT |
| 29 | 144829 | External Detector Adaptor (EDA) Cartridge Assembly Kit |
| 30 | 144834 | External Detector Adaptor (EDA) Tubing Kit |
| 32 | 144865 | O-Ring Buffer Reservoir Replacement - 4 Pack |
| 33 | 144866 | Replacement Cartridge Clip with Double Seal - 4 Pack |
| 34 | 144873 | Replacement Cartridge Clip with Single Seal - 4 Pack |
| 35 | 144940 | Filter Emission Band Pass 520 nm |
| 36 | 144941 | Filter Notch LIF 488 nm |
| 37 | 144942 | Filter Emission Band Pass 655 nm |
| 38 | 144980 | Glass Vial 2 ml |
| 39 | 149044 | Capillary Cartridge CE-MS (White) |
| 40 | 149053 | Traditional CE-MS Interface Capillary - 3 Pack |
| 41 | 149068 | Filter Emission Band Pass 560 nm |
| 42 | 285441 | GEXP (ONE RAIL) SEQ START-UP-PAC |
| 43 | 285489 | GEXP (ONE RAIL) FA START-UP-PAC |
| 44 | 338424 | Capillary Regenerator Solution A |
| 45 | 338426 | Capillary Run Buffer A |
| 46 | 338437 | Capillary Performance Test Kit |
| 47 | 338451 | Pre-cut Bare Fused Silica Capillary 50 um x 67 cm - 3 Pack |
| 48 | 338454 | Pre-cut Bare Fused Silica Capillary 75 um x 50 cm - 3 Pack |
| 49 | 338472 | Untreated Bare Fused Silica Capillary 50 um x 5 m |
| 50 | 338473 | Untreated Bare Fused Silica Capillary 75 um x 5 m |
| 51 | 338474 | Untreated Bare Fused Silica Capillary 100 um x 5 m |
| 52 | 338475 | Untreated Bare Fused Silica Capillary 20 um x 27 cm - 3 Pack |
| 53 | 358821 | Spring Micro Vial - 10 Pack |
| 54 | 359976 | Capillary Cartridge Coolant 450 ml |
| 55 | 360800 | Traditional CE-MS Interface Capillary 75 um x 111 cm - 3 Pack |
| 56 | 360801 | Traditional CE-MS Interface Capillary 50 um x 111 cm - 3 Pack |
| 57 | 360804 | Extended-Length Capillary (eCAP) 20 um x 5 m |
| 58 | 390904 | CEQ-8800 BUFFER EVAPORATION COVER |
| 59 | 390953 | SDS-MW Analysis Kit |
| 60 | 391438 | Separation Gel 20 ml |
| 61 | 391734 | IgG Control Standard - 3 Pack |
| 62 | 477409 | eCAP EnhanCE Dye 0.5 mL |
| 63 | 477410 | dsDNA 1000 KIT |
| 64 | 477422 | eCAP Phosphate Buffer 50.0 mM pH 2.5 100 ml |
| 65 | 477427 | eCAP Tris Buffer 50.0 mM pH 8.0 100 ml |
| 66 | 477431 | eCAP Amine Coated Capillary |
| 67 | 477441 | Neutral Coated Capillary 50 um x 67 cm |
| 68 | 477445 | Protein Methods Development Kit |
| 69 | 477477 | eCAP DNA Capillary 100 um ID 65 cm |
| 70 | 477480 | eCAP ssDNA 100-R Kit |
| 71 | 477497 | cIEF Gel Polymer Solution 100 ml |
| 72 | 477600 | Carbohydrate Labeling & Analysis Kit |
| 73 | 477601 | N-CHO Coated Capillary 50 um x 65 cm |
| 74 | 477623 | N-Linked Carbohydrate Separation Buffer |
| 75 | 501309 | Labeling Dye (APTS) 2 x 5 mg |
| 76 | 501310 | P/ACE MDQ Plus Method Development Kit |
| 77 | 501333 | P/ACE MDQ Performance Test Mix B |
| 78 | 607445 | Wetting Tray - Retainer Version |
| 79 | 607533 | Evaporation Control Mat |
| 80 | 608010 | Separation Gel 10 ml |
| 81 | 608012 | GenomeLab Separation Buffer - 4 Pack |
| 82 | 608070 | SEQUENCING TEST SAMPLE |
| 83 | 608074 | Sequencing Reaction Buffer |
| 84 | 608082 | Sample Loading Solution |
| 85 | 608087 | DNA SEP CAP ARRAY 33-75B |
| 86 | 608095 | DNA Size Standard Kit 600 bp |
| 87 | 608098 | DNA Size Standard Kit 400 bp |
| 89 | 608120 | DTCS QUICK START KIT |
| 90 | 608145 | D4-PA KIT, 0.1G |
| 91 | 608146 | D3- PA KIT 0.1G |
| 92 | 608147 | D2- PA KIT 0.1G |
| 93 | 608395 | DNA Size Standard 80 BP |
| 94 | 609801 | Sample Microtiter Plate - 25 Pack |
| 95 | 609844 | Buffer Microplates, 96-Well Nonsterile - 100 Pack |
| 96 | 713333 | Capillary Conditioning Solution |
| 97 | 713350 | Highly Sulfated Gamma Cyclodextrin Kit 5 ml |
| 98 | 721125 | LIF Cartridge Aperture Plug Assembly |
| 99 | 725898 | APTS-M Extra Purified for Monosaccharide Analysis 20 mg |
| 100 | 969114 | GEXP FRAGMENT ANALYSIS START-UP PAC |
| 101 | 969115 | GEXP SNP START-UP PAC |
| 102 | 969118 | GEXP (ONE RAIL) SNP START-UP-PAC |
| 103 | 969133 | GEXP (SEQ & FA) START-UP PAC |
| 104 | 969134 | GEXP (ONE RAIL) SEQ & FA START-UP-PAC |
| 105 | 970297 | O-Ring for Aperature |
| 106 | 970668 | Vial 0.5 ml - 50 Pack |
| 107 | 974705 | Plastic Waste Bottle 250 ml - 12 Pack |
| 108 | 5043467 | NanoVials - 100 Pack |
| 109 | A10308 | IGG PURITY/HET ASSAY PART 1 OF 2 |
| 110 | A10663 | IgG Purity/Heterogeniety Assay Kit |
| 111 | A20100 | HUMAN STR PRIMER SET KIT |
| 112 | A22196 | Molecular Weight Sizing Standard - 3 Pack |
| 113 | A23201 | GENOMELAB SNPSTART PRIMER EXTENSION KIT |
| 114 | A26487 | 10kDa Internal Standard |
| 115 | A30341 | SDS-MW Gel Buffer |
| 116 | A36465 | GEXP GENE EXPRESSION START-UP-PAC |
| 117 | A36466 | GENOMELAB GEXP (ONE RAIL) INSTALLATION AND TRAINING PACKAGE |
| 118 | A37326 | Open Bore Vial Cap, White |
| 119 | A47775 | Electrode Assembly |
| 120 | A47922 | Cartridge Plug & Clip Kit, Plugged |
| 121 | A50924 | Highly Sulfated Gamma Cyclodextrin Kit 30 ml |
| 122 | A52078 | GENOMELABTM GEXP HUMAN REFERENCE PLEX KIT SALES GROUP |
| 123 | A53537 | Anion Analysis Kit |
| 124 | A53540 | Cation Analysis Kit |
| 125 | A58481 | cIEF Peptide Marker Kit |
| 126 | A59494 | Packaged Laser Module Upgrade (Single Color) Kit 488 nm |
| 127 | A59525 | Electrode Tool Assembly |
| 128 | A61216 | External Detector Adapter Kit |
| 129 | A62250 | Universal Vial Caps - 100 Pack |
| 130 | A62251 | Universal Vials - 100 Pack |
| 131 | A71837 | GENOMELAB? GEXP SEQUENCING START-UP-PAC SALES GROUP |
| 132 | A80976 | Advanced cIEF Starter Kit |
| 133 | A85017 | GENOMELAB GEXP START KIT, LUO |
| 134 | A85022 | THERMO-START TAQ DNA POLYMERASE KIT, LUO |
| 135 | A94461 | Sample Vial Tray 6 x 8 |
| 136 | A94462 | Buffer Vial Tray 6 x 6 |
| 137 | B07363 | OptiMS Adapter for SCIEX Nanospray III Source |
| 138 | B07366 | OptiMS Adapter for Thermo Nanospray II MS Source |
| 139 | B07367 | Silica Surface OptiMS Cartridge |
| 140 | B07368 | Neutral OptiMS Surface Cartridge |
| 141 | B11648 | CESI Vial - 100 Pack |
| 142 | B24699 | CESI Vial Cap - 100 Pack |
| 143 | B68372 | PhotoDiode Array Detector Upgrade Kit |
| 144 | A79661 | PA 800 & P/ACE MDQ Molded Vial - 100 Pack |
| 145 | 477490 | ECAP CIEF 3-10 KIT |
| 146 | 477621 | Gel Kit ssDNA 100-R |
| 147 | A55625 | Pre-Assembled Capillary Cartridge |
| 148 | B83386 | OptiMS Adapter for Thermo Nanospray Flex / NG Ion Source |
| 149 | 391809 | IGG PURITY/HET ASSAY PART 2 OF 2 |
| 150 | 969136 | IEF UPGRADE MODULE FOR THE PA 800 AND PA 800 PLUS SERIES |
| 151 | 477628 | eCAP dsDNA 1000 Gel Kit - 3 Pack |
| 152 | B94499PTO | Fast Glycan Labeling and Analysis Kit |
| 153 | A11147 | CAPILLARY, CARTRIDGE PA800-30CM |
| 154 | 477414 | eCAP dsDNA 1000 Test Mix |
| 155 | 726022 | LIF Performance Test Mix |
| 183 | 608114 | Mineral Oil |
江苏科器成立于一九六三年,隶属于江苏省科技厅,是一个有着超过五十年经营国内外科研器材﹑精密仪器的专业公司,公司具有自营和代理各类商品和技术的进出口权。2005年公司根据省政府有关文件,在省科技厅的直接领导下,整体改制成为股份制公司.
这五十多年来,公司本着诚实守信﹑团结协作﹑开拓创新﹑勇于争先的精神和宗旨,为科研院所﹑大专院校﹑大中型企业﹑医院等单位,提供各种进口﹑国产的科研器材﹑教学仪器等专业设备和技术服务,为促进我省的科学技术发展作出了应有的贡献,受到广大用户的一致好评,得到了省政府的嘉奖,并荣获江苏省精神文明称号.
目前公司主要经营的品种有:分析仪器、光学仪器、电化学仪器、计量仪器、物性测试、环境监测、生命科学、实验室仪器、药物检测仪器。主要国外品牌有日本岛津Shimadzu﹑日本岛津技迩Shimadzu-gl﹑美国贝克曼Beckman﹑美国爱博才思SCIEX、瑞士梅特勒Mettler Toledo﹑德国艾卡IKA﹑美国密理博Millipore﹑德国美墨尔特Memmert﹑德国艾本德Eppendorf、奥地利安东帕Anton Paar、美国热电Thermo、美国戴安Dionex、瑞士步琪Buchi等品牌,用户遍及省内外各大科研院所﹑大专院校﹑电力﹑电子﹑石油﹑化工﹑环保﹑轻工等许多相关领域。
公司经营这五十多年来,始终坚持为用户提供优质商品﹑优惠价格和优良服务,所售产品主要来源于国内外一流品牌的仪器仪表生产企业上。多年来公司注重人才的培养,现拥有一支富有经验﹑懂技术的高素质专业队伍。在科学技术迅猛发展的今天,公司将一如既往,再接再励,携全体员工共同开创美好的明天。
| 单位名称: |
江苏省南京市栖霞区纬地路9号江苏生命科技创新园B3幢
1483923011/2603776813
| 联系电话: |
| Email: |
