细胞生物学试剂
PeproTech重组人B7-H2 Fc
Recombinant Human B7-H2 Fc
进口
美国/PeproTech
20ug/100ug/250ug/50
询价
Catalog Number:
310-37
Synonyms:
Inducible Costimulator-Ligand (ICOSL), B7 homolog 2, B7-like protein Gl50, B7-related protein 1 (B7RP-1), CD275
Description:
B7-H2, or inducible costimulator-ligand (ICOSL), is a transmembrane, co-stimulatory ligand of the T cell-specific surface receptor Inducible T-cell costimulator (ICOS) that belongs to the B7 family and immunoglobulin superfamily, along with B7-1, B7-2 and PD-L1 (B7-H1) and PD-L2. Whereas expression of inducible B7-1 and B7-2 is largely confined to specialized antigen-presenting cells of lymphoid tissues, B7-H2 expression occurs constitutively in hematopoietic and non-hematopoietic cells of peripheral organs. This striking difference in expression indicates that these three B7 ligands may enable temporally and spatially specific regulation of T cell response through non-competitive CD28 interaction; marking a unique function of B7-H2 in immune reactions of nonlymphoid organs in which T cells have migrated to peripheral tissues having only limited expression of B7-1 and B7-2. Expression of B7-H2 has been shown to be differentially regulated by both TNF-α and IL-1β, and inducible to a lesser extent by CD40 or lipopolysaccharide stimulation. B7-H2’s binding to ICOS on activated T cells results in both positive and negative effects on immune response, including its own downregulation. As a member of the immunoglobulin superfamily, B7-H2 is crucially involved in inflammatory immune reactions and the control of excessive immune response; however, unlike B7-1 and B7-2, B7-H2 has not been shown to influence immunity through interaction with CTLA-4, and has only been shown to have restricted interaction with CD28. Interaction of B7-H2 with ICOS has been identified as a critical event in the immunosuppression of tumor-associated memory CD4+ T cells, and has been linked to various auto-immune disorders. PeproTech’s CHO cell-derived Recombinant Human B7-H2 Fc is a glycosylated, disulfide-linked homodimer of 942 amino acid residues whose monomer consists of the 238-amino-acid length extracellular portion of B7-H2 fused to the 231-amino-acid length Fc portion of human IgG1 by two glycines. The calculated molecular weight of Recombinant Human B7-H2 Fc dimer is 104.9 kDa; however, due to glycosylation, it migrates at an apparent molecular weight of approximately 90-95 kDa by SDS-PAGE analysis under reducing conditions.
AA Sequence:
DTQEKEVRAM VGSDVELSCA CPEGSRFDLN DVYVYWQTSE SKTVVTYHIP QNSSLENVDS RYRNRALMSP AGMLRGDFSL RLFNVTPQDE QKFHCLVLSQ SLGFQEVLSV EVTLHVAANF SVPVVSAPHS PSQDELTFTC TSINGYPRPN VYWINKTDNS LLDQALQNDT VFLNMRGLYD VVSVLRIART PSVNIGCCIE NVLLQQNLTV GSQTGNDIGE RDKITENPVS TGEKNAATGG PKSCDKTHTC PPCPAPELLG GPSVFLFPPK PKDTLMISRT PEVTCVVVDV SHEDPEVKFN WYVDGVEVHN AKTKPREEQY NSTYRVVSVL TVLHQDWLNG KEYKCKVSNK ALPAPIEKTI SKAKGQPREP QVYTLPPSRD ELTKNQVSLT CLVKGFYPSD IAVEWESNGQ PENNYKTTPP VLDSDGSFFL YSKLTVDKSR WQQGNVFSCS VMHEALHNHY TQKSLSLSPG K
Source:
CHO cells
Purity:
Greater than 95% by SDS-PAGE gel and HPLC analyses.
Biological Activity:
Determined by its ability to induce adhesion in Jurkat cells activated by immobilized anti-CD3. The ED50 for this effect is 0.3-0.6 μg/ml.
Cross Reactivity:
Human
Research Interests:
Country of Origin:
USA
PeproTech Inc. 创立于1988年,始终致力于为生命科学研究开发重组蛋白及相关产品,如今已成为能提供多种高质量细胞因子和重组蛋白,相应的单克隆、多克隆和生物素标记抗体,以及ELISA试剂盒的世界领导者。PeproTech Inc.的产品涵盖免疫调节蛋白、白介素、集落刺激因子、生长因子、化学趋化因子、干扰素、脂联素、成纤维生长因子、转化生长因子、肿瘤坏死因子、神经营养素和防御素等诸多生命科学研究领域中重要的生物活性分子。
为跟踪当今科研发展、满足日益增长的需求,PeproTech Inc.研制出无动物成分的重组蛋白(animal-free recombinant proteins)。有效地避免了动物源性污染引发潜在问题的可能性,从而可以应用于临床前研究和细胞治疗。此外,PeproTech Inc.最新还开发出无动物成分的培养基添加物试剂盒(animal-free Media Supplement Kits)。这些试剂盒经改良设计,其中的无血清组分对多种哺乳动物细胞的生长有更好的维持能力。
PeproTech Inc.的产品自2000年进入中国市场以来,以其优良的品质和合理的价格迅速得到国内各重点研究和实验机构的认可和青睐。鉴于中国经济发展的良好态势和中国生物医药研发投入的巨额增长,PeproTech Inc.于2009年10月在中国苏州设立代表机构,意为中国的广大用户提供更好的支持和服务,并助中国的科研和产业开发一臂之力。
江苏省苏州市工业园区星湖街218号A1北座4楼L03
0512 6832 5983
