荧光滤光片,带通滤光片,显微镜滤光片
BP系列宽带滤光片(900-1600nm)broad bandpass filter
| 厚度 | 0.55mm-6mm | 棱边倒角 | <0.2mm |
| 厚度偏差 | +0/-0.1mm | 基底材料 | Fused silica;K7;K9;B270; |
| 尺寸偏差 | +0/-0.2mm(ΦD;LxW) | Float glass,etc. | |
| 通光孔径 | >90% | 使用温度 | -40°C /+70°C(低应力状态) |
| 光洁度 | 80-50 MIL-C-48497A | 储存环境 | 恒温~23℃;恒湿<40% |
产品选型(点击型号↓,查看参考光谱曲线)
| 型号 | 中心波长 | 带宽 | 透过率 | 截止范围 | 截止深度 | D12.7mm | D25.4mm | D50mm |
| NO. | CWL | FWHM | >Transm.% | Blocking Range | OD | |||
| BP900-15 | 900nm | 15nm | >80% | 200-1200nm | >OD4 | CALL | CALL | CALL |
| BP900-20 | 900nm | 20nm | >75% | 200-1200nm | >OD4 | CALL | CALL | CALL |
| BP900-30 | 900nm | 30nm | >85% | 200-1150nm | >OD2 | CALL | CALL | CALL |
| BP905-20 | 905nm | 20nm | >85% | 200-1200nm | >OD3 | CALL | CALL | CALL |
| BP905-30 | 905nm | 30nm | >80% | 400-1100nm | >OD3 | CALL | CALL | CALL |
| BP905-40 | 905nm | 40nm | >90% | 200-1200nm | >OD4 | CALL | CALL | CALL |
| BP910-20 | 910nm | 20nm | >85% | 200-1200nm | >OD4 | CALL | CALL | CALL |
| BP910-40 | 910nm | 40nm | >85% | 200-1200nm | >OD4 | CALL | CALL | CALL |
| BP915-20 | 915nm | 20nm | >85% | 400-1200nm | >OD2 | CALL | CALL | CALL |
| BP915-20 | 915nm | 20nm | >80% | 200-1200nm | >OD4 | CALL | CALL | CALL |
| BP920-20 | 920nm | 20nm | >85% | 400-1200nm | >OD2 | CALL | CALL | CALL |
| BP920-20 | 920nm | 20nm | >80% | 200-1200nm | >OD4 | CALL | CALL | CALL |
| BP925-30 | 925nm | 30nm | >90% | 200-1100nm | >OD2 | CALL | CALL | CALL |
| BP930-20 | 930nm | 20nm | >80% | 200-1100nm | >OD5 | CALL | CALL | CALL |
| BP930-25 | 930nm | 25nm | >70% | 200-1200nm | >OD4 | CALL | CALL | CALL |
| BP935-25 | 935nm | 25nm | >90% | 200-1200nm | >OD2 | CALL | CALL | CALL |
| BP935-30 | 935nm | 30nm | >90% | 200-1150nm | >OD2 | CALL | CALL | CALL |
| BP940-20 | 940nm | 20nm | >75% | 200-1200nm | >OD2 | CALL | CALL | CALL |
| BP940-30 | 940nm | 30nm | >90% | 400-1100nm | >OD3 | CALL | CALL | CALL |
| BP940-45 | 940nm | 45nm | >90% | 200-1150nm | >OD2 | CALL | CALL | CALL |
| BP940-50 | 940nm | 50nm | >90% | 400-1100nm | >OD2 | CALL | CALL | CALL |
| BP945-20 | 945nm | 20nm | >70% | 200-1200nm | >OD4 | CALL | CALL | CALL |
| BP945-40 | 945nm | 40nm | >95% | 200-1100nm | >OD2 | CALL | CALL | CALL |
| BP950-20 | 950nm | 20nm | >75% | 200-1200nm | >OD4 | CALL | CALL | CALL |
| BP950-25 | 950nm | 25nm | >90% | 400-1100nm | >OD2 | CALL | CALL | CALL |
| BP950-30 | 950nm | 30nm | >90% | 200-1100nm | >OD3 | CALL | CALL | CALL |
| BP950-40 | 950nm | 40nm | >90% | 400-1100nm | >OD3 | CALL | CALL | CALL |
| BP950-50 | 950nm | 50nm | >90% | 400-1100nm | >OD2 | CALL | CALL | CALL |
| BP955-20 | 955nm | 20nm | >80% | 200-1200nm | >OD4 | CALL | CALL | CALL |
| BP960-20 | 960nm | 20nm | >85% | 200-1200nm | >OD4 | CALL | CALL | CALL |
| BP960-30 | 960nm | 30nm | >85% | 200-1200nm | >OD3 | CALL | CALL | CALL |
| BP970-20 | 970nm | 20nm | >75% | 200-1100nm | >OD3 | CALL | CALL | CALL |
| BP970-30 | 970nm | 30nm | >85% | 200-1200nm | >OD4 | CALL | CALL | CALL |
| BP970-35 | 970nm | 35nm | >85% | 200-1200nm | >OD2 | CALL | CALL | CALL |
| BP975-25 | 975nm | 25nm | >75% | 200-1200nm | >OD4 | CALL | CALL | CALL |
| BP975-30 | 975nm | 30nm | >90% | 200-1100nm | >OD2 | CALL | CALL | CALL |
| BP980-20 | 980nm | 20nm | >85% | 200-1100nm | >OD3 | CALL | CALL | CALL |
| BP980-25 | 980nm | 25nm | >75% | 200-1100nm | >OD4 | CALL | CALL | CALL |
| BP980-30 | 980nm | 30nm | >85% | 200-1100nm | >OD3 | CALL | CALL | CALL |
| BP980-40 | 980nm | 40nm | >90% | 400-1100nm | >OD3 | CALL | CALL | CALL |
| BP985-30 | 985nm | 30nm | >90% | 400-1100nm | >OD2 | CALL | CALL | CALL |
| BP985-40 | 985nm | 40nm | >90% | 400-1100nm | >OD3 | CALL | CALL | CALL |
| BP990-80 | 990nm | 80nm | >95% | 200-1200nm | >OD2 | CALL | CALL | CALL |
| BP995-25 | 995nm | 25nm | >70% | 200-1100nm | >OD3 | CALL | CALL | CALL |
| BP1005-25 | 1005nm | 25nm | >60% | 200-1100nm | >OD3 | CALL | CALL | CALL |
| BP1010-40 | 1010nm | 40nm | >65% | 200-1100nm | >OD3 | CALL | CALL | CALL |
| BP1060-20 | 1060nm | 20nm | >65% | 200-1200nm | >OD4 | CALL | CALL | CALL |
| BP1065-20 | 1065nm | 20nm | >70% | 200-1200nm | >OD4 | CALL | CALL | CALL |
| BP1064-15 | 1064nm | 15nm | >60% | 200-1200nm | >OD4 | CALL | CALL | CALL |
| BP1064-20 | 1064nm | 20nm | >90% | 200-1200nm | >OD4 | CALL | CALL | CALL |
| BP1070-20 | 1070nm | 20nm | >75% | 200-1200nm | >OD4 | CALL | CALL | CALL |
| BP1075-20 | 1075nm | 20nm | >70% | 200-1200nm | >OD4 | CALL | CALL | CALL |
| BP1080-15 | 1080nm | 15nm | >75% | 200-1200nm | >OD4 | CALL | CALL | CALL |
| BP1100-70 | 1100nm | 70nm | >90% | 200-2000nm | >OD3 | CALL | CALL | CALL |
| BP1150-70 | 1150nm | 70nm | >80% | 200-2000nm | >OD2 | CALL | CALL | CALL |
| BP1200-50 | 1200nm | 50nm | >80% | 200-2000nm | >OD3 | CALL | CALL | CALL |
| BP1275-70 | 1275nm | 70nm | >90% | 200-2000nm | >OD2 | CALL | CALL | CALL |
| BP1300-80 | 1300nm | 80nm | >90% | 200-2000nm | >OD2 | CALL | CALL | CALL |
| BP1350-75 | 1350nm | 75nm | >80% | 200-2000nm | >OD2 | CALL | CALL | CALL |
| BP1400-70 | 1400nm | 70nm | >85% | 200-2000nm | >OD2 | CALL | CALL | CALL |
| BP1475-70 | 1475nm | 70nm | >90% | 200-2000nm | >OD2 | CALL | CALL | CALL |
| BP1500-70 | 1500nm | 70nm | >90% | 200-2000nm | >OD2 | CALL | CALL | CALL |
| BP1525-75 | 1525nm | 75nm | >75% | 200-2000nm | >OD2 | CALL | CALL | CALL |
| BP1530-70 | 1530nm | 70nm | >70% | 200-2000nm | >OD2 | CALL | CALL | CALL |
| BP1535-70 | 1535nm | 70nm | >90% | 200-2000nm | >OD2 | CALL | CALL | CALL |
| BP1540-60 | 1540nm | 60nm | >90% | 200-2000nm | >OD2 | CALL | CALL | CALL |
| BP1545-60 | 1545nm | 60nm | >90% | 200-2000nm | >OD3 | CALL | CALL | CALL |
| BP1545-80 | 1545nm | 80nm | >90% | 200-2000nm | >OD2 | CALL | CALL | CALL |
| BP1550-75 | 1550nm | 75nm | >90% | 200-2000nm | >OD3 | CALL | CALL | CALL |
| BP1600-60 | 1600nm | 60nm | >85% | 200-2000nm | >OD3 | CALL | CALL | CALL |
参数如有变动,以实际库存产品为准;更多技术信息咨询及批量定制请致电瑞研科技。
长春瑞研光电科技有限公司(RAYAN TECHNOLOGY CO,.LTD.)(简称:瑞研科技&瑞研光学)位于素有“北国春城”及中国光学发源地之称的吉林省长春市,研发中心设立在长春市风景秀丽的伊通河畔,公司依托长春光机所强大的技术和研发实力支持,现已发展成一家集光学镀膜产品研发、光学解决方案设计、加工生产、销售于一体的新科技创新型企业。
我们专业从事光学镀膜解决方案的创新型公司,采用多台国内外先进的镀膜设备提供光学镀膜元件的生产,数据标定级别的进口分光光度计对出厂的产品质量进行把控,并拥有一支经验丰富的技术团队,聘请长春光机所的专业老师进行技术指导,我公司研发销售的镀膜产品已经广泛应用在科学研究、科研实验、分析仪器、荧光测试设备、环境监测设备、农业测量仪器、生化仪器、医疗分析等多领域和行业。
我们有先进的生产设备,严格的质量管控流程和优秀的技术研发及管理人才。凭借良好的产品质量,极具竞争力的销售价格,准确交货期和优秀的售后服务,深受广大用户的赞誉。并与多家国内外知名厂商、科研院所及国内各大院校保持紧密的合作关系。
瑞研光学本着“全心全意为科研事业服务”的公司理念,也期待与您能成为长期的合作伙伴,现诚邀各科研院校及企业联合研发项目。
技术优势:
瑞研光学研发生产的产品主要有:
窄带滤光片、超窄带滤光片、宽带滤光片、超宽带滤光片、紫外带通滤光片、可见带通滤光片、红外带通滤光片、中远红外滤光片、渐变带通滤光片、多带通滤光片、长波通滤光片、真空紫外滤光片、短波通滤光片、荧光滤光片、拉曼滤光片、陷波滤光片、二向色镜、分光片、中性密度滤光片、增透膜窗口片、介质膜反射镜、金属膜反射镜等。
| 单位名称: |
长春市二道区东盛大街3000号上东国际3号楼A1307
| 联系电话: |
| Email: |
