全自动微孔板封板机
Automatic Heat Sealer a4S
Crucially the a4S does not require an air supply, allowing for it’s flexible use on standard lab benches as a standalone
unit, or integrated within a robotic set‑up. The sealer has a rapid heating element, for fast start-up, and has a
stand-by function, to save energy when not in use.
The a4S sealer is compatible with a wide range of plates, from 384well and 24well PCR plates to deep well or storage
plates, with an SBS footprint. Varying plate heights, from 3mm to 60mm, can be accommodated with minimal
adjustments on the instrument. Plates are presented in the portrait format and the plate position on the shuttle
allows good access for robotic integration.
Rolls with a width between 75—85mm can be loaded in either of two roll positions, depending on roll length and
available space, enabling the entire instrument to fit under the gantree of most liquid handling robots.
The roll width covers an SBS footprint microplate and the seal is cut at the end of the plate. The seal position can
be adjusted to either lay flat on the plate surface or to give an overhang at one end, to make seal removal more
convenient without interfering with plate stacking.
Features
FLEXIBLE INSTALLATION
Installation
• No need for compressed air — Installation is fast and flexible, internal compressor for highest
reproducibility
• 2 roll positions dependent on available space and roll size — Higher flexibility
• Optional roll cover — Seal protection for sensitive applications
EASY HANDLING
Handling
• Colour touch screen with intuitive user interface — Easy and intuitive usability
• Unlimited, password protected protocols — 3 security levels to save
personalised and SOP temperatures and times
• Rapid heating — Fast ramp up, block uniformity of ± 1°C
• Up to 5,000 seals without manual intervention — True walk-away-system
REPRODUCIBLE SEALING
Sealing
• Reproducible sealing – A fixed pressure and variable time/temperature
settings enable consistency of sealing
• High sealing pressure — Improved seal uniformity on the widest range of
plates
• Sealing cycle time of less than 15sec — Time saving
HIGHEST FLEXIBILITY
Flexibility
• Compatible with a wide range of plate types, including 1536 well
PCR plates — Highest flexibility
• Flexibility of seal material choice — 4titude offers a wide range of
sealing materials for use with the a4S
• Compatible with gas permeable heat seals — No instrument
modification necessary for highest convenience
ECONOMIC EFFICIENCY
Economic efficiency
• Attractive pricing — Save money without compromises
• Auto standby mode — Saves energy and prolongs component life
• 2 year warranty on parts and labour
Apricot Designs致力开发适合于高通量和药物筛选的“多通道微量移液”应用技术,主要为制药业提供定制型实验设备和配件。公司总部成立于 1989 年,位于美国加利福尼亚州。
公司所提供的移液处理技术既准确,又经济,凭借多年来在移液处理技术领域上所吸取的宝贵经验,建立并完善了“多通道移液工作站”的设计和应用,使其在功能、效率、精准度和整体性能上表现出色。十多年来,我们为辉瑞、药明康德、葛兰素史克、阿斯利康等许多其他客户提供了他们满意的产品。一直以来,使我们能够持续发展并取得成功的关键,在于与我们密切合作的客户不断提供宝贵的反馈信息。因此,我们的产品总是能够优先体现业内最新需求。为了进一步帮助客户在竞争中独占鳌头,我们还提供定制化设计、咨询、仪器制造和改造。
杰出的工作理念与创新合理的产品是我们全体员工的共同追求。我们将竭尽全力满足客户需求!
