转基因仪
伯乐biorad MicroPulser电穿孔仪(现货)
biorad MicroPulser Electroporator
进口
Bio-Rad
biorad MicroPulser
询价
●是一种设计简单的多功能电穿孔仪,可安全高效地转化细菌、酵母及其它微生物。
●设计简单,一个按钮的脉冲传输,直接与电激杯室连接
●预置优化的程序,用于常用的细菌和真菌样品,程序选择快速
●弧光保护系统,减少贵重样品的损失
●提供广泛的参数选择,电压范围是200-3000V,精确度为10V;脉冲宽度是1.0-4.0mS,
精确度为0.1mS
The MicroPulser electroporator is a simple yet versatile instrument that enables safe and reproducible transformation of bacteria, yeast, and other microorganisms. Transformation efficiencies much higher than those obtained with chemical methods can be achieved.
Key Features
  • One-button pulse delivery, attached cuvette chamber, and rapid charge time for fast sample handling
  • Preset, optimized programs for commonly studied bacteria and fungi allow rapid program selection
  • Arc quenching (ARQ) system significantly reduces arcing, protecting against loss of valuable samples
  • Broad range of parameters for manual optimization. Manual programming allows voltage to be selected in a 200–3,000 V range with 10 V precision and allows pulse width to be selected in a 1.0–4.0 ms range with 0.1 ms precision
  • High-voltage 3,000 V capability yields improved efficiency in larger-volume cuvettes
  • Compact, space-saving design
  • Audible and visible pulse indicators
  • Time constant and actual volts displayed to monitor reproducibility
Outputs Waveform: decaying or truncated decaying exponential-decay with resistor capacitor time constant
Voltage and current: 3,000 V peak into >600 W load; limited at 100 A peak maximum
Output voltage and pulse duration adjustment Voltage adjustable in 200–3,000 V range with 10 V precision; 5 ms default or 1–4 ms with 0.1 ms precision.
Input voltage 100–120 V or 220–240 V
Preset protocols 5 bacterial, 5 fungal
Operating environment 3.5–35°C
Dimensions (W x D x H) 29 x 21 x 8 cm
Weight 2.9 kg
一家经营进口实验室分析仪器及配件的专业公司。于2003年注册成立,在公司发展壮大的10多年里,我们始终为客户提供好的产品和技术支持、健全的售后服务。
本公司有专业队伍,全面维修进口生物器材:擅长离心机,PCR,紫外分光光度计,酶标仪,电泳系统,超低温冰箱,制冰机,培养箱。保修一年。
浦东金桥出口加工区金沪路1269号
