216nm 266nm低功率脉冲激光器
Pulsed lasers from the IR to the deep UV ranges of the spectrum are widely used in biology, biomedicine, chemistry, analytics, micromachining and environmental technology.
波长范围覆盖IR到深紫外DUV,广泛应用于生物学、生物医学、化学、分析学、微加工和环境技术领域。
CryLaS provides passively Q-switched laser systems (DPSS) emitting at wavelengths of 213 nm, 266 nm, 355 nm, 532 nm and 1064 nm with excellent beam quality.
Thousands of lasers of the passively q-switched series “FTSS 355-50” have been supplied and are in industrial operation for more than 7 years.
具有1064,532,355,266nm4个波长,以下是具体参数:
1.1064nm
型号 |
DSS1064-Q1 |
DSS1064-Q2 |
DSS1064-Q3 |
DSS1064-Q4 |
DSS1064-Q4_1kHz |
波长 |
1064nm |
脉冲能量 |
>10μJ@15KHz |
>20μJ@15KHz |
>50μJ@15KHz |
>140μJ@200Hz |
>90μJ@1KHz |
峰值功率 |
>6.7kW@15kHz |
>13kW@15kHz |
>33kW@15kHz |
>90kW@200Hz |
>60kW@1kHz |
最大重复频率 |
20 kHz |
10 kHz |
2.5 kHz |
200Hz |
1kHz |
脉宽(FWHMs) |
≤1.5ns |
偏振度 |
≥100:1 vertical |
稳定性(rms,6hours) |
≤5% |
≤3% |
光斑模式 |
TEM00 |
发散角(full angle) |
≤3mrad |
≤4mrad |
光斑大小 |
600±100μm |
500±100μm |
600±100μm |
650±100μm |
650±100μm |
2.532nm
型号 |
DSS532-Q1 |
DSS532-Q2 |
DSS532-Q3 |
DSS532-Q4 |
DSS532-Q4_1kHz |
波长 |
532nm |
脉冲能量 |
>2μJ@15KHz |
>6μJ@15KHz |
>20μJ@15KHz |
>60μJ@200Hz |
>42μJ@1KHz |
峰值功率 |
>1.5kW@15kHz |
>4.6kW@15kHz |
>15kW@15kHz |
>42kW@200Hz |
>30kW@1kHz |
最大重复频率 |
20 kHz |
10 kHz |
2.5 kHz |
200Hz |
1kHz |
脉宽(FWHMs) |
≤1.3ns |
≤1.4ns |
偏振度 |
≥100:1 vertical |
稳定性(rms,6hours) |
≤5% |
≤3% |
≤2% |
光斑模式 |
TEM00 |
发散角(full angle) |
≤3.5mrad |
≤4mrad |
≤4.5mrad |
光斑大小 |
250±50μm |
260±50μm |
300±80μm |
400±100μm |
400±100μm |
3.355nm
型号 |
DSS355-Q1 |
DSS355-Q2 |
DSS355-Q3 |
DSS355-Q4 |
DSS355-Q4_1kHz |
波长 |
355nm |
脉冲能量 |
>0.3μJ@15KHz |
>3μJ@10KHz |
>15μJ@1KHz |
>60μJ@200Hz |
>42μJ@1KHz |
峰值功率 |
>0.27kW@15kHz |
>2.7kW@10kHz |
>15kW@1kHz |
>42kW@200Hz |
>30kW@1kHz |
最大重复频率 |
20 kHz |
10 kHz |
2.5 kHz |
200Hz |
1kHz |
脉宽(FWHMs) |
≤1.4ns |
≤1.1ns |
偏振度 |
≥100:1 vertical |
稳定性(rms,6hours) |
≤5% |
≤3% |
≤2% |
光斑模式 |
TEM00 |
发散角(full angle) |
≤3.5mrad |
≤4mrad |
光斑大小 |
190±50μm |
200±50μm |
200±50μm |
300±80μm |
300±80μm |
4.266nm
型号 |
DSS266-Q1 |
DSS266-Q2 |
DSS266-Q4 |
DSS266-Q4_1kHz |
波长 |
266nm |
脉冲能量 |
>0.3μJ@5KHz |
>1.25μJ@1KHz |
>18μJ@200Hz |
>12μJ@1KHz |
峰值功率 |
>0.3kW@5kHz |
>1.25kW@1kHz |
>18kW@200Hz |
>12kW@1kHz |
最大重复频率 |
5 kHz |
2.5 kHz |
200Hz |
1kHz |
脉宽(FWHMs) |
≤1.0ns |
偏振度 |
≥100:1 vertical |
稳定性(rms,6hours) |
≤5% |
≤2% |
光斑模式 |
TEM00 |
发散角(full angle) |
≤2mrad |
≤1.5mrad |
光斑大小 |
1.0±0.4mm |
以下是4种波长激光器的尺寸图:
1064nm 532nm 355nm 266nm
北京昊然伟业光电科技有限公司成立于 2010 年,专业代理欧美(德国、瑞士、美国、波兰等)高精度的光学检测设备,致力于为科研和工业客户提供一流的光学检测解决方案及包括售前、售中及售后在内的全方位服务。主要包括:
光学检测产品:应力双折射、折射率、弱吸收、反射率、散射等测量系统/剪切干涉仪/非接触式测厚仪/测角仪/可调相位延迟波片等;
激光检测产品:激光功率计、能量计及光束质量分析仪等;
集成系统所需的激光器、步进位移平台、偏振光转换器等
显微系统所需的XYZ电动载物台、波片进片机、高速相机ICCD、像增强器300ps门控时间、FLIM、高精度脉冲延时器等。
值得一提的是,近年来公司科研团队自主研发PCI弱吸收测量仪,CRD光腔衰荡法高反测量仪,偏心曲率测量仪等产品,相关指标达到国际先进水平,为今后的发展壮大奠定了坚实的基础。
昊然伟业凭借在业内的良好信誉,在国内获得了越来越多客户的认可。昊然科技的客户服务理念是:
从项目调研阶段着手,协助客户选择合适的解决方案。
项目启动阶段,协助客户做好各项手续。
项目调试阶段,协助培训操作人员。
项目使用阶段,及时为客户解决遇到的任何硬件及软件问题。
昊然伟业愿以专业的知识、真诚的服务态度,为用户提供专业、快捷、优质的服务。
我们期望为您提供合适的产品,助力您企业的成长。欢迎您通过各种方式联系我们。也请您多关注我们的技术博客:
http://opcrown.i.sohu.com/
| 单位名称: |
北京市海淀区长银大厦12B18
| 联系电话: |
| Email: |
