动物实验仪器
无创伤性小鼠多普勒超声血流动力学研究系统
Measure Cardiovascular Function Non-Invasively in Mice
进口
USA/ Indus Instrume
Indus Doppler Syste
[ 作者:佚名 | 来源:本站原创 | 点击数:129 | 更新时间:2009-4-9  ]
无创小鼠多普勒超声血流动力学及心脏功能研究系统
是由Indus Instruments仪器公司最新推出的,具有世界一流最先进技术和专利的无创伤性小鼠心脏功能及血流动力学动态连续研究系统
AHMSIC Reasearch 2009 ( Indus Instruments).pdf
Indus Doppler Systems for mice use high frequency ultrasound to non-invasively measure cardiovascular parameters such as blood velocity, heart rate, ejection time, pulse wave velocity,
EXPERIMENTAL SETUP TO ACQUIRE DOPPLER BLOOD FLOW VELOCITY DATA FROM MICE
The overall experimental setup to acquire Doppler blood flow velocity data from mice is shown above. The mouse is anesthetized with Ketamine/Xylazine/Acepromazine cocktail, Nembutal cocktail, or other anesthetics depending on the desired type of study.
The mouse is placed in supine position with its four limbs taped to four electrode plates mounted on a board. These electrodes are connected via a cable to the ECG module in a signal processing system that will provide the mouse ECG signal output.
A 10 MHz pulsed Doppler probe is used with its tip placed just below the sternum and positioned to obtain a blood flow velocity signal from the aortic outlet or mitral inlet. In addition, blood flow velocities from peripheral arteries of mice can be obtained using a 20 MHz pulsed Doppler probe. These probes are plugged into analog pulsed Doppler signal generators (10 or 20 MHz) such as the “Baylor Multichannel High Frequency Pulsed Doppler Analog Mainframe”. Other equivalent systems such as those from Crystal Biotech / Data Sciences Inc. can also be used. These systems will generate in-phase and quadrature Doppler demodulated audio signals.
In the figure above, the Doppler signals are acquired, processed, and displayed as a real-time spectrogram along with the ECG signal using the DSPW. The software also allows the user to perform offline analysis of the data and to generate reports.
The DSPW can measure blood velocities in both major and peripheral arteries of small animals, even mice; all without entering the test subject! The spectrograms below are traced to the artery where blood velocity is being measured. Click on each spectrogram to see how the blood velocity signal can be obtained using the DSPW and a topical probe.
美国健康医疗仪器国际公司AHMSIC于新世纪之初创建于美国纽约,借新世纪之春风快速成长。 AHMSIC是一家专门从事医学科研和临床仪器应用的高科技企业, 志力于心血管,呼吸及神经生理和药理科研仪器的应用:
•心血管-血压,血流,心脏功能及小血管研究: 压力及线性肌动图(Myograph,USA); 光谱成像血流分析仪; 超声血流计,激光血流计, ECGenieTM是唯一的真实地非侵入性地记录神志清楚的小鼠、大鼠和荷兰猪的心电图; 无创小鼠心脏功能及血流动力学动态连续研究系统(Indus Instruments, USA); 无创小动物脉搏血氧仪MouseOx; 精确的尾套法测定血压(USA); 实验动物心脏起搏器; 动物血管封堵器OC Vascular Occluders. 美国肌细胞收缩测定与分析系统Integrated System for Myocyte and SMC Contractility Measurements;
• 神经科学: 行為分析、疼痛研究、脑切片机: 动物行为轨跡-LABORAS &及超音波分析仪-SONOTRACK系統; 新一代振动脑切片机 Compresstome (USA); 动物行为波谱测定仪Behavioral Spectrometer. VCU动物颅脑损伤仪-颅脑创伤模型制作; NYU脊髓冲击损伤仪-脊髓冲击损伤模型制作
• 呼吸研究:CWE生理及呼吸研究仪器; 小动物呼吸机&麻醉系统, CO2 及 O2分析仪, 呼吸及代谢分析系统.
•生理药理和临床教學設備: 美国IWORX产品包括生理学教学设备、网络工具、数据记录主机、信号调节器、各种(ECG、EMG、EEG、PH值及张力、位移、血压、温度等)换能器及附件。在教学方面可以提供全面的人体生理学、动物生理学及心理生理学实验用工具包。在研究方面可以应用于血液动力学、神经系统科学、离体器官和组织试验、药理学等领域。和BIOPAC、POWERLAB并称三大生理研究和教学仪器公司。
•细胞生理:激光扫描,萤光离子,机械牵拉, 電生理:膜片钳放大器, 微量测定一氧化氮NO, 多巴胺, PO2和Dissolved Oxygen , pH, ion, redox, 细胞机械牵拉仪器 STREX - Mechanical Cell Strain Instruments ; 四通道or八通道可编程超微射灌系统; 超微细胞注射泵, 可编程微针拉针器; 显微锻针磨针器
•给药/采样: Alzet 植入式胶囊渗透压泵-- 胶囊大小的滲透压泵植入实验动物皮下或腹腔内, 直接或通过导管以 µl/小时 的速度持续准确地送出測試药剂入作用部位,最長可达6个星期; PE导管(PE10, PE50 & PE60 From USA); 精确可编程序的注射器微量注射泵(USA);
•无创无线遥测: 活动量、体温、心率; VitalView-無線遙測实验动物生理及行为Telemetric Physiological & Behavioral data acquisition system; 無線遙測实验动物Temp., Activity, & Heart Rate; 无创无线遥测心电图 (ECGenie TM, USA);
•低氧研究--Hypoxic Chambers气体O2/CO2/N2自动调控系统; 细胞低氧研究的新工具-镜下温控低氧小室; 高原低氧训练MAG-10.
•运动医学,行为及肥胖研究的最新武器--精确心率,运动量及热卡消耗监测仪.(USA)
•显微外科手术設備: 眼科手术剪(USA). 微型手术镊 (USA), .
• 动物小肠动力学研究-Gastrointestinal Motility Monitor & 膀胱动力学研究--膀胱内压监测系统Mouse Cystometry.
•样品均质:  冷冻细胞粉碎机Frozen Cell Crusher:CRYO-P.
•肥胖,内分泌和代谢研究- EchoMRI 清醒小動物體脂肪水份分析仪.
成都市金牛区一环路北一段88号新熙门2幢624室
028-86653817
400-6762467
