太阳能电池伏安曲线测量系统
Sciencetech模型SSIVT是一种电流电压测量系统,使用Keithley 2400系列源表来表征光伏电池的性能。 科学技术公司制造太阳能模拟器,并提供各种电池测量配件,例如参考电池,电池卡盘和冷却设备,以提供完整的PV测量套件。
结合Sciencetech的负载助推器系统,Sciencetech可提供行业领先的功率范围。 我们的最大可测量面板高达200V,80A。 请参阅下面的BI系列模块信息。
Sciencetech的SSIVT系统可以与我们广泛的闪光灯和连续太阳能模拟器及配件结合使用,以创建满足您确切需求的定制模块化系统。
特征
| Model | SSIVT-21C | SSIVT-20C | SSIVT-60C | SSIVT-T20C | SSIVT-2KC |
| Part No. | 175-9106 | 175-9103 | 175-9101 | 175-9108 | 175-9107 |
| Measured Quantities | Voc, Isc, Vmax, Imax, Pmax, FF, Rseries, Rshunt | ||||
| PV Voltage Range | 0 - 20V | 0 - 200V | 0 - 60V | 0-200V | 0-200V |
| Current Range | 0 - 1A | 0 - 1A | 0 - 3A | 1A | 10A |
| Power Range | 0 - 20W | 0 - 20W | 0 - 60W | 0-20W | 0-2000W |
| Running Mode | Continuous | ||||
| Source Measure Unit (SMU) Model | Keithley 2401 | Keithley 2400 | Keithley 2420 | Keithley 2450 | Keithley 2400 |
| Touchscreen | NO | NO | NO | YES | NO |
| LoadBoost Module | None | BI100 | |||
| Expandable Range with LoadBooster Add-ON |
NO | YES | NO | YES | YES |
| Voltage Source Accuracy at Maximum Voltage (1 Year, 23ºC ± 5ºC) | 0.02%+2.4mV | 0.02%+ 24mV | 0.02%+7.2mV | 0.015% +24mV | 0.02%+ 24mV |
| Voltage Programming Resolution at Maxi-mum Voltage | 500µV | 5mV | 1.5mV | 5mV | 5mV |
| Current Measurement Accuracy at Maxi- mum Current (1 Year, 23ºC ± 5ºC) | 0.22%+570µA | 0.22%+570µA | 0.052%+1.71mA | 0.03%+500uA | 0.22%+57mA |
| Connection | 4-wire (Remote) Measurement (In/Out + Sense +/-) | ||||
| # of Data Points / Scan* | 2 - 100 | ||||
| Scan time* | 2 - 50s for steady-state illumination | ||||
| Operating System Compatibility | Windows 7 32-bit | ||||
| Model | SSIVT2F | SSIVT-60F | SSIVT-2kF |
| Part No. | 175-9104 | 175--9102 | 175-9100 |
| Running Mode | Pulsed | ||
| Source Measure Unit (SMU) Model | Keithley 2400 | Keithley 2400 | Keithley 2420 |
YES | NO | YES |
| Voltage Source Accuracy at Maximum Voltage (1 Year, 23ºC ± 5ºC) | 0.02% + 24mV | 0.02% + 7.2mV | 0.02% + 24mV |
| Voltage Programming Resolution at Maximum Volt-age | 5mV | 1.5mV | 5mV |
| Current Measurement Accuracy at Maximum Current(1 Year, 23ºC ± 5ºC) | 0.22% + 570µA | 0.052% + 1.71mA | 0.22% + 57mA |
| Scan time* | 10s-10min for pulsed illumination | ||
| Model | Voltage | Current |
| BI100 (166-9001) | 200V | 10A |
| BI200 (166-9010) | 200V | 20A |
| BI400 (166-9011) | 200V | 40A |
| BI600 (166-9012) | 200V | 60A |
| BI800 (166-9013) | 200V | 80A |
| Name | Description | |
| 175-9050 | IV Test / PTS Temperature Measure- ment Upgrade | This is a modification to the Keithley unit used for IV Test measurements to allow the system to measure temperature at the same time as intensity. These Keithley units are used in all of Science- tech's line of Photovoltaic Testing Systems, as well as our stand-alone IV Test units. Please note that this system requires a calibrated reference cell to operate, and will not function with flash illumination systems. |
| 175-9105 | (SSIVT-TU) Point-by-Point Irradiance and Temperature Measurement Upgrade for IV Testers | This upgrade adds the necessary hardware and software modifications to Sciencetech's SSIVT line of IV Testers to allow real-time measurement of temperature, irradiance, and calculations of thermal coeffi- cients for each point of the IV curve. Please note that this upgrade requires a Sciencetech IV Tester in order to function, and will not work if a 3rd party tester is purchased from a different supplier. Please speak with your authorized Sciencetech technical support staff member to discuss specifications and any additional details required. |
| 单位名称: |
北京市石景山区鲁谷路51号院泰禾长安中心3号楼A塔11层1108
| 联系电话: |
| Email: |
