反应釜
3000ml三夹套反应釜系统
3000ml三夹套反应釜系统
3Liter Triple-Walled Reaction Unit
进口
日本
3000ml三夹套反应釜系统
3000ml三夹套反应釜系统
3000ml三夹套反应釜系统
Blue Label (Pre-fixed) units for 3Liter reaction vessel, Triple-Walled. The configuration includes the vessel and the standard component which is mentioned bellow Standard Component List. Every part can be replaceable with parts listed on the BL option & parts list. Customer can choose most proper vessel and the option & the parts for the subject.
Triple-Walled 3Liter Vessel selection and code number for placing order.
Code number Vessel Selection Combination
AGI-5740-3000 3Liter Triple-Walled Vessel with Ring Baffle
(Code No. 5742-3000-M)
Standard component, including support stand and Overhead stirrer.
AGI-5720-3000 3Liter Triple-Walled Vessel without Ring Baffle
(Code No. 5722-3000)
Standard Component including support stand and Overhead stirrer.
Standard Component
No. Code Number Description Qty
1 5742-3000-M Triple-Walled Vessel with ring baffle, 3L 1
1' 5722-3000 Triple-Walled Vessel w/o ring baffle, 3L 1
2 5702-100C Glass cover, DN100, 6 ports 1
3 3960-01P Flush valve / PEEK shaft, SQG-29/42 1
4 3750-200-3L Dropping funnel, Graduated, TS24/40, 200ml 1
5 3442-300-4L1L Condenser, Dimroth, TS24/40, L:300mm 1
6 2242-29/42 Stopper for hand hole, TS29/42 1
7 2242-24/40 Stopper for additional hole, TS24/40 1
8 2402-1L Vent adaptor TS15/25 1
9 9131-15/16L Metal Adapter for HTF, Ltype flange coupling, M16 2
10 9006-15 Flange, DN15 2
11 9016-15 Insert, DN15 2
12 9018-15 PTFE Gasket, DN15 2
13 9134-40 Bolt & Nut 6
14 3966-100 Quick release clamp, DN100 1
15 9222-348 O-ring / FKM, DN100 1
16 5708-PMT Stirrer seal, PTFE, TS24/40, shaft OD:φ8 1
17 5708-PMT Temperature probe holder, PTFE,φ8, TS24/40 1
18 5708-600 PTFE coated stirrer shaft, 3L & 5L 1
19 5708-TS Temperature sensor probe, OD:φ8, L:660mm 1
20 5782-B Support Stand Base, Lab 1
21 5784-100C Clamp, DN100 1
22 5786-AS Stirrer Stay 1
23 5788-MC Motor Clamp 1
24 5790-P-920 Support Stand Pipe 2
25 5792-FV-S Vessel Support 1
26 5794-SC Clamp 1
27 5750-TA40 Level Adjuster 4
28 5752-PP20 Stainless cup 1
29 5754-SK-GA40 Screw Knob, Lab 8
30 2572100 Overhead stirrer for 300ml-5L reactors 1
The Triple-Walled Advantage
The vacuum jacket virtually eliminates any heat exchange between the jacket outer surface and the atmosphere.
Because of maximum heat exchange efficiency imparted by the vacuum jacket, there is very little frost formation or condensation on the surface of the reactor vessel for low-temperature operations (i.e. below dew point or sub-zero operations), imparting visibility around the vessel, and hence, the process can be monitored visually.
Blue Label Selection
Blue Label Units are of pre-fixed configuration. However the parts are alternative to the options which are listed in the BL Option and Parts List. Customers may request alternations when placing an order. Customers choose basic configuration Code Number (C/N) in the table 1-1 with the C/N of alternative BL Option or Parts. AGI will advise upon pricing as soon as possible. Order Code No. alternate the condenser from Dimroth (E.g.C/N,3442-200-4L1L)to bigger Dimroth condenser (E.g.C/N,3442-300-4L1L) .
上海贺美仪器设备有限公司,是德国HUBER公司在中国上海的办事处,主要负责HUBER产品在中国的技术支持、市场开拓及售后服务工作,公司销售经理有丰富的HUBER产品的培训、销售经验,销售经理及维修工程师每年都有一个月时间在德国总部进行产品技术及售后等方面的培训。并且在国内已经安装过上百套控温及反应系统。
公司同时还是欧洲多家实验室知名品牌仪器设备在中国的总代理,
主要品牌有:
德国HUBER 恒温水浴/油浴 反应釜专用权封闭控温系统
日本ASAHI 超低温反应釜、玻璃高压反应釜、短程蒸馏设备。
美国CHEMGLASS 反应釜
德国VACUUBRAND 无油隔膜泵、油封旋叶泵、杂交泵、泵系统及真空控制器等
瑞士ESCO 真空乳化仪、小型研磨机等
德国GENSER 大型旋转蒸发仪等
德国HEIDOLPH 磁力搅拌器、旋转蒸发仪、顶置搅拌等
产品广泛用于制药、化工、石化、高校、科研等行业。
公司自成立以来,依靠雄厚的技术实力、科学合理的配置方案、专业的安装调试和周到的售后服务,赢得了广大用户的支持与信赖。多年来,公司本着诚信的经营理念,在国内开拓了广泛的市场,包括各大高校、中科院研究所、医学研究部门及众多的生产企业及公司。
  公司从满足客户多样化需求出发,能及时提供价格合理、性能多样化的仪器设备;公司拥有的专业人才,能够根据客户的需求设计一流的系统解决方案;技术过硬的维修工程师,能够高效率地为客户提供完善的售后服务。
今后,我们将继续努力向国内用户提供更高性价比的仪器,帮助广大用户更合理地运用资金,更高效地使用仪器。
上海市中山北路3856弄2号中环大厦1325-26室
021-52682303 01082376670 020-85286260
