动物行为
转棒疲劳仪,大鼠转棒仪,小鼠转棒仪
转棒疲劳仪,大鼠转棒仪,小鼠转棒仪
Rota Rod 转棒仪/鼠转棒仪
大鼠转棒疲劳仪,大鼠转棒疲劳仪,小鼠转
大鼠转棒疲劳仪,大鼠转棒疲劳仪,小鼠转
请致电:021-35183767,Email:yuyan0317@126.com
大小鼠转棒仪,也叫鼠转棒式疲劳仪,用来测试大鼠小鼠的疲劳和协调性,每个转棒仪配有电脑控制的连续速度或者加速模式,在转棒仪的下端有设置面板,每次动物落下,都会准确感应并记录,精确统计掉落的时间和总次数。无需连接电脑,主机上直接显示数据,方便快捷;也可选择配置,可以将数据链接到电脑上,每台电脑可支持4通道转棒仪。
五通道配置,可以同时对五只鼠进行测试;大小鼠通用化设计,一台设备可以配备大鼠转棒和小鼠转棒两种规格的配件。
TS1000型大鼠小鼠通用型转棒疲劳仪
主要特点:
磁感应平台,精确判断动物掉落,无需校正;
数字化控制,使用方便;
标准5通道配置,可同时做5只动物;
实验时长、起始速度、最大结束速度、转速可调;
正向和反向旋转两种模式;
跑动距离(单位为米)
配备脚踏开关;
主要技术参数:
可调测试时长:1到 999秒;
可调起始速度: 0 到 45 转∕分钟;
可调最大结束速度:45 转∕分钟
加速到最大转速的时间:0-999s;
正向和反向旋转两种模式;
跑动距离(单位为米)
根据需要还可以选择平板式跑步机:
大鼠平板跑步机
小鼠平板跑步机
相关文献:
Substitution of a mutant α2a-adrenergic receptor via “hit and run” gene targeting reveals the role of this subtype in sedative, analgesic, and anesthetic-sparing …
PP Lakhlani, LB MacMillan, TZ Guo… - Proceedings of the …, 1997 - National Acad Sciences
… Rotarod and Loss of Righting Reflex Tests. B6,129 male mice, ≈3 months old, were placed on
a rotarod (IITC, Inc., Life Sciences, St. Petersburg, FL) turning at 10 revolutions per minute. The
mice learned to remain on the rod during three 60-s training periods …
Chronic cannabinoid receptor 2 activation reverses paclitaxel neuropathy without tolerance or cannabinoid receptor 1–dependent withdrawal
L Deng, J Guindon, BL Cornett, A Makriyannis… - Biological …, 2015 - Elsevier
… after challenge (40). Rotarod Test. Motor performance was assessed using an
accelerating Rotarod (IITC Life Science) (4–40 rpm with cutoff time of 300 sec) (41).
See Supplement 1. Rectal Temperature. Rectal temperature (°C …
[HTML] Behavioural signs of chronic back pain in the SPARC-null mouse
M Millecamps, M Tajerian, EH Sage, LS Stone - Spine, 2011 - ncbi.nlm.nih.gov
… A cutoff latency of 17 sec was set to prevent tissue damage. Locomotor Capacity.
Locomotor capacity was measured by the use of an accelerating rotarod (IITC Life
Science Inc.) with the mouse adapter (rod diameter = 3.2 cm) …
Spinal gene transfer using ultrasound and microbubbles
M Takahashi, K Kido, A Aoi, H Furukawa, M Ono… - Journal of controlled …, 2007 - Elsevier
… 2.6.2. Rotarod. For assessing motor function after the intrathecal procedure, mice
were tested using a rotarod (IITC; Life Science Instrument, Woodland Hills, CA, USA)
three days after the gene transfection. The rod had a diameter …
Repeated administration of mirtazapine attenuates oxaliplatin-induced mechanical allodynia and spinal NR2B up-regulation in rats
X Liu, G Zhang, L Dong, X Wang, H Sun, J Shen… - Neurochemical …, 2013 - Springer
… Rotarod test was conducted to evaluate the effect of mirtazapine on the motor performance of
animals. As Blackburn-Munro et al. [21] described, changes in motor performance after drug
administration were measured using an accelerating rotarod (IITC Life Science Inc, USA) …
The aqueous extract of rhizome of Gastrodia elata Blume attenuates locomotor defect and inflammation after traumatic brain injury in rats
CF Ng, CH KoCM KoonWC Chin… - Journal of …, 2016 - Elsevier
… 2.6. Assessment of motor performance. Locomotor performances were tested using
an accelerating rotarod motor test (IITC Rotarod, IITC Life Science Inc., Woodland Hills,
CA, USA). Pre-training, a process to eliminate the dominance …
[HTML] Chronic cannabinoid CB2 activation reverses paclitaxel neuropathy without tolerance or CB1-dependent withdrawal
L Deng, J Guindon, BL Cornett, A Makriyannis… - Biological …, 2015 - ncbi.nlm.nih.gov
… following challenge (40). Rotarod test. Motor performance was assessed using an
accelerating rotarod (IITC) (4–40 rpm with cut-off time of 300 s) (41). See
Supplementary Material. Rectal temperature. Rectal temperature (°C …
[HTML] Involvement of EphB1 receptors signalling in models of inflammatory and neuropathic pain
V Cibert-Goton, G Yuan, A Battaglia, S Fredriksson… - PloS one, 2013 - journals.plos.org
… The Rotarod test was used to measure the balance and the forced motor-coordination activity.
We used a combination of both accelerating and staggered Rotarod procedures on an
accelerating Rotarod (IITC Inc. Life Science, Woodland Hills, CA) with a 32 mm diameter rod …
Resveratrol treatment in mice does not elicit the bradycardia and hypothermia associated with calorie restriction
JR Mayers, BW Iliff, SJ Swoap - The FASEB Journal, 2009 - fasebj.org
… For each time point, the mice were given a habituation trial on the first day, where they were placed on the rotarod (755 Rotarod; IITC Life Sciences, Woodland Hills, CA, USA) at a constant speed of 3 rpm for 45–60 s. The next day, each mouse was given 3 trials during which …
Composition comprising oil palm phenolics for use in providing neuroprotective effects and cognitive-enhancement
R Sambanthamurthi, SS Leow, YA Tan… - US Patent …, 2017 - Google Patents
… Rotarod Improved Motor Function and Balance Analysis In the second analysis mice in both
groups were also tested on a five-laned IITC 755 Series 8 rotarod (IITC Life Science, Inc.,
Woodland Hills, Calif.) every week throughout the feeding period …
Postnatal loss of methyl-CpG binding protein 2 in the forebrain is sufficient to mediate behavioral aspects of Rett syndrome in mice
T GemelliO Berton, ED Nelson, LI Perrotti… - Biological …, 2006 - Elsevier
… For the rotarod test, each mouse was placed on the rotarod (IITC Life Science, Woodland Hills,
California), which was then activated and its speed ramped up from 0 to 45 rpm in 60 sec. The
time to fall off the rotarod or turn one full revolution was measured …
Striatal dysfunctions associated with mitochondrial DNA damage in dopaminergic neurons in a mouse model of Parkinson's disease
AM PickrellM Pinto, A Hida… - Journal of …, 2011 - Soc Neuroscience
[HTML] In vivo analysis of MEF2 transcription factors in synapse regulation and neuronal survival
MW Akhtar, MS Kim, M Adachi, MJ Morris, X Qi… - PloS one, 2012 - journals.plos.org
… Rotarod. Each mouse was placed on the rotarod (IITC Life Science). The rotarod was activated
and its speed ramped up from 0–45 revolutions per minute in 60 seconds. The time to fall off
the rotarod or turn one full revolution was measured for four consecutive trials
Deficits in sensorimotor gating and tests of social behavior in a genetic model of reduced NMDA receptor function
GE Duncan, SS Moy, A Perez, DM Eddy… - Behavioural brain …, 2004 - Elsevier
… 2.4. Rotarod performance. An accelerating rotarod (IITC Inc., Woodland Hills, CA)
was used for assessing balance and motor coordination. Mice (n=8 NR1 +/+ and
n=8 NR1 −/−), from 2 to 2.5 months of age, were placed on a …
  被引用次数:170 相关文章 所有 8 个版本
您想了解更多详细资料吗?
请与我们联系:
TEL :021-35183767,18502129044
QQ :3007536035
Mail:
yuyan0317@126.com
欢迎您的咨询!
         卓越品质  贴心服务    ---玉研仪器
上海玉研科学仪器有限公司是一家专业为生物、医学、药物研发等科研领域提供科学仪器和技术服务的公司。我们着力引进和开发应用成熟、性能先进的实验设备和实验方法,为科学研究和实验室建设提供有效、合理的解决方案。
玉研仪器专注于生理、药理、毒理等动物实验和研究的相关领域,为客户提供动物麻醉与辅助呼吸、生理信号检测与记录、动物给药与暴露染毒、呼吸功能测量与肺功能研究、代谢与缺血缺氧研究、疼痛与炎症研究、小动物行为学研究、神经科学研究、小动物活体成像、生化检验、动物手术与辅助设备、动物手术器械等多方面的科学仪器产品和定制化服务。
玉研仪器致力于打造动物科研仪器领域的百科全书!
经营理念:诚信经营、实干兴邦、积极进取、回报社会
服务理念:客户至上、主动服务、快速响应、解决彻底
我们的使命:提供优质产品和高效服务,助力科研,成就科研
关注玉研仪器微信号:
在接到用户仪器维护和保养服务通知后,相应维修中心将在4小时内响应;并将派遣合格维修工程师在4个工作日内抵达现场进行维修并解决问题。(上海地区24小时内负责维修或更换损坏的零件) 专业的售后服务队伍 在保修期内,凡非人为因素导致仪器的故障均免费维护,售后服务中心将为用户免费更换配件,不收取任何费用,仪器保修期为:1年
上海市闵行区兴梅路579号科技绿洲B1栋3层
