生物反应器
三维细胞培养Synthecon3D细胞培养仪RCCS-D
Synthecon
进口
美国赛斯康Synthecon
一次性3D三维细胞培养仪RCCS-D
旋转三维细胞培养系统Rotary Cell Culture Systems———简称RCCS
旋转细胞培养系统(简称RCCS)是一种针对贴壁及悬浮细胞的独特细胞培养技术. 是第一款设计集生物反应器与细胞培养功能于一体的高新技术系统,具有低剪切力(因为低湍流原因)及高营养传质特点.以上这些条件有利于细胞在三维空间内分裂并抱团.
旋转三维细胞培养系统规格分类
1 基础级. 一次性容器式旋转三维细胞培养仪
2 高  级. 可灭菌容器式旋转三维细胞培养仪
3 高  级. 培养自动灌注式旋转三维细胞培养仪
4 高  级. 干细胞专用旋转三维细胞培养仪
RCCS特点
1 允许在一个三维空间的球体内共培养多种细胞
2 容器(存储营养及细胞)在旋转时仅有较小的剪切力,因此导致的湍流非常小,便于细胞增殖
3 具有高营养素传质特点,可预防细胞死亡
4 容器转速可通过转速表进行任意调整
Our disposable vessel culture systems are low cost, easy to use, rotary bioreactor systems that utilize disposable culture vessels.  Each vessel can be used only once, though there are no limits on the duration of the experiment.  Each culture vessel is gamma sterilized and individually packaged (heat sealed) for immediate use upon opening.  All disposable vessel bioreactor systems include four individually wrapped HARV culture vessels (10 mL or 50 mL), except the RCCS-8D and RCCS-8DQ, which include 8 vessels.
Advantages of disposable vessel culture systems:
  • No sterilization is required prior to use
  • Culture vessels can be discarded following use
  • Preferred for biohazardous materials
  • Lower cost rotator base and vessels
RCCS-D
The RCCS-D bioreactor rotates one disposable vessel at a single speed; the rotation speed is adjustable.
Includes:
♦ a single station rotator base
♦ power supply
♦ operation manual
♦ four disposable culture vessels.
*This system is only compatible with disposable vessels.
RCCS-2D
The RCCS-2D rotates up to two disposable vessels at a single speed; the rotation speed adjustable.
Includes:
♦ a 2-station rotator base
♦ power supply
♦ operation manual
♦ 4 disposable culture vessels
RCCS-4D
The RCCS-4D bioreactors is capable of rotating four vessels at the same speed; the rotation speed is adjustable.
Includes:
♦ a four station rotator base
♦ power supply with tachometer
♦ operation manual
RCCS-4DQ
The RCCS-4DQ bioreactor is capable of rotating up to four disposable vessels at four independent speeds.  This system is ideal for conducting multiple experiments simultaneously.
Includes:
♦ operation manual
* This system is only compatible with disposable vessels.
RCCS-8D
The RCCS-8D bioreactor system rotates up to eight disposable vessels at a single speed. This system provides a cost-effective and time-efficient  way of testing several variables simultaneously.
Includes:
♦ an eight station rotator base
♦ operation manual
♦ 8 disposable culture vessels
RCCS-8DQ
The RCCS-8DQ bioreactor is capable of rotating eight disposable vessels at four independent speeds.  The stations rotate in pairs; each pair of stations can rotate at a speed independent of the other pairs.
Includes:
♦ operation manual
♦ 8 disposable vessels
Disposable vessels
Disposable vessels are available in the High Aspect Ratio Vessels (HARVs).  Each vessel is individually packaged and gamma sterilized. Vessels are supplied four to a pack.
Available vessel volumes: 10 mL  •  50 mL
苏州乾芸仪器科技有限公司代理销售‘美国赛斯康Synthecon一次性3D三维细胞培养仪RCCS-D’并提供售后服务,详情请咨询info@genintech.com或面议!
苏州乾芸仪器科技有限公司是一家专注于生命科学、生物技术及实验室领域的高科技企业,是国内代理销售生物试剂、实验设备、仪器的知名公司之一!苏州乾芸仪器科技有限公司位于素有人间天堂之美誉的城市——苏州。公司自成立之日起,即始终本着“守信、协作、创新”的方针与创业的激情不断努力开拓市场,提升产品、服务质量,保证了公司年销售额的不断增长!同时,苏州乾芸仪器科技有限公司代理的产品也不断得到增加,服务客户规模不断得到扩大。
苏州乾芸仪器科技始终坚持品质第一、服务第一、创新第一,并以“源自细节的创新与专注”为企业经营、发展的基本宗旨。公司代理众多欧美著名生物技术公司产品,为用户提供分子生物学、细胞生物学、免疫学等实验相关的试剂、消耗品及仪器,客户遍布大学、研究所、医院、卫生防疫、商品检验检疫、制药公司、生物技术公司和食品工业等单位。
苏州吴中区胥口镇马舍村浦庄大道北延段凯恒精密园内乾芸仪器科技有限公司
