液相色谱
UltiMate™ 3000 RSLCnano System
进口
美国/Thermo Scientifi
UltiMate™ 300
Optimize your analyses for speed, resolution or sensitivity. The Thermo Scientific™ UltiMate™ 3000 RSLCnano LC system offers better confidence: confidence in performance, confidence in results and confidence in ease of operation. Our 25-year experience in nano LC has resulted in a system that provides better results than ever before, setting a new standard in nano LC applications for Proteomics.
Recommended Use:
■For all proteomics labs looking for the highest performance and usability in nano LC/MS.
■It is easily configured as routine nano LC instrument for LC/MS protein identification.
■The versatility and excellent performance allow users to optimize sample throughput and protein identification.
■Routine, advanced and high throughput proteomics applications, like direct-injection, pre-concentration, 2D-LC techniques or tandem operation, are all supported by standardized workflows.
■Customized application setups are easily established for proteomics, metabolomics, intact protein analysis, biopharma and beyond.
■The system’s dual pumps cover a very wide flow range starting at the very low flow rates from 20nL/min. less than 50µm i.d. to 1mm column i.d. flows up to 50µL/min. with the nano pump.
■The loading pump can deliver accurate gradient from 50 to 2500µL/min. for 2D separations or an occasional analytical flow experiment.
Exceptional Chromatography Performance:
The UltiMate 3000 RSCLnano system delivers the highest level of performance for your low flow applications:
■Up to three times faster than conventional nano LC systems
■Up to twice the resolution of traditional nano LC systems
■Extensive flow-pressure range for maximum application flexibility
■Continuous direct flow delivery enables uninterrupted, very long ultra-high resolution runs
■Optional stainless-steel-free column flow path protects your analytes from modification and degradation
Extended Solution to Match Your Workflows:
■Extensive selection of column formats, traps and chemistries, e.g., 25cm and 50cm long 75µm I.D. Thermo Scientific™ Acclaim™ PepMap™ columns
■Complete MS integration with Thermo Scientific Dionex™ DCMSLink™ software Integrates seamlessly with Thermo Scientific™ EASY-Spray™
■Full range of consumables for all application areas, including nanoViper-based application kits
Choose the Right Configuration for You:
■Nano pump, loading pump and heated column compartment integrated in one setup
■Compact separate and heated column compartment featuring a direct nano/cap/micro flow, binary pump and an exceptionally capable loading pump (NCS-3500)
■Optional two-position, six-port or two-position, ten-port Snap-In nano valves (also PEAK versions)
■Four-channel degasser built into the solvent rack (SRD-3400)
■Thermostatted pull-loop well plate autosampler (WPS-3000TPLRS) or thermostatted fractionation sampler for advanced 2D-LC techniques (WPS-3000TFC)
■Variable wavelength UV detector with large choice of low volume U-Z view flow cells (e.g., 3nL)
■nanoViper MS connection kits for Thermo Scientific mass spectrometers
■Optional EASY-Spray source interfaces
■Optional additional nano/cap/micro flow pump module (NCP-3200)
■DCMSLink system control integration software
服务科学,世界领先--赛默飞世尔科技
赛默飞世尔科技(纽约证交所代码:TMO)是科学服务领域的世界领导者。公司年销售额170亿美元,在50个国家拥有约50,000名员工。我们的使命是帮助客户使世界更健康、更清洁、更安全。我们的产品和服务帮助客户加速生命科学领域的研究、解决在分析领域所遇到的复杂问题与挑战,促进医疗诊断发展、提高实验室生产力。借助于首要品牌Thermo Scientific、Applied Biosystems、Invitrogen、Fisher Scientific和Unity Lab Services,我们将创新技术、便捷采购方案和实验室运营管理的整体解决方案相结合,为客户、股东和员工创造价值。欲了解更多信息,请浏览公司网站:https://www.thermofisher.com/cn/zh/home.html
赛默飞世尔科技中国
赛默飞世尔科技进入中国发展已有30多年,在中国的总部设于上海,并在北京、广州、香港、台湾、成都、沈阳、西安、南京、武汉、昆明等地设立了分公司,员工人数约3700名。我们的产品主要包括分析仪器、实验室设备、试剂、耗材和软件等,提供实验室综合解决方案,为各行各业的客户服务。为了满足中国市场的需求,现有8家工厂分别在上海、北京和苏州运营。我们在全国共设立了6个应用开发中心,将世界级的前沿技术和产品带给国内客户,并提供应用开发与培训等多项服务;位于上海的中国创新中心结合国内市场的需求和国外先进技术,研发适合中国的技术和产品;我们拥有遍布全国的维修服务网点和特别成立的中国技术培训团队,在全国有超过2000名专业人员直接为客户提供服务。我们致力于帮助客户使世界更健康、更清洁、更安全。欲了解更多信息,请登录网站 https://www.thermofisher.com/cn/zh/home.html
联系方式:
电话:800-810-5118, 400-650-5118(支持手机)
售前咨询电子邮箱:sales.china@thermofisher.com
售后服务电子邮箱:cru.cn@thermofisher.com
扫一扫,关注
“赛默飞色谱与质谱中国”官方微信
上海市浦东新区新金桥路27号3& 6& 7号楼
