其它各类仪器
X射线晶体分析仪
X射线晶体分析仪
X-ray crystal analysis meter
奥龙
JF-2000型
用途 Function
X射线晶体分析仪用于研究物质内部微观结构,如:单晶定向,检测缺陷,物质定性,测定点阵参数,测定残余应力等
F-2000 Model X-ray crystal analysis meter is used for inspect the inner micro structure unkown,for example: single crystal direction,inspecting flaw defects,fix the nature,measure the lattice  parameters,measure the remainder stress and others.
X射线发生器 X-ray generator
●管电压:10-60KV由单片机自动控制(lkv / step)
●管电流:5-80m A 由单片机自动控制(lm A / step)
●管电压,管电流稳定性≤0.03% ;
●PLC模块控制,设定参数,定时关机
●额定输出功率:3KW
●有无压,无流,过压,过流,过功率,无水,X射线管超温分配保护.
●Tube voltage:10-60kv controlled by auto- singlechip (lkv / step)
●Tube current: 5-80m A  controlled by auto- singlechip (l m A / step)
●Stability of tube voltage,tube current ≤0.03%;
●Control by PLC module,pre-set parameters and auto-closed by setting time.
●Output rating:3KW
●There is protection device for non-voltage,non-current,over-voltage,over-power,non-water and for over-temperature of tube inserted.
冷却循环系统 Cooling system
自带制冷系统,无需外接循环水,并自动控制水温具有水温显示水压,水流量保护功能。
采用不锈钢水泵,噪音为20分贝,并避免水锈的产生,不使X射线管堵塞
There is cooling system in machine ,no need the external connection of recirculated water,and also display the temperature pressure of water AT the sometime ,protect the flow rate.
It adopts stainless steel pump whose noise is 20 DB who can avoid producing water rust in order to not block X-ray tube inserted
X射线防护罩 X-ray shield
●采用高密度,高透光性的铅玻璃作为X射线防护装置,外射线泄漏量不大于2.5μ sv/h
●X射线管靶材:Cu,Fe,Co,Cr,W,Mo任选其一
●额定功率:2KW
●焦点尺寸(mm):点焦点(0.1 x0.1),线焦点(0.1 x0.1)
●额定电压:60KV
●额定电流:80mA
●可配置德拜相机、劳厄相机或其他型号国产进口相机。
●It adopts high density and high transmission of light lead glass,so promise the outside dose of X-rays is less than 2.5μ sv/h
●X-ray tube target material:Cu,Fe,Co,Cr,W,Mo(Option)
●rating power:2KW
●Focus  size: point focus(0.1 x0.1),line focus(0.1 x0.1)
●Rating voltage:60kv
●Rated current:80mA
●Camera can choose the one made in China and also choose the one imported.
丹东奥龙射线仪器集团有限公司是中国射线仪器行业技术力量与综合实力雄厚的民营高科技企业。奥龙集团传承50余年中国射线仪器研制历史。目前,奥龙集团旗下拥有上海奥龙星迪、丹东奥龙电子、奥龙检测服务、丹东奥龙中科传感技术四个子公司。奥龙是专业X射线仪器和材料试验仪器的开发商和产品制造商,也是X射线检测解决方案的服务商。
奥龙集团坐落于辽宁省“五点一线”沿海经济带上的丹东临港产业园区;占地面积3万平方米,建筑面积1.7万平方米;拥有一支技术过硬、经验丰富的科研团队;拥有完善的企业管理系统和行业领先生产环境及配套设施;奥龙集团与无损检测行业的全球领导厂商美国GE成功牵手,进一步巩固了奥龙集团在国内市场的领先地位。中国发射的“神舟载人飞船”有多项系统使用奥龙集团生产的X射线探伤设备实施无损检测,并取得成功,奥龙人为中国航天事业发展做出了贡献。
奥龙集团以“更安全,更可靠,更精准”为制造理念,不断地突破自我,引领创新,成功研发出目前国内技术领先的CT检测设备,并荣获国家改革开放40周年机械工业杰出产品奖,在奥龙设立辽宁省工业CT仪器技术专业创新中心。奥龙集团还将继续坚持自己精益求精的作风,为客户提供更先进更优质的产品和服务而不懈努力。
奥龙主要荣誉:
● 国家首批高新技术企业
● 通过ISO9001国际质量体系认证
● ISO14001国际环境管理体系认证
● ISO45001国际职业健康安全管理体系认证
● 通过欧盟CE认证
承担国家重大科学仪器设备开发专项
国家x射线实时成像高技术产业化示范工程基地
全国模范院士专家工作站
● 丹东市市长质量奖
● 辽宁省企业技术中心
● 辽宁省著名商标
● 辽宁省名牌产品
● 辽宁省软件企业
拥有百余项国家专利和计算机软件著作权
改革开放40周年机械工业杰出产品奖
辽宁省工业CT仪器技术专业创新中心
奥龙主导产品:
● 工业CT ● X射线衍射仪
● X射线探伤机 ● X射线晶体定向仪
● X射线数字成像检测系统 ● X射线荧光光谱仪
● 便携式DR数字成像检测仪 ●活体小动物2D、3D成像系统
● 管道爬行器 ● 生物学X射线辐照仪
●微焦点X射线检测系统 ●X射线检测服务
●开放式微焦点X射线管 ● 安全检查仪
●材料试验机 ● 硬度计
产品应用领域:
航空航天、兵器、船舶 电力、电子、管道检测
● 铸件检测 安检、防爆检查
轮胎、轮毂检测 珠宝、文物古董,岩心检测
直缝、螺旋钢管、锅炉焊管 ● 医疗、生物检测
材料质量检测 ● 植物、种子检测
焊接质量检测 ● 辐照检疫检测
管道检测 ● 小动物辐照研究
航空航天、兵器、船舶工业 ● 药品、食品检测
● 气瓶检测 ● 蓝宝石、单晶硅定向
● 火车各部件检测 ● 材料分析、物相分析
  奥龙长期专注于无损检测、材料试验机等系列产品的研发与运营,产品不仅畅销国内市场,而且还远销美国、德国、英国、印度、澳大利亚、荷兰、马来西亚、印尼、泰国、南非、沙特阿拉伯、香港、台湾等世界五大洲的50多个国家和地区。被广泛应用于国防、航空航天、造船、汽车、压力容器、机械、冶金、石油化工、电子信息、输变电、耐火材料、食品安全、科技教育、卫生等行业领域。
  奥龙,一个立足丹东,产品辐射国内外市场的集团企业,正以技术、管理、品牌和规模的企业优势,紧紧围绕“提升核心能力,打造奥龙国际品牌”的战略,积极推动企业向着更高水平的目标迅猛发展。
辽宁省丹东市振兴区临港产业园区富民大街46号
