医学检验仪器
厂家热卖YBDX-98-7电动吸痰机
厂家热卖YBDX-98-7电动吸痰机
慧科
YBDX-98-7
YB·DX-98-7 ELECTRIC PORTABLE ABSORB PHLEGM UNIT/电动吸痰机
电动吸痰机产品特点:
1、电动吸痰机采用无油自润滑的单柱塞泵作负压吸引源,由负压泵(单柱塞泵)、负压调节器、负压指示器、收集容器组件、机箱等组成;
2、具有可根据病人的痰液的粘稠度进行无级调压的特点,能迅速吸出浓痰和粘液,减轻病人痰阻塞的痛苦,起到转危为安的作用;
3、本机具有溢流阀安全装置,安全可靠;
4、本机按防电击类型及程度分类为Ⅰ类设备B型应用部分,运行模式为连续运行,IPX0、非AP型或APG型普通设备;
5、产品符合GB9706.1、YY0505、YY0636.1相关要求。
技术指标:
1、负压极限值:≥0.08MPa(600mmHg);
2、负压调节范围:0.02~0.08MPa(150~600mmHg);
3、抽气速率:泵口(出气口)≥10L/min,终端≥6L/min;
4、电源:AC220V±22V,50Hz±1Hz;
5、消耗功率:≤30VA;
6、噪声:≤60dB;
7、收集容器容量:1000mL;
8、工作环境:温度:+5℃~+35℃,相对湿度:25℃不超过80%,大气压力:86KPa~106KPa。
FEATURES:
1、Electric absorb phlegm unit adopts oil-free self-lubricating single plunger pump as suction source of negative pressure, comprised of negative pressure pump (single plunger pump), negative pressure regulator, negative pressure indicator, collection container assembly and framework etc.;
2、It can execute the stepless pressure regulation according to the viscosity of patient's phlegm, the phlegm and mucus can be sucked out rapidly, relieve the patient's pain causing by phlegm blocking thus to be out of danger;
3、Overflow valve safety device is equipped, safe and reliable;
4、According to shock proof type and degree, the electric suction apparatus is divided into class Ⅰ device type B application part, run mode is continuous, IPX0, none AP type or APG type common devices;
5、The products meet related requestments of IEC60601-1,IEC60601-1-2,ISO10079-1.
TECHNICAL SPECS:
1、Negative pressure limit: ≥0.08MPa(600mmHg);
2、Negative pressure adjustable range: 0.02~0.08MPa(150~600mmHg);
3、Pumping rate: hole (air vent)≥10L/min, terminal≥6L/min;
4、Power: AC220V±22V, 50Hz±1Hz;
5、Input: ≤30VA;
6、Noise: ≤60dB;
7、Collection container capacity: 1000ml;
8、Work environment: temperature:+5℃~+35℃, relative humidity: 25℃ no exceeding 80%, atmospheric pressure: 86KPa~106KPa.
公司注重产品质量管理,完善配置了确保产品质量的各种检测手段和调测试设备,同时配齐了生产过程中所需的各种生产设备,完全满足了批量规模生产内外销产品的需求,公司通过了ISO9001和ISO13485质量体系认证,连续10年被资信评估公司评为“AAA”资信企业,连续8年被评为“AA”重合同守信用及质量信得过单位,为所属国省区医疗器械行业协会会员单位,提有所属国食品药品监督管理部门颁发的医疗器械产品出口销售证明书,多次在所属国省市卫生厅装备项目招标中中标,产品还多次批量出口东南亚市场,受到了国际用户的信赖与好评,2009年成功完成所属国援摩尔多瓦医疗设备项目。
江苏省江都市仙女镇双仙北路258号
