医学检验仪器
遥感勘测皮肤&体内温度,心率呼吸
遥感勘测皮肤&体内温度,心率呼吸
VitalSense Telemetric Physiological Monitoring System
进口
USA/Mini Mitter
VitalSense
VitalSense遥感勘测皮肤&体内温度,心率呼吸
遥感勘测皮肤&体内温度,心率和呼吸速率
Real-time Temperature Monitoring
Along with real-time monitoring of temperature data using the VitalSense Monitor, you can also monitor it on your PC. Just connect the Monitor to the PC and click the "Real-Time" button on the application program's front display.
PC Requirements
  • Operating System: Windows '98, ME, 2000, NT 4.0, and XP
  • Pentium II Processor (266 MHz or higher)
  • 64 MB of RAMCD-ROM Drive
  • 9-pin or 25-pin RS-232 serial communications port
VitalSense Integrated Physiological Monitor
Go Wireless with VitalSense!
Monitor your subjects without the nuisance of wires or probes that can get tangled, snagged, pulled at and pulled off. VitalSense wireless sensors free your subjects and provide a more convenient, reliable and satisfying solution. The VitalSense System includes wireless sensors, a small monitor, software and accessories. VitalSense is designed to be effective for monitoring temperature, in active or inactive subjects and in indoor and outdoor environments such as:
  • Clinical trials
  • Sports Medicine Research
  • Exercise Physiology
  • Military medicine/military training
  • Pre- or post-operative outpatient monitoring
  • Healthcare telemedicine
  • Hazardous occupations
VitalSense monitors can receive transmissions from multiple miniature, wireless, temperature sensors. Core temperature is sensed by the ingestible capsule. Dermal temperatures are recorded from hypoallergenic, non-irritating, adhesive dermal patches.
Both sensor types are disposable, but designed for multi-day use under demanding physical and environmental conditions. Both types of sensors use low-power radio frequency transmissions to communicate with the Monitor.
Click here to download brochure
Click here to download technical data sheet
Temperature Sensors
VitalSense offers two types of temperature monitoring - core body and skin temperature. The new technology employed by VitalSense disposable telemetric sensors provides accurate data that can be transmitted and logged continuously for up to 10 days. The unique ID of each sensor is automatically identified by the VitalSense monitor to avoid cross-talk among sensors on the same subject or in close proximity.
Core body temperature (CBT) is measured by an ingestible, biocompatible, and easy to swallow capsule that is disposable. Skin temperature is measured by a hypoallergenic and water-resistent dermal patch that is also disposable.
Ambient skin temperature is measured with the dermal patch that can be placed at many different locations on the body to record skin temperature
VitalSense-XHR Heart Rate & Respiration Sensor
The VitalSense-XHR sensor is an innovative, compact device that wirelessly transmits Heart Rate and Respiration Rate to the VitalSense telemetric physiological monitoring system. This state-of-the-art sensor enables researchers to monitor heart rate and respiratory rate on ambulatory subjects.
The XHR is a chest-worn wireless physiological monitor that incorporates an ECG-signal processor. It attaches to two standard ECG pads or to a dry electrode band. The XHR senses heart rate and respiratory rate and transmits the data in near real time to the VitalSense monitor four times per minute. The monitor logs the data in nonvolatile memory.
Use with Other Devices
VitalSense functionality can be supplemented through the use of our Actical device. Caloric expenditure is calculated from movement recorded by the Actical device worn on the waist. Data from this device is transcribed to a format that allows both sets of data to be synchronized for an integrated analysis.
VitalSense Monitor
  • Activates the sensors
  • Tracks and records sensor data
  • Displays data in a convenient numeric table or as a trend graph
  • Functions as the computer interface
  • Stores data in a nonvolatile memory
  • Transfers data to PC
  • Continuously logs data
  • Monitors and tracks up to 10 sensors
  • Designed for research, clinical and ambulatory applications
After sensor activation, each sensor transmits its first value to the VitalSense Monitor within 15 seconds and then takes another reading every 15 seconds. Transmission to the monitor occurs four times a minute on a transmission schedule that is synchronized with the monitor.
The subject wears the monitor which is then able to receive the sensor transmissions. The monitor logs and displays the data.
Ingestible Capsule
  • Easily ingestible and disposable
  • Comparable in size to a vitamin or a large gel capsule
The monitor is used to activate the capsule sensor. The capsule is swallowed with liquid. Transmission begins 15 seconds after activation and then occurs four times per minute. The capsule easily travels and passes through the GI tract without affecting bodily functions. Transmit time varies with individual; 12-48 hours is typical.
Graph2
Graph showing high degree of correlation
between VitalSense capsule
and rectal probe
Dermal Temperature Patch
This superior temperature measurement solution can assist investigative researchers in the measurement of peripheral temperature. When used in association with ingestible capsules and heart rate sensors, peripheral temperature may be compared with core body temperature, heart rate, and activity. Integration of these parameters is important for the evaluation and treatment of many indications.
  • Waterproof
  • Hypoallergenic adhesive
  • Smooth, comfortable and easy-to-use
  • Battery life of 10 days following activation
The monitor is used to activate the dermal temperature patch. The dermal temperature patch can be placed at many different locations on the body to record skin temperature. Multiple dermal patches can be monitored simultaneously.
XHR Heart Rate and Respiration Rate Sensor
The VitalSense-XHR sensor is an innovative, compact device that wirelessly transmits Heart Rate and Respiration Rate to the VitalSense telemetric physiological monitoring system. The monitor is used to activate the state-of-the-art XHR sensor enabling researchers to monitor heart rate and respiratory rate on ambulatory subjects. Data is transferred near real time to the monitor four times per minute.
  • Chest-worn, wireless physiological sensor that incorporates an ECG-signal processor
  • It attaches to two standard ECG pads
  • Accurate
  • Water-resistant
  • Lightweight
  • Comfortable
Medic Mode
Medic Mode is a special function that enables the VitalSense monitor to detect and record signals from any VitalSense sensor that is within reception range. It displays and records sensor ID, time stamp and temperature value for each sensor transmission that is detected.
Software and Analysis
The VitalSense application program is simple-to-use software utility that communicates with the VitalSense Monitor via an RS-232 cable. With this link, a variety of functions can be accomplished:
  • Setup of the VitalSense Monitor
  • Setup and initialization of the sensors
  • Real-time temperature data monitoring
  • Retrieval of recorded data from the VitalSense Monitor
Recorded Data Analysis Example
The VitalSense application program automatically extracts your data to an Excel
file type for easy graphing and analysis. It can also be combined with other data, for a more complete analysis of your subjects.
Graph combining core, dermal, and
rectal temperatures, plus
Actical activity data
美国健康医疗仪器国际公司AHMSIC于新世纪之初创建于美国纽约,借新世纪之春风快速成长。 AHMSIC是一家专门从事医学科研和临床仪器应用的高科技企业, 志力于心血管,呼吸及神经生理和药理科研仪器的应用:
•心血管-血压,血流,心脏功能及小血管研究: 压力及线性肌动图(Myograph,USA); 光谱成像血流分析仪; 超声血流计,激光血流计, ECGenieTM是唯一的真实地非侵入性地记录神志清楚的小鼠、大鼠和荷兰猪的心电图; 无创小鼠心脏功能及血流动力学动态连续研究系统(Indus Instruments, USA); 无创小动物脉搏血氧仪MouseOx; 精确的尾套法测定血压(USA); 实验动物心脏起搏器; 动物血管封堵器OC Vascular Occluders. 美国肌细胞收缩测定与分析系统Integrated System for Myocyte and SMC Contractility Measurements;
• 神经科学: 行為分析、疼痛研究、脑切片机: 动物行为轨跡-LABORAS &及超音波分析仪-SONOTRACK系統; 新一代振动脑切片机 Compresstome (USA); 动物行为波谱测定仪Behavioral Spectrometer. VCU动物颅脑损伤仪-颅脑创伤模型制作; NYU脊髓冲击损伤仪-脊髓冲击损伤模型制作
• 呼吸研究:CWE生理及呼吸研究仪器; 小动物呼吸机&麻醉系统, CO2 及 O2分析仪, 呼吸及代谢分析系统.
•生理药理和临床教學設備: 美国IWORX产品包括生理学教学设备、网络工具、数据记录主机、信号调节器、各种(ECG、EMG、EEG、PH值及张力、位移、血压、温度等)换能器及附件。在教学方面可以提供全面的人体生理学、动物生理学及心理生理学实验用工具包。在研究方面可以应用于血液动力学、神经系统科学、离体器官和组织试验、药理学等领域。和BIOPAC、POWERLAB并称三大生理研究和教学仪器公司。
•细胞生理:激光扫描,萤光离子,机械牵拉, 電生理:膜片钳放大器, 微量测定一氧化氮NO, 多巴胺, PO2和Dissolved Oxygen , pH, ion, redox, 细胞机械牵拉仪器 STREX - Mechanical Cell Strain Instruments ; 四通道or八通道可编程超微射灌系统; 超微细胞注射泵, 可编程微针拉针器; 显微锻针磨针器
•给药/采样: Alzet 植入式胶囊渗透压泵-- 胶囊大小的滲透压泵植入实验动物皮下或腹腔内, 直接或通过导管以 µl/小时 的速度持续准确地送出測試药剂入作用部位,最長可达6个星期; PE导管(PE10, PE50 & PE60 From USA); 精确可编程序的注射器微量注射泵(USA);
•无创无线遥测: 活动量、体温、心率; VitalView-無線遙測实验动物生理及行为Telemetric Physiological & Behavioral data acquisition system; 無線遙測实验动物Temp., Activity, & Heart Rate; 无创无线遥测心电图 (ECGenie TM, USA);
•低氧研究--Hypoxic Chambers气体O2/CO2/N2自动调控系统; 细胞低氧研究的新工具-镜下温控低氧小室; 高原低氧训练MAG-10.
•运动医学,行为及肥胖研究的最新武器--精确心率,运动量及热卡消耗监测仪.(USA)
•显微外科手术設備: 眼科手术剪(USA). 微型手术镊 (USA), .
• 动物小肠动力学研究-Gastrointestinal Motility Monitor & 膀胱动力学研究--膀胱内压监测系统Mouse Cystometry.
•样品均质:  冷冻细胞粉碎机Frozen Cell Crusher:CRYO-P.
•肥胖,内分泌和代谢研究- EchoMRI 清醒小動物體脂肪水份分析仪.
成都市金牛区一环路北一段88号新熙门2幢624室
028-86653817
400-6762467
