Kimble Dounce Homogenizer匀浆器
Kimble Dounce Homogenizer匀浆器 885300-0002/885300-0007
名称:杜恩斯组织匀浆器 Dounce Tissue Grinders
品牌:KIMBLE
全WHEATON33低溶出硼硅酸盐玻璃制作,符合ASTM Type Ⅰ Class A和USP type Ⅰ 标准。为高的细胞核和线粒体保留率设计;每一匀浆器配有松型和紧型两根槌;在实际操作中,先用松型槌初步匀浆,再用紧型槌终匀浆;适用于酶科学研究。相比于wheaton产品间隙设计更加精细合理。
Designed primarily for cellular work where the nucleus remains intact after homogenization.
All-glass construction
Two pestles are supplied with each complete unit
Large clearance pestle is used for the initial sample reduction
Small clearance pestle is used to form the final homogenate
Replacement components are available and completely interchangeable
Manufactured from 33 expansion, low extractable borosilicate glass conforming to USP Type I and ASTM E438, Type I, Class A requirements
产品编号 |
产品描述 |
包装 |
市场价 |
885300-0000 |
匀浆体积:0.5ml;紧槌0.0025-0.0055;松0.0005-0.0025 |
1套/箱 |
2443.30 |
885300-0001 |
匀浆体积:1ml;紧槌0.0030-0.0050;松0.0010-0.0020 |
1套/箱 |
2690.28 |
885300-0002 |
匀浆体积:2ml;紧槌0.0030-.0050;松0.0005-0.0025 |
1套/箱 |
3092.02 |
885300-0007 |
匀浆体积:7ml;紧槌0.0008-0.0022;松0.0028-0.0047 |
1套/箱 |
2690.28 |
885300-0015 |
匀浆体积:15ml紧槌0.0010-0.0030;松0.0035-0.0065 |
1套/箱 |
3092.02 |
885300-0040 |
匀浆体积:40ml;紧槌0.0010-0.0030松0.0030-0.0060 |
1套/箱 |
3849.92 |
885300-0100 |
匀浆体积:100ml;紧槌0.0020-0.0100;松0.0005-0.0055 |
1套/箱 |
6217.96 |
Wheaton Dounce Tissue Homogenizer 组织匀浆器357538/357542
Dounce 型组织研磨器
可以将细胞破坏,以提取包括蛋白质、RNA 和DNA 在内的细胞产物,每一套研磨器都包括一个紧研磨棒和一个松研磨棒,适合软组织研磨,Wheaton 33 低析出硼硅玻璃制造,可高压灭菌。
所有的WHEATON组织研磨器都采用33超低析硼硅玻璃制造,符合美国药典和ASTME-438的A类要求,并且它们的配件都是可单独购买的,且可以互相更换。
This tissue grinder is designed to retain a high percentage of cell nuclei and mitochondria in soft tissues or from cell cultures. In operation, the pestle ball is encircled in liquid, which avoids heat buildup by reducing friction. This grinder is ideal for enzyme studies. The initial grinding is performed using the "loose" pestle. The grinding process is completed using the "tight" pestle. This grinder is used by moving the pestle up and down, and works best with cell suspensions or very soft tissue.
The mortar has a large reservoir and pouring lip and is supplied with a "loose" pestle and a "tight" pestle. Two complete sets per case.
Tight Pestle "A" Specification: 0.0010-0.0030 in (0.025 - 0.076 mm), Loose Pestle "B" Specification: 0.0035-0.0055 in (0.089 - 0.14 mm)
订货号 |
规格/描述 |
单位 |
包装数量 |
市场价 |
357538 |
1ml |
包 |
2 |
2443.83 |
357542 |
7ml |
包 |
2 |
2691.02 |
357544 |
15ml |
包 |
2 |
3092.87 |
357546 |
40ml |
包 |
2 |
3850.03 |
北京明阳科华生物科技有限公司
联系人:吴经理
联系电话:13701245989
传真:010-59919166
QQ:204057474/1170535434
Email:mingyangkehua@126.com
地址:北京市朝阳区汤立路216号东方郁金香C座8层
邮编100012
北京祥利盛达生物科技有限公司(BeijingMingyangkehuaBioTechnologyCo.,Ltd.)是一家生产及代理销售生物相关行业高科技产品的公司。公司以经营各种科学实验仪器、生化试剂、实验室消耗品为主,致力引进国外的先进技术及产品,为中国广大客户提供优质服务。公司在北京建立大量库存,能够保证向用户提供迅捷的服务。
公司代理销售特色优势产品:美国Kimble微量电动匀浆器、线粒体提取杜恩斯玻璃组织匀浆器,美国Wheaton低速磁力搅拌器、双侧壁悬浮细胞培养瓶,德国Greiner细菌接种环、培养皿、培养瓶,美国ABI荧光定量PCR耗材,法国Hyphen-biomed发色底物,美国W.S.Tyler筛分仪,加拿大Lablabs无菌采样袋,美国Millipore细胞电阻仪,美国康宁Transwell小室,英国Carbosynth核糖、核苷,瑞士Keller热珠灭菌器,美国Biospec公司MiniBeadbeater系列研磨珠均质器,英国DECON迪康90清洗剂,Gelded核酸染料,美国SignaGen体外DNA高效转染试剂,瑞典Mercodia大、小鼠胰岛素试剂盒等众多国际知名品牌产品。
| 单位名称: |
北京市朝阳区汤立路216号
| 联系电话: |
| Email: |
