LE-LS-HeNe 氦氖激光器
高稳定氦氖激光器系列产品Stabilized Helium-Neon Laser System Series
■ 632.8nm Stabilized HeNe Laser System
Applications:
□ Scientific Research
□ Spectroscopy
□ Fluorescence Measurements
□ Photoluminescence Measurements
□ Raman Measurements
□ Flow cytometry
□ Metrology
□ Semiconductor Inspection
□ Hematology
□ High-speed Printing
Features:
□ Easy operation & Free maintenance
□ High Reliability and High Power Stability
□ Long Operating Life
□ Low Noise
□ Excepional beam-pionting stability
LE-LS-633-N Series
Specifications:
LE-LS-633-XXXN Series Stabilized HeNe Laser System |
Mode No. |
LE-LS-633-XXXN ( XXX is output Power ) |
Center Wavelength |
632.8nm |
CW Output Power |
0.6mW ~50mW |
Operation Mode |
TEM00(≤5.5mW),TEM MM(>6mW); CW |
Beam divergence, full angle(mrad,typ.) |
0.8~1.0 |
Beam Diameter |
0.9~1.8mm(Optional) |
Spectral Line width |
0.28~1.75GHz |
Polarization Type* |
Optional (P Type) |
Polarization Ratio* |
>200:1( P Type, Optional) |
Power Stability |
<3%(S); <1%(H) |
Input Voltage(VAC) |
220VAC or 110V(Optional) |
Power Supply |
Optional; Type A(Standard), Type B(Module) or Type C(Compact); |
Expected Lifetime |
>15000h |
Operating Temperature |
10 °C ~ 40 °C |
Warranty time |
1 Year |
■ Other Styles and Custom designs are available. Contact us to discuss your needs.
■ *Polarization type is optional and the model is LE-LS-633-XXXNP.
Model Table:
Model |
Output Power(mW) |
Laser Tube Dimensions(mm) |
LE-LS-633-0.6N |
≥0.6 |
150*Φ26 |
LE-LS-633-0.8N |
≥0.8 |
150*Φ26 |
LE-LS-633-1.2N |
≥1.2 |
180*Φ26 |
LE-LS-633-1.8N |
≥1.8 |
230*Φ35 |
LE-LS-633-2.0N |
≥2.0 |
250*Φ35 |
LE-LS-633-3.0N |
≥3.0 |
300*Φ35 |
LE-LS-633-4.0N |
≥4.0 |
300*Φ35 |
LE-LS-633-6.0N |
≥6.0 |
350*Φ35 |
LE-LS-633-7.0N |
≥7.0 |
400*Φ40 |
LE-LS-633-8.0N |
≥8.0 |
400*Φ40 |
LE-LS-633-5.5N |
≥5.5 |
450*Φ40 |
LE-LS-633-10N |
≥10 |
450*Φ40 |
LE-LS-633-15N |
≥15 |
550*Φ48 |
LE-LS-633-18N |
≥18 |
600*Φ48 |
LE-LS-633-20N |
≥20 |
600*Φ48 |
LE-LS-633-25N |
≥25 |
700*Φ48 |
LE-LS-633-35N |
≥35 |
800*Φ50 |
LE-LS-633-48N |
≥48 |
l000*Φ50 |
LE-LS-633-W Series
Specifications:
LE-LS-633-XXXW Series Stabilized HeNe Laser System |
Mode No. |
LE-LS-633-XXXW ( XXX is output Power ) |
Center Wavelength |
632.8nm |
CW Output Power |
1mW ~70mW (Optional) |
Spectral Line Width |
<1MHz(typ.) |
Polarization |
Linear |
Polarization Ratio |
>2000:1(typ.) |
Operation Mode |
TEM00,CW |
Beam divergence, full angle (mrad) |
0.8 |
Beam Diameter |
0.8~1.1 mm |
Power Stability |
<3%(S); <1%(H) |
150~250VAC |
Power Supply |
Type A ; |
Life Time |
>12000h |
10 °C ~ 40 °C |
Warranty time |
1 Year |
Accessories
n LENS-632.8BE Series Customized Beam Expander for 632.8nm laser;
n LEM-632.8 Series Mirror for 632.8nm laser
n LE-MT-LS Series Customized laser mount for 632.8nm laser
n LE-MT-LENS Series Customized lens mount for 632.8nm laser
n LE-AD-FB-632.8SM Series Single Mode fiber adapter for 632.8nm laser
n LE-LS-632.8-Raman Series Specially Designed 632.8nm HeNe Laser for Raman Spectroscopy
购买询价或技术咨询,欢迎联系我司:
销售服务电话:177 2251 0197(直线);
销售服务邮箱:leophotonics@139.com
销售服务QQ:1227381373
注意:1.需要更详细资料,请参看PDF文档。或来电咨询我司实验仪器事业部,销售服务热线:17722510197(直线)或0755-25876905(总机),或加服务QQ:1227381373,或发邮件到leophotonics@139.com 或 sales@sz-leo.com索取报价单。
2.如果对产品规格有特殊要求,我们可根据您的实验或测试要求提供定制产品服务,并且提供系统解决方案,欢迎来电咨询。
理欧光电:您身边的光电专家!为您的科研实验保驾护航!
我司主要产品明细一览:
主要波长有:(213nm,266nm,325nm,355nm,375nm,405nm,410nm,414.8nm,415nm,430nm,435nm,440nm,442nm,445nm,
457nm,473nm,488nm,491nm,500.8nm,510nm,520nm,523.5nm,526nm,532nm,540nm,542nm,543nm,556nm,561nm,
5,光学平台:各种尺寸隔震光学平台(光学平板,面包板,精密光学平台,隔震光学平台,主动隔震光学平台,被动隔震隔震光学平台,气垫精密隔震光学平台,自平衡光学平台,大理石光学平台..)
7,弱信号检测仪器(锁相放大器,前置放大器,光学斩波器,调光片,光闸,光学快门,皮安表,2400系列数字源表...)
8,光电机械(光学镜架,光学调整架,光具座,手动位移台,电控位移台,um微米位移台,nm纳米位移台,多维度控制器,定制光学精密机械调整系统....)
深圳市理欧光电科技有限公司自2007年成立至今,一直致力于光学元件(玻璃/塑胶镜片、镜头、滤光片、棱镜)、光学系统(光谱测量、光电弱信号检测、光量测)、光学仪器(激光器、单色仪、光源、光电探测器)、光学精密机械(精密位移、光学隔振平台)的设计、制造及销售工作。已从早期的单纯光学产品代理,成功转型为拥有:自主研发、高精制造、国际品牌的高新技术型企业。
深处“光”、“机”、“电”一体化的时代,LEO人一向秉承“人才培养、技术创新、制度管理”的宗旨:
人才培养:企业从研发、制造及销售,各环节均由资深光学专业人员负责。并且每年都有来自国内光学知名高校的新生力量注入团队。企业高薪聘请业内资深技术顾问。为企业发展奠定了坚固、稳定的基础。
技术创新:“以市场为导向、以技术为根本”不断研发迎合市场需求的产品、扩充产品的应用领域。设计技术、制造工艺等不断学习、改进、创新;多项自主创新技术的成功发明及专利申请;提升了LEO自身竞争力,使LEO走出了自身特色。
制度管理:善于借鉴成功企业管理经验及制度,并结合自身情况。开展正规、系统化管理;注册“LEOPTICS”商标;树立、经营企业品牌形象等举措。LEO逐渐形成了一套适合自身的现代企业管理制度及模式。
“专业、诚信、友善”的经营理念,将LEO推向全世界并得到客户的接受与认可。除做好本土市场外,还在韩国、台湾、印度、法国、美国等世界各地成功发展了代理商及合作伙伴。LEO售出的不只是产品,更多的是提供专业的技术支持及完整的系统解决方案;以及长久、双赢的战略合作关系。LEO产品、LEO品牌、LEO精神已触及世界各地!
“Expert at Optical Solutions - 成为您身边的光学专家”是LEO全体同仁努力不懈、孜孜以求的目标及承诺!
