伯乐biorad Universal通用电源(现货)及维修
Output specifications | 500 V, 2.5 A, 500 W |
Output range (programmable) | 10–500 V, fully adjustable in 1 V steps 0.01–2.5 A, fully adjustable in 0.001 A steps 1–500 W, fully adjustable in 1 W steps |
Type of output | Constant voltage, constant current, or constant power with automatic crossover |
Output terminals | 4 pair recessed banana jacks floating in parallel |
Timer control | 1 min–99 hr 59 min, fully adjustable |
Volt-hour control | 99,000 V-hr |
Pause/resume function | Yes |
Programmable methods | Stores 9 methods, each with up to 9 steps |
Real-time clock | Yes |
Automatic recovery after power failure | Yes |
Display | 128 x 64 pixel, backlit graphics LCD |
Safety compliance | EN61010 |
EMI | Conforms to CE standards for emissions and immunity class A, tested at 120/230 V. TÜV EMC certification |
Safety features | No-load detection, sudden load change detection, ground leak detection, overload/short circuit protection, overvoltage detection, input line protection, auto power-up after power failure |
Input power (nominal) | 100–120/220–240 VAC, 50/60 Hz, autoswitching |
Operating conditions | 0–40°C, 0–90% humidity in the absence of condensation |
Dimensions (W x L x H), cm/in | 27.5 x 34 x 10/10.8 x 13.4.x 3.9 |
Weight, kg/lb | 2.5/5.5 |
一家经营进口实验室分析仪器及配件的专业公司。于2003年注册成立,在公司发展壮大的10多年里,我们始终为客户提供好的产品和技术支持、健全的售后服务。
