超纯水/纯水
密理博超纯水机 Milli-Q Advantage A10
进口
Merk Millipore/密理博
Milli-Q Advantage A
上海金甚生物科技有限公司是Merk Millipore/密理博超纯水机 Milli-Q Advantage A10上海地区医院系统授权代理商,咨询电话:021-51019318
概述
Milli-Q® Advantage A10 has been designed to deliver the highest quality ultrapure water for all your applications, even the most critical ones. It is adapted to suit every user’s needs in today’s demanding laboratory environment. The system produces ultrapure, Type 1 water from a pretreated water source. It features two separate and distinct components:
  • The Milli-Q® production unit – compact, it can be placed wherever it best suits you.
  • The Q-POD®, Quality-Point-Of-Delivery unit – always within reach, it brings ultrapure water right where you need it.
Milli-Q® water • Best-in-class purity
To reach the most reliable ultrapure water quality, Milli-Q® is built on an optimized purification sequence:
  • Pure water, ideally from an Elix® system, first enters the Q-Gard® purification cartridge selected based on the feed water source.
  • Purified water then passes through a long-life dual wavelength UV lamp, which ensures organic molecule degradation by photooxidation.
  • Next, the Quantum® polishing cartridge removes ionic and organic contaminants below trace levels.
  • Finally, the ultrapure water recirculates through a loop to the Q-POD® unit, where an Application-Pak removes specific contaminants critical for your experiments – Ultrapure water free of particulates, bacteria, pyrogens, nucleases, proteases, VOCs, endocrine disruptors and organics for LC.
Made only for Milli-Q® systems, Jetpore® virgin ion-exchange resin is used in all Milli-Q® purification cartridges. Selected for its exceptional performance, it can capture even the most weakly charged ions due to its kinetic capabilities. Both Q-Gard® and Quantum® cartridges also incorporate RFID technology. This provides instant visibility on cartridge parameters and also ensures a safe & optimal performance of your system, giving you full traceability.
Q-POD® dispenser • Advanced technology
The Q-POD® dispenser simplifies operation and displays essential data in an easy-to-use and compact device.
  • Facilitate your daily lab work - The Q-POD® remote dispenser is always within reach. Its convenient and adaptable handling enables both intuitive and precise dispensing. The user can select either a specific volume with the autofill key or manually press the plunger. Its multicolor graphic display allows easy interaction with the system and provides information about water quantity and quality.
  • Free up space on your bench - As only the Q-POD® is necessary for daily needs, the system can now be placed where it is most convenient – under the bench, on the wall… Up to three Q-POD®s can be used with each production unit at different locations within the same laboratory.
  • Get the right water quality for your experiments – Fitted to each Q-POD®, an Application-Pak provides final polishing to match the water quality according to your application’s exact needs. A range of POD-Paks is available for you to select from.
Total control for peace of mind
The combination of both resistivity and Total Organic Carbon (TOC) monitoring allows control over both ionic and organic contaminants that can impact research results. Calibrated meters are used to measure the quality of ultrapure water.
  • Accurate A10® TOC monitor
  • High-sensitivity resistivity cells
To always ensure the finest quality is available, the Milli-Q® Advantage A10 integrates advanced control settings with alerts & alarms that are customizable according to your specific needs. This is to validate your system is properly operating, providing the best working conditions for your experiments. With easily replaceable cartridges, a long-lasting UV lamp and timely service alerts, the system runs smoothly all year long. In addition, routine maintenance and troubleshooting procedures are available to assist the user in performing specific tasks. Millitrack® e-Solutions provide enhanced data management control, remote access capabilities to the system dashboard, and long-term electronic archiving for your Milli-Q® Advantage A10.
Quality certificates
For full confidence in your Milli-Q® Advantage A10 system, it is delivered with a Certificate of Calibration for the built-in temperature and resistivity meters, and a Certificate of Conformity ensuring that it has been built and tested fully assembled following internal Standard Operating Procedures. In addition, all Milli-Q®Advantage A10 consumables are delivered with their Certificate of Quality. The manufacturing site is ISO® 9001 v.2000 and ISO® 140001 certified.
Advanced support & validation
A complete range of Services, including Validation support, is provided by certified Field Service Engineers using calibrated equipment and Qualification Workbooks. Millitrack® Compliance e-Solution has been designed specifically for the pharmaceutical, biotech and contract labs that follow GxP regulations (GLP, GCP, or cGMP regulations). Activation of Millitrack® Compliance software combined with Qualification Services will enable full water purification system compliance with record saving, electronic signature and auditing criteria guidelines such as those of FDA Title 21 CFR Part 11 or similar requirements set by other global regulatory organizations. A report on conformity of Milli-Q® Advantage A10 water quality to Type 1 water quality as described by ASTM®, ISO® 3696 and CLSI® norms, and to Purified Water as described in USP and EP is available upon request.
“The POD system allows us to focus on our research rather than watching containers fill with water. All we have to do is set the POD to dispense a specified amount of water and it does it automatically — no one has to stand there and turn off the system once the container is full.” Kris Gellynck, Ph.D., Senior Scientist, Orthox Ltd., Oxford U.K.
通知函
尊敬的合作单位:
    首先,感谢贵单位一直以来对我司上海金甚生物科技有限公司的支持。
默瑞(上海)生物科技有限公司做为我司的关联公司于2016年7月22日成立,现我司决定自2016年【8】月【1】日开始,原上海金甚生物科技有限公司负责的业务转由默瑞(上海)生物科技有限公司负责。贵单位与上海金甚生物科技有限公司之前尚在有效期的协议不受影响。
   由此给贵单位带来的不便,我司深表歉意!我司和默瑞(上海)生物科技有限公司将一如既往地和贵单位保持愉快的合作关系,并希望继续得到贵司的关心和支持!
上海金甚生物科技有限公司
                              2016年8月1日
上海金甚生物科技有限公司,取“甚于金”之意。公司主要从事高端医疗器械、仪器仪表、计算机软件的研发和销售。公司本着基础与前沿兼顾的原则,力求为科学家们提供生命科学和医学全系列产品,公司主要产品有:Leica显微系统,Merk Millipore实验室纯水超纯水仪,Tecan酶标仪、液体工作站,Roche实时定量PCR仪、DNA测序仪、核酸纯化仪,AB Sciex质谱分析仪,Seahorse细胞分析仪,Beckman离心机和流式细胞仪等,设备跨越形态学、蛋白组学、基因组学,全面满足分子、细胞、组织、胚胎和个体水平的研究,完全迎合个性化研究和大规模筛选需要,广泛应用于基础医药、科学研究、高等教育等广泛领域。
  客户至上客户的满意是我们最大的追求,金甚秉承客户的满意度标准是唯一标准的准则。我们承诺为您提供全球一流的专业设备,完善的技术支持,贴心的售后服务。只要您购买金甚旗下的任何产品,我们将为您使用的产品终身保驾护航。
  以人为本人才是企业发展的基础,我们坚持以人为本,特别注重每个员工的个性化优势,在此基础上综合培养,使每一位员工的综合素质和专业能力最大化。我们的团队是一支具有高素质和高效率的优秀专业团对,在技术、供货及售后服务等各个方面,我们呈现给客户的是高速度、高质量、个性化、一站式的服务。
  创新突破创新是公司发展壮大的助推器,在保障品质和完善服务的同时,我们特别注重产品的研发。我们的研发团队勤奋踏实、积极主动、坚持不懈。我们始终倡导多元文化的融合与互补,激发创新智慧,实现公司与个人的共同发展与飞跃。
  持续发展公司经历了14年多的发展历程,至今已成为同行业中的佼佼者。不仅获得了客户的满意与信赖,而且获得许多殊荣。不断坚持一流品质和放心服务是我们贯彻可持续发展的动力。
  甚于金,从心开始,精益求精,与您携手同行,共创未来。
西藏南路760号安基大厦704室
