滨松ORCA-Quest qCMOS相机 C15550-20UP
量子效率 | @peak QE: 90 % |
成像设备 | qCMOS™ image sensor |
有效像素 | 4096 (H) × 2304 (V) |
有效面积 | 18.841 mm (H) × 10.598 mm (V) |
满阱容量 | 7000 electrons(Typ.) |
读出速度 | Standard scan: 120 frames/s (@4096 pixels × 2304 pixels, CoaXPress) Standard scan: 17.6 frames/s (@4096 pixels × 2304 pixels, USB) Ultra quiet scan: 5 frames/s (@4096 pixels × 2304 pixels, CoaXPress) Ultra quiet scan: 5 frames/s (@4096 pixels × 2304 pixels, USB) |
读出噪声 | Standard scan: 0.43 electrons rms (Typ.) Ultra quiet scan: 0.27 electrons rms (Typ.) |
制冷方式 | Peltier cooling |
曝光时间 | Standard scan: 7.2 μs to 1800 s Ultra quiet scan:172.8 μs to 1800 s |
制冷温度 | Forced-air cooled (Ambient temperature: +25 °C) : -20 ℃ Water cooled (Water temperature: +25 °C) : -20 ℃ Water cooled (@max cooling; Water temperature: +20 ℃, Ambient temperature: +20 ℃) : Less than -35 ℃ |
暗电流 | 0.016 electrons/pixel/s (Sensor temperature: -20 ℃, Ambient temperature: +25 ℃) (Typ.) 0.016 electrons/pixel/s (Sensor temperature: - 20 ℃, Water temperature: +25 ℃) (Typ.) 0.006 electrons/pixel/s (Sensor temperature: Less than -35 ℃, Water temperature: +20 ℃, Ambient temperature: +20 ℃) (Typ.) |
动态范围 | 25 900:1 (Typ.)*1 |
外部触发模式 | Edge / Global reset edge / Level / Grobal reset level / Sync readout / Start *2 Edge / Start *3 |
外部触发信号路径 | SMA |
触发延迟功能 | 0 s to 10 s in 1 μs steps |
触发输出 | Global exposure timing output / Any-row exposure timing output / Trigger ready output / 3 programmable timing outputs / High output / Low output |
接口 | USB 3.1 Gen 1, CoaXPress (Quad CXP-6 ) |
A/D 转换器 | 16 bit, 12 bit, 8 bit |
电源 | AC100 V to AC240 V, 50 Hz/60 Hz |
功耗 | Approx. 155 VA |
室内工作温度 | 0 °C to +40 °C |
室内工作湿度 | 30 % to 80 % (With no condensation) |
室内储存温度 | −10 °C to +50 °C |
室内储存湿度 | 90 % Max. (With no condensation) |
Cell尺寸 | 4.6 μm (H) × 4.6 μm (V) |
Lens mount | C-mount |
图像处理功能 | Defect pixel correction (ON or OFF, hot pixel correction 3 steps) |
*1: Calculated from the ratio of the full well capacity and the readout noise in ultra quiet scan
*2: At Area readout, Photon number resolving
*3: At Lightsheet readout (Software such as HCImage is required. For details, please contact your local Hamamatsu representative or distributor.)
1、极低的噪音表现
为了以高信噪比检测微弱光,ORCA-Quest已针对传感器的各个方面(从结构到电子器件)进行了设计和优化。 利用最新的CMOS技术不仅完成了相机开发,而且还完成了自定义传感器的开发实现了0.27个电子的极低噪声性能。
2、实现光子数解析(PNR)输出
光是许多光子的集合。光子在传感器上转换为电子,这些电子称为光电子。 “光子数解析*”是一种通过对光电子计数来精确测量光的方法。为了计数这些光电子,相机噪声必须足够小于光电子信号的量。常规的sCMOS相机虽然实现了很小的读出噪声,但仍比光电子信号大,因此难以对光电子进行计数。ORCA-Quest使用先进的摄像头技术对光电子进行计数,并提供0.27电子rms(@超静音扫描)的超低读出噪声。随着温度和时间变化,其性能依然保持稳定,并且对每个像素值进行单独校准和实时校正。 *光子数解析与光子计数有很大不同(更精确地说,该方法可解析光电子数。但是,由于在该领域中可比较的方法是使用单光子计数而不是单光电子计数,因此我们将使用“光子数解析”)。
3、采用背照式结构,具有高分辨率
高QE对于高效检测光子来说至关重要。在常规的背照式传感器中,由于没有像素分离,所以在像素之间发生串扰,并且分辨率通常低于前照式传感器的分辨率。 ORCA-QuestqCMOS®的传感器具有背照式结构,可实现高量子效率,并且通过沟槽式结构,每个沟槽内只放一个像素,从而来减少串扰。
4、实现大像素和高速读出
现在通常使用诸如约0.3兆像素的EM-CCD相机之类的电子倍增相机来获取光子计数(PC)级图像。 但是,ORCA-Quest不仅可以获取PC级图像,还可以获取9.4兆像素的光子数解析图像。 另外,将不同像素数相机的读出速度按帧速率进行比较是不公平的。 在这种情况下,使用像素速率(像素数量×帧速率),即每秒读取的像素数量。 到目前为止,能够进行SPC读取的最快相机是EM-CCD相机,速度约为27兆像素/秒,但是ORCA-Quest能够以约47兆像素/秒的速度实现光子数解析成像,几乎快了一倍。
一款好的科研相机应该是软件与硬件相结合的产物。滨松提供的科研级相机不仅具有多种读出模式、校正功能、大像素、高读出速度等功能,我们也配备了相应的软件来完善每一位客户的工作。点击链接查看相关软件。
当客户选择一款用于工业或者科研等领域的相机时,需要考虑波长、光强等多种因素。我们提供了“相机模拟实验室”,该工具可让用户在检查模拟图像的同时直观地比较由于相机性能差异而导致的成像结果差异。点击链接了解“相机模拟实验室”。
产品应用
中性原子,离子阱
中性原子和离子可以被视为所谓的量子位,因为它们可以呈现叠加状态,在这种状态下,即使单个原子也具有多种属性。 人们正在积极研究这一特性,以实现量子计算和量子模拟。 通过观察捕获的离子和中性原子的荧光,可以确定量子位的状态,并使用低噪相机读取荧光。
● 天文学
星云成像
当从地面观察恒星时,由于大气湍流,恒星的图像可能会变得模糊,因此会大大降低捕获清晰图像的能力。 但是,在短时间曝光和合适的大气条件下,有时可以捕获清晰的图像。 因此,幸运成像是一种大量获取图像、整合图像最清晰的办法。
●拉曼光谱
拉曼效应是指与入射光不同波长的光的散射,拉曼光谱法是一种通过测量该波长来确定材料特性的技术。 拉曼光谱法可在分子水平进行结构分析,从而获取化学键合,结晶度等信息。
● 植物中的荧光延迟
在一段时间内,植物释放的光能中只有一小部分会吸收,以进行光合作用,这种现象被称为延迟荧光。 通过检测这种微弱的光线,可以观察到化学物质,病原体,环境和其他胁迫因素对植物的影响。
科研&工业应用相关科研相机网站
点击图片了解滨松科研级数字相机在科研以及供应领域中的应用。
随着ORCA-Quest的推出,用户现在能够以每秒120帧的速度将9.4兆像素的图像传输到他们的计算机。点击本链接,查看PC推荐列表,更加高效快捷的使用该款相机。
天文学是一个极具前景的研究领域,科学家们以及相关学者正在进行各种研究以发现和探索未知的天体和天文学现象,我们也对相关优秀的天文学家进行了采访。所以在该栏目大家可以对天文学相机应用案例进行学习,了解此类应用的示例以及适用于每种应用所使用的相机。点击图片了解学习。
成立于1953年的日本滨松光子学株式会社(以下简称滨松集团),是世界上科技水平最高、市场占有率最 大的光科学、光产业公司。使用滨松集团11200支20英寸光电倍增管的东京大学小柴昌俊教授的中微子实验获 得2002年的诺贝尔物理学奖。滨松集团的产品被广泛的应用在医疗生物、高能物理、宇宙探测、精密分析等产 业领域,是光产业界的领军企业。为了更好的贡献于中国光产业,紧跟中国十二五规划的步伐,在2011年10月 成立“滨松光子学商贸(中国)有限公司”。
滨松集团的中国业务最早可追溯到1988年,当时接到中国方面的技术支援请求后,与北京核仪器厂共同投 资兴建了北京滨松光子技术有限公司(以下简称北京滨松),现在作为光电倍增管等的生产销售基地在中国国 内创下了每年约1.3亿元(约16.5亿日元:以下按1元等于13日元换算)的销售业绩。另一方面,通过本集团直 接贸易实现的销售额高达约2.3亿元(约30亿日元),中国国内需求有不断扩大的趋势。在这一背景下,近几 年很多欧美顾客都在中国成立生产基地,而最近随着中国国内需求的扩大,他们又开始在中国成立产品开发基 地,由此无形中也带动了中国企业的成长。
因此,随着中国十二五规划的要求,中国相关研究所和企业加快了高新技术研究的步伐,在宇宙探测、新 能源开发、重离子治疗、正电子CT(PET)等方面要求我们提供更加优质和便捷的服务。所以在中国加大销 售、技术支持和产品售后服务等相关市场活动也逐渐显现出其必要性,为此我们在中国成立了滨松光子学商贸 (中国)有限公司(简称滨松中国)。将来,还预计根据当地的需求设立相应的开发体制,以更好的服务于中国。
单位名称: |
北京市朝阳区东三环北路27号嘉铭中心B座12层1201室
联系电话: |
Email: |
