1000ml三夹套反应釜系统
1Liter Triple-Walled Reaction Unit
Blue Label (Pre-fixed) units for 1Liter reaction vessel, Triple-Walled. The configuration includes the vessel and the standard component which is mentioned bellow Standard Component List. Every part can be replaceable with parts listed on the BL option & parts list. Customer can choose most proper vessel and the option & the parts for the subject.
Triple-Walled 1Liter Vessel selection and code number for placing order.
| Code number | Vessel Selection | Combination |
| AGI-5740-1000 | 1Liter Triple-Walled Vessel with Ring Baffle (Code No. 5742-1000-M) |
Standard component, including support stand and Overhead stirrer. |
| AGI-5720-1000 | 1Liter Triple-Walled Vessel without Ring Baffle (Code No. 5722-1000) |
Standard Component including support stand and Overhead stirrer. |
Standard Component
| No. | Code Number | Description | Qty |
| 1 | 5742-1000-M | Triple-Walled Vessel with ring baffle, 1L | 1 |
| 1' | 5722-1000 | Triple-Walled Vessel w/o ring baffle, 1L | 1 |
| 2 | 5702-100C | Glass cover, DN100, 6 ports | 1 |
| 3 | 3960-01P | Flush valve / PEEK shaft, SQG-29/42 | 1 |
| 4 | 3750-50-3L | Dropping funnel, Graduated, TS24/40, 50ml | 1 |
| 5 | 3442-200-4L1L | Condenser, Dimroth, TS24/40, L:200mm | 1 |
| 6 | 2242-29/42 | Stopper for hand hole, TS29/42 | 1 |
| 7 | 2242-24/40 | Stopper for additional hole, TS24/40 | 1 |
| 8 | 2402-1L | Vent adaptor TS15/25 | 1 |
| 9 | 9131-15/16L | Metal Adapter for HTF, Ltype flange coupling, M16 | 2 |
| 10 | 9006-15 | Flange, DN15 | 2 |
| 11 | 9016-15 | Insert, DN15 | 2 |
| 12 | 9018-15 | PTFE Gasket, DN15 | 2 |
| 13 | 9134-40 | Bolt & Nut | 6 |
| 14 | 3966-100 | Quick release clamp, DN100 | 1 |
| 15 | 9222-348 | O-ring / FKM, DN100 | 1 |
| 16 | 5708-PMT | Stirrer seal, PTFE, TS24/40, shaft OD:φ8 | 1 |
| 17 | 5708-PMT | Temperature probe holder, PTFE,φ8, TS24/40 | 1 |
| 18 | 5708-500 | PTFE coated stirrer shaft, 1L & 2L | 1 |
| 19 | 5708-TS | Temperature sensor probe, OD:φ8, L:660mm | 1 |
| 20 | 5782-B | Support Stand Base, Lab | 1 |
| 21 | 5784-100C | Clamp, DN100 | 1 |
| 22 | 5786-AS | Stirrer Stay | 1 |
| 23 | 5788-MC | Motor Clamp | 1 |
| 24 | 5790-P-920 | Support Stand Pipe | 2 |
| 25 | 5792-FV-S | Vessel Support | 1 |
| 26 | 5794-SC | Clamp | 1 |
| 27 | 5750-TA40 | Level Adjuster | 4 |
| 28 | 5752-PP20 | Stainless cup | 1 |
| 29 | 5754-SK-GA40 | Screw Knob, Lab | 8 |
| 30 | 2572100 | Overhead stirrer for 300ml-5L reactors | 1set |
The Triple-Walled Advantage
The vacuum jacket virtually eliminates any heat exchange between the jacket outer surface and the atmosphere.
Because of maximum heat exchange efficiency imparted by the vacuum jacket, there is very little frost formation or condensation on the surface of the reactor vessel for low-temperature operations (i.e. below dew point or sub-zero operations), imparting visibility around the vessel, and hence, the process can be monitored visually.
Blue Label Selection
Blue Label Units are of pre-fixed configuration. However the parts are alternative to the options which are listed in the BL Option and Parts List. Customers may request alternations when placing an order. Customers choose basic configuration Code Number (C/N) in the table 1-1 with the C/N of alternative BL Option or Parts. AGI will advise upon pricing as soon as possible. Order Code No. alternate the condenser from Dimroth (E.g.C/N,3442-200-4L1L)to bigger Dimroth condenser (E.g.C/N,3442-300-4L1L) .
| 单位名称: |
上海市中山北路3856弄2号中环大厦1325-26室
| 联系电话: |
| Email: |
