VWR* 台面式紫外显影仪/VWR* 冷光源显影仪
21475-466VWR* 台面式紫外显影仪(Benchtop Ultraviolet Transilluminators)
• 体积小巧 Compact Size
• VWR两年质保 VWR Two-Year Limited Warranty
通过统一标准的强紫外背景光源和荧光物质,紫外显影仪能够以高灵敏度检测被染色的双链核酸,单链核酸也可以被检测,但灵敏度相应较低。每个显影仪都可将强紫外射线投射到整个工作表面,特殊的滤镜可降低射线的损失。利用塑料盖可减少紫外线的伤害。
单波长型号可提供302纳米的中频紫外光,此波长的紫外光线将光致退色现象降至最小,从而允许更长时间的使用。
多波长型号比购买多个单波长光源的仪器更经济。可发出302纳米-365纳米波长的紫外线,满足用户的不同需要。
Transilluminators offer uniform and intense ultraviolet light for back-illumination of transparent, fluorescent materials, providing a highly sensitive method to detect double-stranded nucleic acids that have been labeled with dyes. Single-stranded nucleic acids may be detected, but with lower sensitivity.
Each transilluminator is designed to deliver high intensity UV radiation over the full working surface. Units are fitted with a special 5000-hour filter that provides longer filter life and decreases the solarization rate. A plastic cover blocks harmful UV radiation.
Single wavelength models provide 302nm midrange ultraviolet light. Photobleaching is minimized at this wavelength, allowing more time to take pictures without having to restain.
Multiple wavelength models reduce the investment normally associated with the need to acquire more than one light box. Select the longwave (365nm) for viewing a gel for extended periods while avoiding photonicking damage, or easily switch to the midrange UV wavelength (302nm) to increase fluorescence for photo documentation work.
The 115V Models are ETL and ETLc approved. The 230V Models are CE approved.
滤光片尺寸 Filter Size: 20 x 20cm
设备尺寸 Unit Dimensions: 24.1D x 33.7W x 12H cm
21475-464VWR* 冷光源显影仪(Benchtop Ultraviolet Transilluminators)
• 体积小巧Compact Size
• 白色冷光源Cool White Light
• 无紫外线辐射No Ultraviolet Transmissions
• VWR两年质保VWR Two-Year Limited Warranty
VWR* 冷光源显影仪体积小巧,白色冷光源柔和,适宜显影黑白底片,放射自显影片和X-光片。也可用于显影酶联免疫反应版和各种染色后的蛋白凝胶。
The space-saving VWR white light transilluminator provides a cool white light through an evenly diffused glass surface. Excellent for viewing negatives, film positives, radiographic and X-ray film. Can also be used for examining Microtiter* plates and stained gels such as coomassie blue, methylene blue, and silver stained protein gels.
The 115V model is ETL, ETLc approved. The 230V model is CE approved.
滤光片尺寸 Filter Size: 21 x 26 cm
北京诺克奥基因工程技术有限公司, 简称“诺克奥基因”, 是一家加拿大独资注册于北京中关村科技园区清华科技园的高新技术企业。公司专门从事生命科学专业技术的咨询服务和生命科学类产品的研发、生产及销售, 其产品广泛应用于医疗卫生、生物制药、基因治疗、太空生物工程、环境保护、快速饮用水生物检测、畜牧养殖、食品加工、生物医疗信息管理系统等领域。
研发是公司可持续发展的基础, 公司在创立之初就形成了一只以数名归国留学博士为核心的研发团队, 现在已经在病毒快速诊断技术研发上取得了突破性的进展, 如先天性心脏病基因诊断技术、子宫胫HPV基因诊断技术、早期乳腺癌基因诊断技术、血传病毒的基因快速诊断技术(包括HIV, HBV, HCV, TTV, WNV)、大肠杆菌E.coli 0157株系的基因快速诊断技术、细菌(MRSA, VRE)抗药基因的分子快速诊断技术等; 同时, 以研发成果为平台, 新产品也在不断地推向市场。
公司在生命科学实验室的建设和管理的咨询具有得天独厚的优势。公司拥有一只具有多年海外发达国家大型生命科学实验室研究和管理背景的专家队伍, 为国内从事分子生物学、基因工程, 转基因动植物, 细胞生物学、生物化学、生态学、免疫学及环保等多项学科研究实验室的建设、改造及管理提供完整的解决方案, 以为国内在这些方面的研究发展紧跟世界潮流提供必要条件。公司采用了一个具有中国特色的商务模型, 建立了一套长短目标结合的产品开发系列, 既实现了短期收入, 又为公司长远发展打下了科研基础。我们面向国内外科研机构、医院以及生物医药企业, 积极开展技术合作和服务。同时我们也将充分发挥和挖掘诺克奥自身的优势, 主动适应国内外市场和客户的需求, 探索产品定位, 开拓业务范围, 寻求最佳经营模式, 力求走一条切合诺克奥基因实际的资本增值道路。
公司以“弘扬高科、真诚务实、放眼全球”为指导思想, 以发展科技、服务社会为己任, 以成为国际一流高技术公司为目标, 愿与社会各界诚信合作, 共同进步。
单位名称: |
北京市海淀区信息路1号院创业1楼B1室
964339422 849541200
联系电话: |
Email: |
