2000ml双夹套反应釜系统
2000ml双夹套反应釜系统
2Liter Double-Walled Reaction Unit
Blue Label (Pre-fixed) units for 2Liter reaction vessel, Double-Walled. The configuration includes the vessel and the standard component Every part can be replaceable with parts listed on the BL option & parts list. Customer can choose most proper vessel and the option & the parts for the subject.
Double-Walled 2Liter Vessel selection and code number for placing order.
| Code number | Vessel Selection | Combination |
| AGI-5730-2000 | Double-Walled with ring baffle (code No. 5732-2000-M) |
Standard Component including support stand and Overhead stirrer. |
| AGI-5710-2000 | Double-Walled without ring baffle (code No. 5712-2000) |
Standard Component
| No. | Code Number | Description | Qty |
| 1 | 5732-2000-M | Double-Walled Vessel with ring baffle, 2L | 1 |
| 1' | 5712-2000 | Double-Walled Vessel w/o ring baffle, 2L | 1 |
| 2 | 5702-100C | Glass cover, DN100, 6 ports | 1 |
| 3 | 3960-01 | Flush valve / Glass shaft, SQG-29/42 | 1 |
| 4 | 3750-100-3L | Dropping funnel, Graduated, TS24/40, 100ml | 1 |
| 5 | 3442-300-4L1L | Condenser, Dimroth, TS24/40, L:300mm | 1 |
| 6 | 2242-29/42 | Stopper for hand hole, TS29/42 | 1 |
| 7 | 2242-24/40 | Stopper for additional hole, TS24/40 | 1 |
| 8 | 2402-1L | Vent adaptor TS15/25 | 1 |
| 9 | 9199-L15P | Metal Adapter for HTF, Ltype screw coupling, M16 | 2 |
| 10 | 3966-100 | Quick release clamp, DN100 | 1 |
| 11 | 9222-348 | O-ring / FKM, DN100 | 1 |
| 12 | 5708-PMT | Stirrer seal, PTFE, TS24/40, shaft OD:φ8 | 1 |
| 13 | 5708-PMT | Temperature probe holder, PTFE,φ8, TS24/40 | 1 |
| 14 | 5708-500 | PTFE coated stirrer shaft, 1L & 2L | 1 |
| 15 | 5708-TS | Temperature sensor probe, OD:φ8, L:660mm | 1 |
| 16 | 5782-B | Support Stand Base, Lab | 1 |
| 17 | 5784-100C | Clamp, DN100 | 1 |
| 18 | 5786-AS | Stirrer Stay | 1 |
| 19 | 5788-MC | Motor Clamp | 1 |
| 20 | 5790-P-920 | Support Stand Pipe | 2 |
| 21 | 5792-FV-S | Vessel Support | 1 |
| 22 | 5794-SC | Clamp | 1 |
| 23 | 5750-TA40 | Level Adjuster | 4 |
| 24 | 5752-PP20 | Stainless cup | 1 |
| 25 | 5754-SK-GA40 | Screw Knob, Lab | 8 |
| 26 | 2572100 | Overhead stirrer for 300ml-5L reactors | 1 |
The Ring Baffle Advantage
Since the ring baffle distribute heat transfer fluid evenly throughout the jacket, the temperature in a vessel is well controlled more precisely and efficiently.
Thus, it leads to progress the reaction process with great efficiency and allow a circulator to operate with less energy.
Blue Label Selection
Blue Label Units are of pre-fixed configuration. However the parts are alternative to the options which are listed in the BL Option and Parts List. Customers may request alternations when placing an order. Customers choose basic configuration Code Number (C/N) in the table 1-1 with the C/N of alternative BL Option or Parts. AGI will advise upon pricing as soon as possible. Order Code No. alternate the condenser from Dimroth (E.g.C/N,3442-200-4L1L)to bigger Dimroth condenser (E.g.C/N,3442-300-4L1L) .
| 单位名称: |
上海市中山北路3856弄2号中环大厦1325-26室
| 联系电话: |
| Email: |
