台式离心机
VWR 银河系列微型离心机
VWR 银河系列微型离心机
VWR Galaxy* Microcentrifuges
进口
美国 VWR
Galaxy*
来电询价
特点:
1、 经济可靠
2、 操作简便无噪音
3、 小巧灵活
4、 能在冷室内应用
5、 两种转速型
VWR银河系列微型离心机具有高准确性、耐用等特点,操作噪音低、占用空间小,由于采用了风流式内部设计,离心过程中,样品不易升温,加速和减速优良性能使用户节约很多样品处理时间,该系列离心机还能在冷室内正常安全运行。银河系列有7和16型两种离心机,16型最高转速达到每分14000转,(离心力16000G),是DNA样品处理和分子生物学研究的理想离心机,7型离心机为经济型,最高转速为每分钟10000转(离心力7200G).两种离心机转头均为45℃。离心管大小是1.5ML至2.0ML
VWR Galaxy Microcentrifuges are high performance, quality units designed to stand up to the rigors of continuous duty. They are exceptionally quiet and require very little bench space, allowing them to be used almost anywhere. Airflow patterns within the chambers of these centrifuges keep sample temperature rise to a minimum, even at maximum speed. Exceptionally fast acceleration and deceleration saves the user considerable time especially in applications requiring a large number of samples. The Galaxy microcentrifuges can be used safely in a cold room. Operation can be timed, from 1 to 30 minutes, or continuous.
Two models are available to meet a variety of applications. The Galaxy 16 has a maximum speed of 14,000rpm/16,000g making it ideal for DNA work and other applications requiring a high g-force. The Galaxy 16 features a brushless motor, which makes this microcentrifuge virtually maintenance-free. It also has a momentary button for quick spins. The Galaxy 7 is the economical choice when higher speeds are not required. The unit''s maximum speed of 10,000rpm/7,200g makes it perfect for quick spins and microfiltration.
The Galaxy 16 has a capacity of 18x1.5/2.0mL tubes while the Galaxy 7 holds 12x1.5/2.0mL tubes. Both units are supplied complete with a 45° fixed angle rotor. Adapters are available for smaller tubes. The rotors feature easy on-off lids that can be removed and replaced with one hand.
___________________________________Galaxy 16_____________Galaxy 7
最大转速Maximum Speed:____________ 14,000 rpm____________10,000 rpm
最大离心力Maximum RCF:_____________16,000 g_______________7,200 g
减速时间
Deceleration from maximum speed:___12 seconds____________20 seconds
最大范围
Maximum radius (for 1.5/2.0mL):____18 x 1.5/2.0 mL______ 12 x 1.5/2.0mL
时间控制 Timer:____________________1 to 30 minutes_______1 to 30 minutes
噪音 Noise level:__________________55 dB(A)______________52 dB(A)
外部尺寸 Dimensions (W x D x H):___21 x 24 x 18 cm_______21 x 24 x 18 cm
重量 Weight:_______________________6 kg__________________4 kg
北京诺克奥基因工程技术有限公司, 简称“诺克奥基因”, 是一家加拿大独资注册于北京中关村科技园区清华科技园的高新技术企业。公司专门从事生命科学专业技术的咨询服务和生命科学类产品的研发、生产及销售, 其产品广泛应用于医疗卫生、生物制药、基因治疗、太空生物工程、环境保护、快速饮用水生物检测、畜牧养殖、食品加工、生物医疗信息管理系统等领域。
研发是公司可持续发展的基础, 公司在创立之初就形成了一只以数名归国留学博士为核心的研发团队, 现在已经在病毒快速诊断技术研发上取得了突破性的进展, 如先天性心脏病基因诊断技术、子宫胫HPV基因诊断技术、早期乳腺癌基因诊断技术、血传病毒的基因快速诊断技术(包括HIV, HBV, HCV, TTV, WNV)、大肠杆菌E.coli 0157株系的基因快速诊断技术、细菌(MRSA, VRE)抗药基因的分子快速诊断技术等; 同时, 以研发成果为平台, 新产品也在不断地推向市场。
公司在生命科学实验室的建设和管理的咨询具有得天独厚的优势。公司拥有一只具有多年海外发达国家大型生命科学实验室研究和管理背景的专家队伍, 为国内从事分子生物学、基因工程, 转基因动植物, 细胞生物学、生物化学、生态学、免疫学及环保等多项学科研究实验室的建设、改造及管理提供完整的解决方案, 以为国内在这些方面的研究发展紧跟世界潮流提供必要条件。公司采用了一个具有中国特色的商务模型, 建立了一套长短目标结合的产品开发系列, 既实现了短期收入, 又为公司长远发展打下了科研基础。我们面向国内外科研机构、医院以及生物医药企业, 积极开展技术合作和服务。同时我们也将充分发挥和挖掘诺克奥自身的优势, 主动适应国内外市场和客户的需求, 探索产品定位, 开拓业务范围, 寻求最佳经营模式, 力求走一条切合诺克奥基因实际的资本增值道路。
公司以“弘扬高科、真诚务实、放眼全球”为指导思想, 以发展科技、服务社会为己任, 以成为国际一流高技术公司为目标, 愿与社会各界诚信合作, 共同进步。
北京市海淀区信息路1号院创业1楼B1室
964339422 849541200
010-56533001 18611194327
