蛋白质芯片Reflective optical coating
生物芯片:蛋白质芯片Reflective optical coating
涂层:Reflective optical coating 反射光学镀膜
可应用于:乙肝诊断蛋白质芯片、寡核苷酸微阵列、微孔板蛋白芯片、SARS 诊断蛋白质芯片、化学微阵列、信号检测分析、某些肿瘤诊断蛋白质芯片、基于细胞的微阵列、探针的制备、微阵列扫描仪、微阵列定制、微阵列生物芯片、小分子微阵列、生物分子检测、抗体、全蛋白质组微阵列、三维凝胶块芯片等等。
Reflective optical coating (价格请来电咨询)
NEXTERION® HiSens Slides
Overview
Type of coating | Ordering information | |||
NEXTERION®product | Barcode option | Item number | Slides per pack | |
Reflective optical coating available with most of NEXTERION® functional coatings | HiSens uncoated | None | 1141518 | 25 |
Label | 1141519 | 25 | ||
HiSens AStar | None | 1178045 | 25 | |
Label | 1178046 | 25 | ||
HiSens A+ | None | 1139673 | 25 | |
Label | 1141515 | 25 | ||
HiSens AL | None | 1139827 | 25 | |
Label | 1141514 | 25 | ||
HiSens E | None | 1125813 | 25 | |
Label | 1137332 | 25 | ||
HiSens H | None | 1141517 | 25 | |
Label | 1139829 | 25 | ||
HiSens P | None | 1178051 | 25 | |
Label | 1178052 | 25 |
Key product features |
• Significantly improved signal to background ratios for identifying low-expressor genes or low-abundant proteins |
• Easy implementation with standard slide protocols |
• Compatible with all common microarray equipment |
• Reduced target concentrations |
• Reduced reagents and dye costs |
• Preservation of Cy3/5™ ratios – comparable to data from conventional slides |
• Chemically stable reflective coating |
Suitable probe types |
The functional coating on NEXTERION® HiSens Slides is identical to the respective coating on NEXTERION® Slides. Please refer to the table in the section “General information coated slides” in order to find the appropriate coating chemistry for your specific application. |
Product details
Taken together, these effects can theoretically enhance the fluorescence signal by up to 12.6 times when compared to standard transparent microarray slides.
Increased sensitivity
Significant increases in fluorescent signal intensities and signal-to-background ratios have been demonstrated with the NEXTERION® HiSens E and A+ products, the first two slide surfaces launched by SCHOTT in the HiSens range in 2006 (all slide surfaces are now available). The functional coatings are identical to the standard NEXTERION® slides and were processed with standard slide processing protocols. The results clearly exhibit the same impressive spot size and morphology that users typically associate with NEXTERION® Slide E and Slide A+, but the signal intensity is significantly enhanced thanks to the HiSens coating.
Identical oligonucleotide probes were printed on NEXTERION® HiSens A+ and the standard NEXTERION® Slide A+. The slides were hybridized and scanned on an Axon 4000B scanner with identical settings. Images of the NEXTERION® HiSens reflective coating are compared to standard Slide A+. The NEXTERION® HiSens A+ data was normalized against the standard NEXTERION® Slide A+. An 8 to 10 fold increase in signal-to-background ratios was obtained with the NEXTERION®HiSens reflective coating compared to the standard NEXTERION® Slide A+.
肖特集团是全球领先的特种玻璃及相关特种材料、元件和系统制造公司。公司创始人Otto Schott先生于1887年发明了抗化学侵蚀的硼硅酸盐玻璃,能耐高温及温度骤变,并在1938年注册了商标DURAN ™(杜安),125余年以来高硼硅玻璃已成为高品质实验室玻璃器皿的材料标准。集团目前拥有约17,000名员工,肖特集团的主要市场涉及医药、生命科学、光学、家用电器、新能源、航空铁路交通以及建筑行业等领域。2010/2011财年全球销售额近29亿欧元。
Duran™(杜安)主要产品:
实验室试剂瓶(蓝盖瓶)
配套瓶盖及连接系统
容量瓶
烧杯
烧瓶
培养试管
培养皿
移液管
滴定管
干燥器
单位名称: |
上海市虹梅路1801号凯科国际大厦301室
联系电话: |
Email: |
